Question about Kenmore 22422 Top Load Washer
Loose Belt Drive
I just need to replace a loose belt drive on a Kenmore washer/dryer stackable the washer part. How do I do it myself?
  • 108 Answers
Remove the rear cover on the unit and see if the belt is loose. It should not stretch more than 3/4" when you pull on it. There may be an adjusting bolt on the motor to tighten the belt. Disconnect power before working on the unit!! You should have an owners manual for this unit. Check it for further information.
Ray
Posted on Dec 14, 2008
Need to replace belt
Search Results
    How to repair a KENMORE double decker washer&dryer ...
    ? 4:59
    www.youtube.com/watch?v=Rc_ZGugYBTY
    May 31, 2014 - Uploaded by MrProductionist
    How to repair a broken dryer belt from a Double Decker Washer and Dryer. ... I have a Kenmore stackable Washer-Dryer, and the dryer belt is ...
Oct 21, 2015 | Frigidaire FFLE1011MW White Washer/Dryer...
How do I change the dryer belt
You need to take the front cover off by lifting the top and removing 2 screws and remove the 2 screws on the bottom, pull the front cover off the drum will fall. just slip the old belt off and put the new one on and leave the belt loose until you replace the front cover. Then hook the belt around the motor and tension er . By the way before your take it apart ,note how the tentioner is placed.
Jul 26, 2014 | Frigidaire Front Load Stackable Washer
The spin cycle is very slow. how do i tighten the belt?
there is no adjustment that can be made.either your motor windings are weak and causing the tub to spin slowly.or the transmission bearings are going out causeing extra tension and slowing it down.
you could have a bad belt as well over time they do get a little stretched and become loose on the pulleys.
Jan 31, 2010 | Kenmore 98702 Stacked Washer/Dryer
Hey bud, i replaced my kenmore washer with a new coupler, but still it will not spin??
inspect under the washer. look at springs for broken or one that may have come loose. inspect drive belt for broken or off pulleys. the drive belt is not turning pulleys, belt maybe broke or outa pulley grooves. or belt tension springs are broken or unhooked. good luck!!
Jan 09, 2010 | Kenmore 24032\24036 Top Load Washer
We have a stackable kenmore washer and dryer. The belt started to slip and smoke on a heavy wash load. I replace the belt but it still smokes and wont spin. Is there and adjustment?
Hi, There are no adjustments. Make sure the pulley on the idler and the drive pulley are tirning freely. It is possible the transmission is locked up and the belt will not turn properly.
If all the pulleys are free, start the washer in the spin cycle while watching the drive pulley to see if it turns.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 18, 2009 | Kenmore 98702 Stacked Washer/Dryer
My kenmore stackable model number has been
there should be a number on the belt take it to the spares place and they should be able to match one up for you
Jul 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable washer/dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
May 25, 2009 | Kenmore 93702 Top Load Stacked Washer /...
Belt Keeps Breaking
Maybe it cause a too tied belt.
Oct 03, 2006 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 22422 Top Load Washer Logo
96 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
