Question about Canon PowerShot A520 Digital Camera
Shutter doors out of alignment/won't open
The camera got banged around while inside a backpack, and now the two little doors that are supposed to open over the lens will not open. It appears that a little "arm" that is meant to be behind the door is now in front of the door. I have tried to carefully use a sharp instrument to push the little arm down, while pulling up on the door (at the same time) to get it to pop back in the track....to no avail. Thanks for your help!
    Scholar:
  • 99 Answers
Sounds like you will need to replace the shutter doors. Go to www.canon.com for a repair service form.
Posted on Feb 08, 2008
SOURCE:
When the camera is turned on the shutter won't open all the way.
If you mean the lens (the barrel that's supposed to extend from the body), try these procedures.
Mar 01, 2013 | Nikon Coolpix S3000 Digital Camera
97 Mercury Mountaineer driver side door won't open. Outside handle flops around; inside handle won't open door
Try a slim jim first, down the side of the window. Or AAA or locksmith. If no luck, remove the seat first. Find the screws and bolts around the door handle and arm rest. Most Ford's have screws around the outer side of the panel. I don't believe your's does. The panel lifts or pops off. Once the panel is off, you can reach down and open the door. Just a note. I have done some to where the panel came out in pieces.
Mar 14, 2012 | 1997 Mercury Mountaineer
I have a Canon PowerShot SD1000 and it turns on, but the screen is blank. It will upload any photos taken (although you can't see what pics you take), but even then you have to click the button on the...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife happens to own a SD1000. Great little camera, but it's prone to stuck shutter every once and a while. Easily fixed each time though by simply opening the battery door while on, and gently flicking the lens barrel a few times. Again, see the link.
May 31, 2011 | Canon PowerShot SD1000 Digital Camera
Just recieived a used Nikon N80 and it gives the message of open door.Frame counter and film indicator flashes when door is shut and no film is in in camera?
Confirm tht DX shows in LCD. If not then press and hold shift button then press ISO so "DX" appears.Open Camera Back. Insert film cartridge, pull film leader out to right and align with red index mark (inside film chamber on right). Make sure there is no slack in leader.Close camera back until lock release snaps closed. Fully depress shutter until film advances to first frame.
Confirm " 1" and film transport show in LCD. If Film is not loaded correctly, "ERR" show on LCD. Open cack and reload film.
Users manual can be downloaded from:
http://www.lensinc.net/manuals/Nikon_N6006L.pdf
Nov 03, 2010 | Nikon N80 35mm SLR Camera
Canon Powershot A510 - lens covers stuck
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it. There are many non-invasive techniques that people have come up with to accomplish this. Some may be seen on this blog article. You can also open the lens barrel up to fix the covers, but only as a very last resort. The article also gives examples for this type of procedure.
Jun 06, 2010 | Canon PowerShot A510 Digital Camera
Hello, My Canon a590 shutter wil not open,stuck closed.
I was THRILLED to find this fix for my camera when the shutter wouldn't open. The 590 is a little different than the 540 in these pics, but the solution still worked. I didn't even have to do as much disassembly as he did--just had to take the little circular thing off the top of the lens, and clean the little flap things inside. Here's the link: http://ilmoita.net/mot/?p=4
Jan 09, 2010 | Canon PowerShot A590 IS Digital Camera
Film advance not working smoothly
Open the film door and see if the shutter cutains are aligned straight. If not the curtains are at fault. If not the gearing is bad inside your camera
Dec 02, 2009 | Pentax K1000 35mm SLR Camera
Vivitar 8025 camera won't turn on and when I charge it,the red light just stay on. Just bought never even used it.
I had this problem, and I fixed it by flipping the battery around. It looks like it's supposed to go one way, but it's supposed to be the other.
Oct 19, 2009 | Vivitar ViviCam 8025 Digital Camera
Canon A310 Won't Power Up.
Try checking this... on the battery door (the outside door) along the top edge (over the CF card pointer embossed in the back of the door) you should see a little plastic piece that pokes out... tis is supposed to push a small switch located in a slot over the battery compartment. It's the sensor that tells if the battery door is open or closed.. if the plastic part breaks off or gets chipped it wont push the button and the camera will not turn on when the shutter door is opened.
Jun 09, 2007 | Canon PowerShot A310 Digital Camera
Canon A40 Shutter Stuck The Camera works fine with all icons but it appears that the shutter is stuck open causing a black screen. Please advise how to solve this problem by myself. thanks and regards
It is impossible for the Shutter to be stuck, as the A40 does not have a Shutter. Sounds like you have a bad image sensor. I would contact Canon about this as they acknowledge a defective sensor in some of their models. However, depending on how old the camera is and depending on if it is one of their recognized defects, you may have to purchase a new one. Wait, what do you mean by shutter? do you mean the little covers on the front that open to exspose the lens? the little curtin like things? Tap on the front this can sometimes snap them open. If you can see the glass in the front and its still black, make sure your "display" button is not set to the off mode. Sometimes it can power on and the display will be off because it was turned off before the last time you used it. If its still black it could be a bad connection inside, wich controls the camera section inside the unit. If you bang or bump the camera ont he side will the screen flicker or show purple lines? sometimes show an image?
Mar 19, 2006 | Canon PowerShot A40 Digital Camera
Canon PowerShot A520 Digital Camera Logo
51 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
