Question about Pitco Frialator SG14 Deep Fryer
Control board not going on in the morning
    Problem Solver:
  • 11 Answers
Do you have a electronic ingition or standing pilot ? What model and serial #
Scoota
Posted on Feb 01, 2009
I HAVE THERMODORE OVEN. CONTROL BOARD FROZEN IN THE BROIL MODE. MODEL ? SEC34285 /02
Good morning William, first thing to try would be shutting off the power to the unit and wait a minute or two then turn it back on. That should reset the board if it's a glitch in the programming. If that doesn't solve the problem,you'll probably going to have to replace the control board. It could also be a problem with the power board having a relay fused shut,so that it is always feeding the broil circuit. Really need to get hands on to pin it down exactly,but those are your most likely problem spots. Hope that helps.
Feb 10, 2018 | Ovens
Samsung Plasma PN59D8000FF no picture no sound
Generally if the power lamp is on but the set is dead its the power board, you could remove the back if your comfortable doing so and check the voltages going from the power board and see if any are missing or incorrect...good luck!
Nov 25, 2017 | Samsung Televison & Video
Xerox center printer is being shut off instead of going to sleep and wake on job
bad control board or might be settings to put in sleep mode then shutoff check settings go to menu
Jun 03, 2015 | Xerox Office Equipment & Supplies
When the motor is bad can it cause the Motor Control Board to go bad also?
Good Morning Friend,
I understand that you want to know if the motor is bad in your Frigidaire Affinity washer, model# ATF7000E, can it cause the motor control board to go bad as well. Just because the motor is bad, does not mean that the motor control board is bad. It depends on what is going on with your appliance. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine exactly what is going on. Hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Affinity ATF7000E Front Load...
How to troubleshoot gsh25ggcb refrigerator not cooling?
There is a very good chance the control board is the culprit. The fans are ran from a separate circuit form the control board. There is a slim chance that one of the sensors is bad but it is rare. The cost of the control baord is a steep one but I have replacxed many of them without any visible burned spots.
Jun 14, 2014 | Refrigerators
How do I test the digital circuit board that controls the temperature in refrigerator and freezer
I understand you are trying to test the digital circuit board that controls the temperatures for your Frigidaire refrigerator, model# FRS22ZRG. Typically, this is not a do it yourself test, as there are no step by step instruction manuals for this. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your refrigerator and determine what is going on with your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 12, 2014 | Frigidaire Refrigerators
There is no power going through my Bosch 1200 washing machine. I have changed the fuse but nothing. The powe supply is fine. I have moved on Saturday and the machine was working fine in the morning
In such cases what is needed is to remove the power plug and using a multimeter you must check the continuity of the power to the main controller board. If so connect and check the mains voltage to the board. If the boarrd does not respond you need to remove and replace unless you are an expert to check for component level failure.
click this link for tips : Control board
Jun 26, 2012 | Bosch Washing Machines
My Whirlpool Refrigerator ED5PVEXWS Not Getting Cold. We got up this morning and everything in the freezer melted. We bought it in November. it still gets power the lights are on inside. still under...
First thing I would consider is the=> W10135899 Defrost Control Board The first thing that stops is the compressor and fans most times when they go bad. You can find this board here=> ED5PVEXWS00 Control Panel Your control panel is found above the top shelf inside the fresh food compartment. Just unplug the power to refrigerator and lower the panel and where part 6 is in the photo is where the board is located. Most times when these boards burn out it creates this problem you described. Replacing that board should get you going and back to cooling normally. I will be here if you have other questions, Thanks, Sea Breeze
Apr 23, 2011 | Refrigerators
I have a whirlpool side by side refrigerator model no GS5SHAXNB00 refrigerator light blew this morning i replaced the bulb no lights working on refrigerator side and temp control settings
you need to replace the main/board for sure located in the lower rear left hand wall of the unit in a plastic case, it will have 3 wire harnesses unplug the unit,undo the plastic container and unplug the the board and there will be a burned spot on the case and burned trace on the circuit board, reason being,this is very common on any of these sideXsides,if a light blows out in the refrige compartment it puts a surge on the board and burns the circuit trace open,this makes the digital temp read-out go dark and if the lamps light at all they "strobe" dimly or not at all,and you will hear a clicking of the relays in the rear area trying to latch the light bulb circuitry, but cant because the main/mother-board is defective now
Mar 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My home air conditoning compresor doesn't always come on.
All timers are located on the main control board in the air handler " inside unit ". There is a circuit board in it near the heat strips and it has a couple of relays that are notorius for going out. Replace the board and the condenser unit " outside unit " should start to operate properly.
Jul 07, 2009 | Heating & Cooling
Pitco Frialator SG14 Deep Fryer Logo
43 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
