Question about Apple iPhone Smartphone
My iphone is blocked and only i see on the screen the pineaple pi
The phone is only showing the pineaple on the screen can u advice
    Problem Solver:
  • 19 Answers
I recommend restoring the old non-hacked firmware. To do this, you will need to put it in Recovery Mode, and then iTunes will ask to restore it.
Instructions:
1. Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
2. Disconnect the USB cable from the iPhone or iPod touch.
3. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
4. Press and hold the Home button while reconnecting USB cable. When you reconnect USB, the device should then power on.
*Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
5. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
6.When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message.
*If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
7. Click OK, and restore device.
Best Regards,
Sam
Was this information helpful? Please rate it!
Posted on Dec 11, 2008
My iphone screen cant touch ?
Hello there,
There are two major reasons that could be causing the touch screen not to be responding. The first is if the phone fell and the sensor board got bad, and the best solution is to replace the sensor board. To replace the sensor board is quite sensitive so i will strongly advice you seek advice from a specialist that can assist you with that. But if you intend to fix it DIY way, then you can ask and i will direct you through the steps.
On the other, it might be the screen is weak and needs calibration. To calibrate the screen. I will advice you go through the user manual for the steps to calibrate the screen of your phone. If you cannot get any response from the screen, i will advice you replace the sensor board. Because calibration requires you to touch the screen and since it is not responding to touch, it will be pointless trying to calibrate.
Thank you for using fixya.
Caseytech
Sep 21, 2011 | Apple iPhone Smartphone
DISABLED OR BLOCKED IPHONEA1303 16GB
You can enable or activate your phone without Restoring or Loosing data.Please follow this procedure...
* Open iTunes.You can check your iTunes version by clicking "iTunes" in the menu bar and then clicking "About iTunes."
If you don't have itunes yet,download the highlighted keys below.
DOWNLOAD ITUNES
* Make sure you have the Blackra1n jailbreak tool on your desktop. download the link below
BLACKRAIN FOR WINDOWS
BLACKRAIN FOR MAC
* Attach your iPhone to a USB port on your computer by using the iPhone data cable. Open the Blackra1n tool and then click in the middle of the box where it says, "Make it Rain." Now perform a hard reboot on your iPhone.
To perform a hard reboot, simultaneously, press the iPhone on/off button located on the top right of your iPhone and the "Select" button centered on the bottom of the iPhone below the screen. Hold down both buttons for approximately 60 seconds. Your screen will go black. Then you will see the apple logo. Then your screen will go black again. After about 60 seconds, you will see the normal iPhone reboot screen, which shows the iTunes logo and a picture of a USB data cable.
Release both buttons and you will see the Blackra1n reset screen which looks like a picture of a teenage boy surrounded by iPhone images. Your iPhone should now be fully functional and no longer disabled.
Good Luck...
Aug 04, 2011 | Apple iPhone (16 GB) Smartphone
My iphone 3Gs is just showing apple monogram on phone it doesn't get off by pressing the switch,
1. Connect your iPhone to iTunes.
2. Hold the Home button and the Power button at the same time for 10 seconds.
3. After exactly 10 seconds, release the Power button but keep holding the Home button for 10 seconds or until iTunes pops up a message saying that it has detected an iPhone in recovery mode. At this point, click OK, then click "Restore" in iTunes.
Feb 07, 2011 | Apple iPhone Smartphone
E63 Cell Phone: my pi code blocke, asked puk code. i input the puk...
Read the Below Link :-
http://www.fixya.com/support/r4274474-unblock_puk_code
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 16, 2010 | Nokia E63 Cell Phone
Cracked iPhone Screen Question
Play/stay safe; return your Apple product back to Apple and have them advice you on the next line of action.
Oct 13, 2017 | Cell Phones
Frozen Apple Logo
if itunes recognizes the phone use the restore option if not you need to perform a force recovery mode. to do this hold power and home screen buttons until the screen resets when it does keep holding the home screen button and plug in the phone to the computer after a few seconds itunes should see a phone in recovery mode and force you to do a restore. if that does not work you might have a hardware problem and will need to go to a store.
Jan 24, 2009 | Apple iPhone Smartphone
Apple iphone shows on screen ''Phone Disabled connect to itune''
did you try to use itunes to restore it to its factory settings?
Nov 12, 2008 | Apple iPhone Smartphone
Disabled iphone
my iphone show me iphone is disabled connect to itune when i connect itune show massege iTune could not connect the iphone
because it is locked with a passcode. i forgat
Aug 22, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
211 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
