Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Refridgerator Leaking in the back onto the floor
  • 417 Answers
Unless your fridge has a water supply connected to i.e for an ice maker,t about the only place the water could be coming from the condensate waste pipe.
Inside most fridges near the evaporator (the cold part) is a drain hole so that any condensate can drain out. This flows thru a tube to the back of the fridge. Normally this tube will feed into a tray and will evaporate away naturally.
You could have a look at the back of the fridge to see if this is happening.
Pease remember to rate this solution.
Posted on Dec 11, 2008
253.63712300 sears Hoffman estate fridge has small pools off water that sometimes freeze on back of fridge shelf. Sometimes small trickle of water leaks onto floor. the refridgerator and freezer are s
probably dust, hair, lint plugging the drains.
you have pets?
have it serviced by a professional, or you can disassemble all the drain lines and conduit and pans and clean yourself. good luck
call a PROFESSIONAL
Dec 29, 2014 | Estate Refrigerators
Refridgerator leaking on floor, tray in back full of water
Cracked Plastic Water Line--you have to find & fix
Aug 31, 2014 | Refrigerators
Our Jenn-Air refridgerator is 11 years old and is leaking from the back onto the floor. We looked in the back behind the cardboard panel and saw that the pipes around the( pump ?)located in the lower...
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Aug 11, 2010 | Jenn-Air Refrigerators
Water is leaking onto the inside floor of the fridge. when u used the water dispenser it leaks even more
You have a leaking water tank inside the refrig behind the crispers . The tank ( now plastic hoses ) is easily replaceable . Called a water resevoir technically .
May 12, 2010 | Refrigerators
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Aug 10, 2009 | Whirlpool Refrigerators
Leaking inside refridgerator
not shure as to the design of that brand, but it is usually caused from a bloked up drain
Oct 25, 2008 | GALAXY Microsystems 63702 Top Freezer...
Freezer leaking on Ge Profile
The drain is frozen over and water cannot escape when it defrosts. You will need to remove the back panel inside the freezer and run some hot water down the drain until it has thawed. Hope this helps
Sep 24, 2008 | Refrigerators
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
50 people viewed this question
Dan Webster
Dan Webster
Sal De
