Question about Sharper Image SA251 Subwoofer
Sharper Image Powered Subwoofer SA-251
Need the hook-up directions and users manual for specs
tech240
  • 169 Answers
SOURCE: subwoofer installation
no jack =no sub audio signal so you would have to get some kind of summing filter. this would sum (mix) the two signals together and extract the sub audio from both channels in order to drive the powered sub woofer you have. could be expensive dont know.
Posted on Apr 25, 2008
  • 3 Answers
SOURCE: need a user manual for Sharper Image MP3 player
This is the direct link to the pdf of the manual http://www.mscustomercare.com/forms/MP3_Camera_IM.pdf
:D
Posted on Apr 06, 2009
SOURCE: Sharper Image Digital 10 x 25 Camera Binocular NEED DEVICE DRIVER
Try This website:
Posted on Sep 11, 2009
  • 5 Answers
SOURCE: I own a Sharper Image eVac. It came without a manual.
I just got a eVac from craigslist today 12-22-09. Fairly new only been run a handfull of times maybe. This came with a manual but theres not much to it. (15 pages) It is supposed to run about 45 min to a charge and its good to let the battery run all the way down before recharging.
I got a half hour runtime after a couple shorter runs that didnt hold charge very long or didnt run becuse there was a brush sensor error.
I believe these types of batteries are best stored for long periods with some charge left on them, otherwise run it down all the way before charging. Manual says battery temp is a factor in how long it takes to charge, im guessing hotter = longer.
Filter is cleanable with water. No detergent. Fan can be air dusted clean too.
These are my findings after 1 day.
This one didnt want to go on carpet very long before stopping with a "brush error". The 5 small screws that hold the black plate with the red brush sensor window that is directly above the brush comes out easily and exposes the brush sensor in the middle which is quite fragile but can be air dusted clean.
A magnet is good to have on hand, the screws are tiny. With the plate off, I also gently aligned one sensor to be slightly more parallel to the other. This also helped reduce the brush error.
Note which side comes out first because it will want to go back in the same way it comes out. If forced in, this is where you can potentially bend the sensors and undo your careful adjustment and cleaning of them, This is the most critical step so take it slow and have plenty of light to see that no sensor gets pushed askew. Its like Operation The Wacky Doctor Game ...in reverse, dont touch the sides of the window to the sensor...bzzzt!
Posted on Dec 22, 2009
SOURCE: Web Support site for a Sharper Image MP3WMA Player
when i drop a song it say no free space but inside empt no any file?.... help me
Posted on Jun 26, 2010
Tip
Sharper Image Jumbo Remote Manual
Sharper Image Jumbo Universal Remote Control Manual
Have you misplaced your Sharper Image Jumbo Universal Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Sharper Image Jumbo Universal Remote Control Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
on Apr 30, 2010 | Televison & Video
Tip
Sharper Image Jumbo Touch Remote Manual
Sharper Image Jumbo Touch Remote Control Manual
Have you misplaced your Sharper Image Jumbo Touch Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Sharper Image Jumbo Touch Remote Control Users Guide?
I hope that helps.
How do i make the Sharper Image SA251 Subwoofer Speaker work what do i use as a line level?
I don't suppose they came with a manual.
http://www.spreadmyad.com/san-diego/merchandise/electronics/8242133-sharper-image-subwoofer-san-diego-25
Line level would (usually) be the LFE signal produced by a multichannel receiver. The speaker level inputs would be from the Front L and R speaker outputs.
Aug 04, 2011 | Sharper Image SA251 Subwoofer
I have a Sharper Image Powered Subwoofer SA251 and it started making a steady harmonic loud sound, turned it of and on and still had the same problem. I also unplugged it and pluged it back in and still...
Subwoofers are basically single mono amps. In your case it could be caused by a faulty electrolytic capacitor or a defective power output device.
If you can't do the job yourself, then any decent electrical service shop should do it for you.
Nov 27, 2017 | Sharper Image SA251 Subwoofer
How many speakers can be hook to a denon avr-889
A lot... 9, but it does not directly amplify as subwoofer.
The user manual, specs and quick start guide are her:
http://www.retrevo.com/support/Denon-AVR-889-Receivers-manual/id/23110dj896/t/2/
Jan 12, 2011 | Denon AVR-889 Receiver
Can u connect another subwoofer to this sub? if so how?
Yes, you can connect another subwoofer too along with this unit, hook RCA pin in this subwoofer coming from amplifier sub out and there is RA jack line-out, anothersubwoofer can be plugged there. It is mentioned in user manual page-7 and previous expert gave you user manual link to download a copy.
Thanks.
Aug 26, 2010 | Sony SA-W305 Subwoofer
Need a user manual for Sharper Image MP3 player
:D
Mar 18, 2009 | Sharper Image 1612911 MP3 Player
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Sharper Image SA251 Subwoofer Logo
379 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
Tom Chichester
Yoav Shilon
Yoav Shilon
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
