Question about Toshiba DP-85F Fax
Toshiba DP85F states paper jam - but there isn't one
I have a Toshiba DP85F that is saying there is a paper jam but there isn't one. It will not allow faxes to be sent out but we can receiving incoming ones. Please let me know how to fix this problem. Thank you!
SOURCE: Incoming Faxes won't print, states failed pickup and pages in memory
take all the paper out of the paper tray, wait a few seconds and put it back in. Capt'n Andy
Posted on Mar 28, 2007
Guru Guy
  • 95 Answers
SOURCE: paper jam inside
You may also have a problem with the paper feed (clutch, dirty feed/pick up tires) section, or even a dirty sensor as Jay mentioned. A sensor in modern office equipment is generally a photo sensor, which means it shoots light from one side to be detected on the other side of it. If it's dirty, it will give you a flase reading. Try cleaning the tires that pick up the paer from the tray (don't force them down if they won't rotate easily) with mild soap and water on a rag, and also try fresh paper. Sometimes if paper has been sitting for a while, or in damp conditions, it will pick up moisture and give you paper feed problems... which is what it sounds like you are having. Sounds like the paper may need even be making it to the sensor in the 1st place if it on comes out of the tray 1/2 an inch. Good luck
Posted on Dec 27, 2007
SOURCE: Brother Intellifax 2820 JAMMED
Clean the rollers, but also check the drum/toner. at the front there is a peice that breaks on occasion that will cause a jam.
Posted on Dec 17, 2008
  • 149 Answers
SOURCE: Paper jam in Panasonic KX-
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
Posted on Jul 07, 2009
  • 125 Answers
SOURCE: we have a Toshiba fax
Just press the stop key twice.
Posted on Aug 11, 2010
I have a Toshiba estudio162 and its saying clear paper jam. I opened the tray, removed the crumbled paper and closed it.Its still saying Clear Paper Jam. How do i make the red light stop flashing?
The sensor acturator that the paper hits might be broken or out of place so the copier thinks there is paper there when there is not or there might be a small piece of paper that stuck in there holding the sensor acturator up.
Nov 17, 2015 | Toshiba Office Equipment & Supplies
Paper jam in Toshiba Tec
Check length of label and type of sensor used and check the sensors
Apr 02, 2013 | Toshiba TEC B-472 Thermal Label Printer
Printer is in alarm mode stating a paper jam when there isn't one?????
Even though u cant see a jam there there is exactly a jam inside
U believe it or not thats why paper jam
Look for the paper detection sensor below the carriage
use ur common sense
I cant say exactly it is detect sensor it may be some other sensor related to gear wheel set
but most of the cases paper jam occurs due to malfunction of paper detect sensor
If u find it use a thin tool to see it is working properly
otherwise give it to someone know how to repair & pay a reasonable price
Sep 17, 2012 | Canon PIXMA MP280 Photo Inkjet All-in-One...
I have a Toshiba Dp85F Fax machine and need to replace the toner cartridge...I do not know what model number I need to replace it with. Please advise
Ink, Toner & Accessories for DP-85F Printers, Copiers & Faxes Select from the list below Compatible or Original ink and toner cartridges that work with your DP-85F.
TOSHIBA TK-18 Compatible Black Laser Cartridge, TK-18
  • - Condition: Compatible
  • - Page Yield: 6000
  • - Color: Black
  • - Printer Technology: Laser Cartridge
  • - Item Number: TK18-70
- OEM Part#: TK-18, TK18
Item #: TK18-70
MSRP: $114.99
Price: $38.99
Toshiba DK-18 DP-80/DP-85 Drum Unit
  • - Page Yield: 20000
  • - Color: Black item-color-black.gif
  • - Printer Technology: Drum Unit
  • - Item Number: DK18-70
- OEM Part#: DK18, DK-18
Item #: DK18-70
MSRP: $114.99
Price: $39.99
Toshiba DP85F Toner Cartridge, Black
Toshiba TK18 Toner Cartridge, Toshiba TK-18 Fax Toner
Nov 29, 2010 | Toshiba DP-85F Fax
Toshiba 2060 copier shows paper jam at right side but I can not find any paper jam at all any other thing will cause to show paper jam? thanks mike
sometimes it does not sense that you opened the door that it says the jam was in. open and close the jam areas to see if it clears. if not restart the copier
May 17, 2010 | Toshiba 2060 Copier
Everytime I hit copy the error says paper, there isn`t any jam, I have tried turning it off, it still says paper jam. Help
There must be some piece of paper or other small material upstructing the path the paper takes and must be thouroghly cleaned to acheive maximum result.
Feb 11, 2010 | HP 190 Copier
Paper jam
My dp85f, jams also.
The reason is, that the "fuser and pressure roller" unit is clamping an thus, the gearwheel driving this unit has been damaged.
Anyone knows, where to get spare parts?
Jun 05, 2009 | Toshiba DP-85F Fax
Paper jam
It seems youre facing an issue with the scanner consumables - pad and pick roller. It is a goos idea to replace both of them at the same time. Also check the feed and exit rollers (the two rollers on the upper part of the scanner) as the get sticky causing problems like the one you describe.
Sep 27, 2017 | Fujitsu ScanPartner fi-5120C Pass-Through...
102 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
