Question about Uniden Cordless Phone
Phone rings but can not answer it. it says connecting.
Can not dial out either. when push talk button it says 'connecting'
I did finally resolve the issue and if you would like to know I'd like to offer you my Premium Assistance Plan for 9.89 by email.
Posted on Dec 12, 2008
Please help I can't ring out on my phone
Check for dialing tone by pressing 'Talk On' phone button.
If no tone, check cord at base station and the phone socket is correctly plugged in at both ends using the original cord supplied.
If still no dial tone, check the phone at another phone connection to establish if either the phone or the line is faulty. Address for
Binatone support at this link: http://binatoneglobal.com/support/
Jun 28, 2015 | Binatone Lifestyle 1910 Twin Cordless...
Why can I not answer my phone when it rings?
You must push the green button or "talk" button first.
Sep 03, 2014 | Blu Advance 4.0 A270A 4.2 5MP Camera...
I cannot get a dial tone. I press the talk button to dial out. After 3 quick short beats a message appears in the display window " can't connect ". The phone rings when in coming calls come, but...
Which make and model of phone is it?
Are you pressing the green call button beforew you try to enter the number you are calling?
You should enter the number first, then press 'green'
You wont hear a dial-tone like a landline phone
Feb 23, 2011 | Cell Phones
How do I use the intercom
The "hands free" button would need to be pushed on the phone you are calling. This will make the phone answer when an internal call comes in to that extension. Outside calls will still act normally and ring the phone, then go to voicemail. the downside is that it is difficult for fellow employees to leave you a voicemail since your phone answers to intercom on all internal calls when "hands free" is pressed. If all you are talking about is paging through the phones, pressing 621 will page through the phones with a 3 digit dial plan and 6201 on a 4 digit dial plan.
Oct 27, 2010 | 3Com NBX 2102 IP Phone
Hang up
Button on side is not for answering calls.
PTT or Push To Talk allows you to use your mobile like a walkie talkie. It is dependant on your network operator running the service.
Quote from Pocket lint:
To use the function you must first create a group or individual in your phone menu and send an SMS invitation to those you wish to join. Once your contacts are set up, your phone shows which members have their handsets switched on with push-to-talk enabled, in the same way that instant messaging works online. By pushing a single button on the handset, you are connected with one person or with your group. There is no need to dial numbers, nor do the recipients need to answer calls. You simply push a button and talk. As with a walkie-talkie, anyone in the group hears you almost instantaneously. The talking is one way with only one person able to speak at a time. Unlike walkie-talkies, which are infuriatingly dependent on distance, push-to-talk has no such limitations.
You should be able to disable PTT in the Nokia menu, which is best if your network doesn't support it. Plus you won't keep cutting off calls.
Apr 23, 2009 | Cell Phones
Need to have 3 way conversation on Panasonic KX-T7730
Steps
  1. Call your friend.
  2. Tell them that you will connect your other friend.
  3. Press talk to put your first friend on hold.
  4. Dial your second friend's number.
  5. Press talk again.
  6. Wait for them to answer.
  7. When they have answered, press talk again to bring the first friend back on the line.
  8. You made a three way call!
Option 2
  1. You can press the button that says 'flash' on the phone.
  2. Then dial the number.
  3. Press flash again.
Option 3
  1. While on the phone dial a number and press call/talk.
  2. When the dialed number answers press the options button.
  3. Select merge/join/combine calls or press call/talk again
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Panasonic KX-T7730 Corded Phone
How do i enter the distinctive ring sound for the fax?
click on menu/setup button
then advanced fax setup-ok
answer ring pattern-ok
chose from single, double, double and triple, none-ok
Feb 06, 2009 | Samsung SCX 4521F All-In-One Laser Printer
No dial tone on my handset
when the phone rings just pick up the hand set and answer
if that doesn't work press the talk/answer button and answer
Oct 05, 2017 | GE 21008GE2 Dual-Handset Cordless...
No dial tone when the talk button is pushed
the circut inside is acting up and will need repair, this can happen whenthe batterys are low in the phones and the base does not detect them , also the detect circut coud be bad , and or the automatic pick up circut for the answering machine
Oct 15, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
Vintage phones cannot dial out
Any standard phone should work, even phones made in 1800's should still work on a standard phone line.
I'm not sure what phone you have. The one listed in the question "M7310" is a business system phone and will ONLY work on the Nortel business phone system.
If you have standard home phones, my only suggestion (using the information supplied) is to check if the Tone/Pulse switch is set to tone... even though both should work.
Do you have phone service through a cable line?
May 28, 2008 | NorStar M7310 Phone
Uniden Cordless Phone Logo
155 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
