Question about Ovens
My neff oven b1664 rear fan element stays on after switched off
After my oven as been turned off,even hours later, the rear fan element stays on high heat for ages, the only way to turn it off is if i switch it off at the wall,a few days before the fuse had blown at the wall, so obviosly something may have blown inside the cooker but what?
  • Ovens Master
  • 3,463 Answers
I suspect that the fan oven thermostat is faulty,probably a contact welded inside the stat.or possibly a faulty function selector switch.
If the fan is not running, then it is still getting a supply from the thermostat. Fit new stat.
Posted on Dec 11, 2008
Neff B1644 Oven Fan Issue
096825 is the part number for circo fan grease hardened in the motor bearing is making it stiff the motor has little torque to overcome resistance the grease melts at high temps allowing motor to turn. time for a replacement comes as complete unit with new blade.
Jan 28, 2014 | Neff B1644 Electric Single Oven
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
Switch oven on within 3 mintues the fuses blow main fuse box
I suspect the fan oven element has failed, this is located at the rear of the inner oven compartment behind a removeable cover
It is probably breaking down as the element gets hotter.
Feb 28, 2010 | Neff B1421 Electric Single Oven
NEFF U1271 Oven overheating
Hi it could well be the thermosat has stopped working
Jan 24, 2010 | Neff U1721 Double circotherm Electric Oven
MAIN OVEN DOES NOT TURN ON HIGH
this could be the thermostat or the main oven element this sheet might help. For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 14, 2010 | Smeg Ovens
Replace fan motor in an electric fan oven
Jan 13, 2010 | Neff B1421 Electric Single Oven
Neff circotherm doudle oven main oven fan working
It is more than likely that the oven element has failed.
You will it located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 09, 2010 | Neff B1641 Single circotherm super...
NEFF B1320 OVEN DOES NOT HEAT UP. POWER ON FAN WORKING
For all Free appliance repair videos visit our VIDEOTUTORIALS neff video
1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Dec 25, 2009 | Neff B1641 Single circotherm super...
The oven packed up on me yesterday.The grill heater still works, also the fan and timer. Is it repairable and at approxiamate cost. I cannot afford another Neff oven. It is barely 6 years and this is the...
You have a very good chance that it could simply be a faulty oven elemenr or burned wire or even an over temp. cutout switch. Have it checked by the technician and possibly get a quote..(When repair is done, you want to see faulty items).
Sep 24, 2009 | Neff B1421 Electric Single Oven
How do you change the language on Neff B1664 Oven?
press the SSS button on the left hand side (this is next to the cC button) for 5 seconds you will see a list of languages By David Allen in Bolton
Feb 14, 2009 | Neff B1691 Single circotherm super...
Ovens Logo
247 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
