Question about Amana ACS3350 Gas Kitchen Range
Kompact BCE600/2SS stops working cools off then starts again
Oven works for a short while then stops when cooled down will heat up again help
3 Suggested Answers
  • 3 Answers
SOURCE: Model ACS3350 oven stops heating up mid cycle
Does your range ever get very very hot on the exterior, mostly by the control panels?
Posted on Aug 21, 2009
  • 6 Answers
SOURCE: WHEN THE OVEN REACHES A CERTAIN TEMPERATURE,
I had this same problem...I needed to replace the digital pad, cost about $200 online and took about an hour to replace. The heat from the oven wears out the electrical components in the pad...good luck!
Posted on Oct 10, 2009
Can it be used without the fan?
If you want to get anymore useful life out of it, stop operating it without the fan.
Aug 18, 2015 | Whirlpool Microwave Ovens
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
Jun 05, 2017 | Heating & Cooling
When my corolla is cold it starts fine. I can drive for about a 1/2 mile and then it quits and will not start. I let it sit for awhile and it will start again but not run for very long. So it seems to be...
Is there any kind of check engine light on, or emissions light on? Sometimes when the ignition coils heat up they will short out and stop working, and after they cool down they will work again only till they heat up, then they will stop. If this doesn't help i would need more information to better diagnose whats wrong. Thanks, good luck, Bob
Mar 13, 2011 | 2005 Toyota Corolla
Kompact oven wont heat up - is a fan oven - grill working
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 01, 2011 | Microwave Ovens
Gas dryer won't heat with cover off
The 2 coils on the gas valve , need to be replaced . After the dryer runs for a short time , the coils get warm from the electricity going thru them . The weaker valve , shorts internally , not letting the gas go thru . After the dryer cools down , and the coils cool down , then the short will close ( giving continuity ) , until they warm up again . If you had given the model number , I would have given you the part number .
Sep 17, 2009 | Maytag Dryers
Sanyo EM S667W 1000W 240V Microwave.
Please do not operate the microwave (other than short bursts when testing) until the cooling fan is working again.
Otherwise, the magnetron will be destroyed, and that's expensive.
When the magnetron overheats (since the cooling fan is not working) the magnetron thermostat opens up to kill power and protect the magnetron until it cools back down again.
Chances are you have a bad connection, bad relay, or bad component driving the relay on the control circuit board.
If you will scan (at 300dpi if possible) the schematic, and e-mail it to me, along with clear digital photos of both sides of the board, I can probably help you get this fixed.
Feel free to contact me directly (and please remind me of your full model number).
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 12, 2008 | Sanyo EM-W3000W 1000 Watts Microwave Oven
Nov 15, 2008 | Amana ACS3350 Gas Kitchen Range
The oven stops working
if your light also cuts out intermittenly sounds like a loose connection, when heated moves and loses contact, def check wiring
Mar 01, 2008 | Electrolux EOB5630 Ultrafan Electric...
Amana ACS3350 Gas Kitchen Range Logo
99 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
