Question about Karcher 1750 psi Electric Pressure Washer
How to Install the Pump Guard into Electric Powerwasher
I received a bottle of Pump Guard to winterized my Electric Power Washer I follow directions, only to find out the Pump Guard bottle had threads outside of bottle and the high pressure outlet had outside threads.Could you send me directions so, I can Service my Power Washer
Thank You,
Mr Norman Blum
    President:
  • Karcher Master
  • 1,388 Answers
Here is the web page on how to install the pump guard. The bottle is installed on the water inlet side of the pump. Good Luck, enjoy
http://www.karcherresidential.com/support/downloads/pdfs/pic_guide/karcher_pmpgrd_elec_pg.pdf
Posted on Dec 12, 2008
My powerwasher Generac model# 0060223 is spraying water I think from the pump. Any ideas as to what is wrong.
if you did not winterize it it might have froze up and busted I was given one years back that si what happened to it before I got it and luckily I was able to fix with some lock tight spread on a thin layer and clamped it tight for several days to cure out
Apr 17, 2015 | Generac 6022/5989 2700 PSI 2.3 GPM 196cc...
Tip
Winterizing your Pressure Washer
Once again it's that time of year to get your pressure washer prepared for the cold months ahead. Proper winterization will protect your pump from the freezing of excess water in the pump over the winter. There are many ways to winterize your pump; we like to classify it as the good, better and best.<br /> <br /> Good: (Gasoline powered) Leaving your machine in the off position with the high pressure hose disconnected pull the recoil rope 4 to 5 times or until you don't see any more water coming out of the high pressure end of the pump. (Electric powered) Disconnect your high pressure hose, turn the machine on for 5 to 10 seconds or until you don't see any more water coming from the high pressure end of the pump.<br /> Better: If you have a air compressor around the house, hook the air line to the garden hose end of the pump and blow the water out until you don't see any more water coming out of the high pressure end of the pump.<br /> Best: Purchase Karcher's Pump Guard, follow the simple directions that come with the product. This product is specially formulated to keep your pump from freezing, corrosion, premature wear, adds lubricant to the valves and seals to prevent sticking in the spring. You can usually get 2 or 3 uses from one bottle of Karcher's Pump Guard. <br /> <br /> <a href="http://www.wmpcs.com/blog/?p=63">Visit this link to read more</a>
on Nov 01, 2010 | Garden
Is there a drain plug to remove any standing water within the pump to prevent freezing over the winter? I have lost the manula that came with the pressure washer
No, there isn't a plug to drain the water. There are a couple options though when it comes to winterizing your pump. Here is a link with the different options
I would recommend using Karchers Pump Guard, it works very well and can be assured that your pump is properly winterized.
Here is the information on how to use Karchers Pump Guard
Oct 31, 2010 | Briggs Stratton 020273 Elite Series...
Directions of how to change a power steering pump
Removal/Installation
  1. Disconnect battery ground cable.
  2. Disconnect inlet and outlet hoses from pump.
  3. Remove serpentine belt guard as necessary.
  4. Remove belt from pulley, using 1/2 inch breaker bar.
  5. Remove coolant recovery bottle as necessary.
  6. Remove pump assembly.
  7. Transfer pulley as necessary.
  8. Reverse procedure to install, them bleed power steering system as follows:
    1. Turn wheels all the way to left.
    2. Add power steering to Cold mark on fluid level indicator.
    3. Start engine and run at fast idle, then add fluid, if necessary, to bring level to Cold mark.
    4. Bleed system by turning wheels from side to side without hitting stops. Keep fluid level at Cold mark.
    5. Return wheels to center position and continue running engine for 2-3 minutes.
    6. Road test vehicle to ensure steering functions normally and is free of noise.
    7. Check fluid level and ensure level is at Hot mark after system has stabilized at its normal operating temperature.
Aug 19, 2010 | 1992 Oldsmobile Cutlass Supreme
POWER CRAFT BY Karcher bought Aldi on 31Mar 05.2100Watts 130 bar.
You did winterize the machine? Leaving water in a powerwasher will freeze and damage the pump. It's a common happening, because people don't think of it or are not told by the maker.
Apr 29, 2010 | Karcher K2.26 Electric Power Washer
Red light on power cord stays on powerwasher wont turn on
The red light means you are getting power. It sounds like the bypass (unloader ) valve is stuck. This is inside the actual pump
Sep 12, 2009 | McCulloch FHH18A Electric Pressure Washer
Windshield washer pump
if it is the same as a 2002 UK spec then the washer pump is situated at the bottom of the washer bottle. the washer bottle is situated behind the inner guard on the same side as the filler cap for the washer bottle.
the pump is push fitted to the water bottle.
if u have been using window washer additives then they can form a slime that stops the pump working.
if that is the case then remove the pump and wash it under the warm tap to clean it out and refit.
hope this helps
oscargilpin
Mar 22, 2009 | 2004 Hyundai Santa Fe
Karcher power washernot as powerfull as previously
Look for +/- on knob and turn + direction for max pressure.
Mar 18, 2009 | Karcher K2.26 Electric Power Washer
Karcher 1750 psi Electric Pressure Washer Logo
400 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
