I have a savin 9935dpe b&W multifunction copier. It states an error code of: "functional problem SC321-00" and to poweroff the machine or call for assistance. I powered off the copier and turned it back on with no resolution. Any one have answer on how to fix it? The only research that i could come up with was a "no image" issue.
  • 2 more comments
  • pancholi Dec 11, 2008
    cleaned the toner and the unit adjacent to it (long bright green tube looking thing) had some toner streaks on it. Now I get a sc320-00 error message. any ideas?
  • pancholi Dec 12, 2008
    We tried that with great hope. Just before we tried, we called in the copy machine guy. He says we need a new laser motor. Any idea how much this costs as a part and how difficult it is to replace?
  • elgieke Mar 31, 2009
    error SC320. How do you replace the motor and who sells it?
    guy@robotics-design.com. Thank you.
  • Anonymous May 10, 2009
    my 9955dp first said functional error sc121-00...I disconnected the attachment from the copier that holds the papers and now it says sc320-00...please help
    email me Shamszereh@aol.com
    President:
  • Office Equip... Master
  • 990 Answers
The laser unit can't write, pull out laser unit to clean out (do not open black box ) laser unit located at left down corner of the toner unit. after clean if still not work, change laser unit.
Posted on Dec 11, 2008
  • Everett Lin Dec 12, 2008
    sc320 mean the laser motor defect , try to reset steps as follow;
    1, press clear mode key on upper right panel.
    2, enter 107.
    3, prss and hold clear stop key for 3-5second until screen show out SPmode.
    4, turn power off and on(power switch on lefthand sideof the machine
User codes.
that's due to having too many users..you'll need to delete some folks to make this work...maxing out the user codes will freeze the unit..
Apr 25, 2008 | Savin 9935DP Laser Printer
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
MY SAVIN 4700WD WIDE FORMAP COPIER/PRINTER/SCANNER MACHINE COMES UP WITH AN ERROR CODE "SC35303". tHE ERROR CODE ISSUE HAS PROGRESSIVLY COME UP MORE OFTEN. CAN I DO ANYTHING OR DO I NEED A...
The error code is from the image density sensor, it may be dirty or not able to read the drum surface correctly. If it hasn't been serviced in a while a preventive maintenance will be needed. What is the meter reading on the unit at this time? Hope this helps.
Jul 12, 2011 | Savin Office Equipment & Supplies
Savin Copier 2020, IP 192.168.2.100 functional error SC672
yes a 672 is an address book error. do you have scanner feature on this machine?. it may be bad. you may need a tech to come remove the option. turn the machine on and use it as a copier. then reinstall the option and see if the error returns. it could be a static build up or the option is bad.
Dec 26, 2009 | Savin Office Equipment & Supplies
Savin 9935 dpe not working
try to ask your question to the problem section you will have more chance
Nov 13, 2009 | Office Equipment & Supplies
Savin error code E-547 error code?
Fusing unit trouble.Clean the thermofuse and thermistors,check the heater lamp.After ,enter in the service mode turn the power switch OFF unplugged the crd.Wait 10 sec. plugg the cords and turn ON the machine.I think the Savin is based the Ricoh copiers machine.The service enter code is : Press the toral clear key - 1 - 0 - 7 -hold down the C key more 3 sec.
Aug 17, 2009 | Savin Office Equipment & Supplies
I have a Savin 9922DP red wrench and code SC 546
Parts availability ended for this machine Jan of 07, now is a good time just to chuck it.
Jun 02, 2009 | Ricoh Aficio 450 Copier
Savin 9935DPE document feeder maintenance
GO ONLINE TO SAVIN: TYPE THE FOLLOWING INFORMATION:
WWW.SAVIN.COM/SERVICE_MANAUL
/TECH_SUPPORT
/SERIVES
/HELP?
CALL SAVIN ASK TECHICAL SUPPORT, ASK FOR A TECHICAIN THAT REPAIRS OR FIXS THAT TYPE OF EQUIPMENT AND EXPLAIN THE PROBLEM AND SEE IF HE HAS ANY IDEAS YOU CAN TRY BEFORE YOU GO OUT AND SPEND ANY TYPE OF MONEY ON THAT PART.
ROD
May 12, 2009 | Office Equipment & Supplies
Copier reset procedure.
hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;
http://savin.custhelp.com/cgi-bin/savin.cfg/php/enduser/std_adp.php?p_faqid=7081&p_created=1102093227&p_sid=9TrLDc-i&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQzNiZwX3Byb2RzPTI1MTAsMjUxNCZwX2NhdHM9MCZwX3B2PTIuMjUxNCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZXJyb3IgY29kZQ**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Mar 07, 2008 | Computers & Internet
250 people viewed this question
k24674
jasbo
jasbo
