My Canon Mp130 Printer waste ink absorber is full. How do I replace it ?
I hope I have fixed it. I followed the advice of 'Reverend' this morning and did some mopping up with the aid of a torch and some tissues and have made a couple of unblemished copies.Despite this the screen still says 'waste absorber nearly full' and I would like to instruct it to cease !
pe004h9127
Posted on Dec 12, 2008
Waste ink absorber is almost full on my Canon Pixma MP130 will not print. How do I locate this absorber and how do I clean it ?
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Sep 11, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
Waste Ink absorber is full.
this msg show that you will need to reset your printer waste ink counter and replace the waste ink pad.. you can try to reset it with a resetter software here.
http://www.fix-printer.moon4ever.com/?cat=5
May 28, 2010 | Canon PIXMA MP130 All-In-One InkJet...
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
5) Select OK
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste Ink Absorber on Pixma MP130 multifunctional is almost full.
You don't have to change the waste ink absorber. There are two in the MP130 and they cost about $15 each. I have found though that you can just reset the counter and let the printer run without any problems. I have done this with three now with no problems. Reset procedure is:
1. Start Printer
2. Press button MENU, then SCAN, COPY and again SCAN – the printer will go into the service menu.
3. select NVRAM ACCESS and further BY OK.
4. select SET Abs- m level and reduce to zero.
5. select SET Abs- r level (if there is) and reduce to zero.
6. Turn off printer by button POWER.
Jan 05, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber is full How do i empty it
You can't empty that one, you need a shop to replace the pads which are under the printer, and they can reset the waste ink counter at the same time.
Sep 29, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
Jul 05, 2009 | Cannon Office Equipment & Supplies
The waste ink absorber is full.
You have to contact the Canon agent to get the waste absorber replaced. or you can continue it with pressing resume everytime.
Apr 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
The waste ink disposal is almost full and it won't print
The waste ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>
WASTE INK NEAR FULL The printer has a built-in waste ink absorber to hold the ink used during print head cleaning, for example. This error message indicates that the waste ink absorber is nearly full.
Press the OK button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact a Canon1.gif service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing cannot be performed until the Waste ink tank is replaced.
this answer is directly from canon
Jan 30, 2008 | Canon Pixma iP6210D InkJet Photo Printer
Canon pixma MP130
ink waste absorber is almost full, what should I do?
Jan 20, 2008 | Canon PIXMA MP130 All-In-One InkJet...
66 people viewed this question
k24674
jasbo
jasbo
