Question about Bose Acoustimass 15 System
Bose Acoustimass 15 woofer, Replacement of RCA female connector
I need to replace one of my speakers RCA female connector on my Acoustimass 15 subwoofer. But I can't disassemble the case to get to the RCA female connector! How do you remove the part of the case that contains the RCA connector?
Thanks .
David
  • Anonymous Mar 22, 2014
    my bose speaker module not working
    Problem Solver:
  • 4 Answers
On the end opposite of the jacks (top of the sub opposite connectors) in the exact middle, there is a ratchet looking device (flashlight and magnifying glass reveal the little culprit) with a very small flat screw driver rotate the piece CCW until a small tab is protruding from the middle. Pu the palm of your hand on the plastic case and give it a small whack (in the direction of the jacks) it will move about a 1.2 inch. Lift straight up and the case will come off and reveal the connectors. Trust me, get a flashlight and magnifying glass and peer through the small crack between the cover and the box, you will see the little notch (encoder looking) rotating wheel
Posted on Dec 15, 2008
I found the solution in your forum. Thanks.
David
Posted on Dec 12, 2008
Need new system input cable for acoustimass 10
I've made a diagram of my serial cable. You can easily make one with some speaker wire and a 15-pin d-type female serial connector. Solder the wires as shown in the diagram.
Jan 26, 2010 | Bose Acoustimass 10 III System
Where can I buy a new system input cable? I have searched everywhere online but have yet to call Bose to see where I can get one. Does anyone know? Help!
You can make one, just need a female 15-pin d-type connector and a lot of speaker wire. Solder the wire to the connector as shown below.
Nov 19, 2009 | Bose Acoustimass 15 Series II System
Gap contact
You can try and use another cable. I've read before that changing the cable can fix that problem. If you know how to solder you can make your own cable. All you need is a female 15-pin d-type connector and some speaker wire. Here's a diagram of the connections:
Sep 28, 2009 | Bose Acoustimass 10 II System
Bose audio input receiver cable 15 pin
You can buy it on ebay but it's cheaper just to make one. If you can solder, all you need is a female 15-pin d-type connector and a bunch of speaker wire. Here is a diagram of the connections.
Jun 24, 2009 | Bose Acoustimass 10 III System
How to make a 15 pin female sound in cable
Ya, here is a diagram I made of my Acoustimass 10 IV input cable. All you need is a female 15-pin d-type connector and a bunch of speaker cable (also one RCA connector for sub connection). Here's my diagram:
Mar 10, 2009 | Bose Acoustimass 10 III System
My sound in cable was missplase and can i make it my self and pls any body can send me the cable structre. pls...........
Here's a diagram of the 15-pin serial input cable that came with my Acoustimass 10 IV system. You just need a 15-pin female d-type connector, one RCA connector and a lot of speaker wire. Here's my diagram:
Bose acousticmass 15 sub-woofer making a noise
The sub contains the amp for the other speakers. But it sounds like the amp has a seriously damaged section and will probably have to be serviced by Bose.
Jun 24, 2008 | Bose Acoustimass 15 System
Bose AM-500 Acoustimass Bass module hookup to new Sony STR-DG910 Receiver
it need it own sub out speaicl done so bye bose steyem crossovers wont work right in your set up nee dto upgrade the sub try mtx
Feb 04, 2008 | Audio Players & Recorders
Bose Acoustimass 15 System Logo
1,330 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
