Question about Onkyo TX-DS838 Receiver
TX DS838 WHEN TURNINGVOLUME DOWN UNIT MAKES A POP SOUND
AFTER DOWNING A REPAIR ON THE SUROUND OUTPUT AMPS UNIT CAME UP WITH A NEW PROBLEM WHEN TURNING VOLUME DOWN AND COMING TO MIN VOLUME UNIT MAKES A POP SOUND AND GOES TO PROTECTION FOR APROX 3 SECONDS THEN COMES BACK TO NORMAL ,IT ONLY DOES IT ON SUROUND SOUND A/B FRONT IS FINE.
    Brigadier General:
  • 8,546 Answers
Sight unseen my money says the new problem is a direct result of the 'repair' to the channels that are giving you problems now. You didn't elaborate on what it was you were trying to fix in the first place. Backtrack your steps and undo what you can to see if the bug changes.
Posted on Apr 30, 2009
How can I hook up BIC F12 subwoofer to Onkyo TX-DS838 receiver? Will the receiver power the subwoofer and other speakers?
Get a RCA cable and connect from your amp where it said Sub Woofer in the Pre Out box in the back of the amplifier top left hand side and take it to the "Sub In" located in the back of your Sub woofer bottom right hand (White round connector).
Good Luck!
Aug 06, 2014 | Onkyo TX-DS838 Receiver
I can't get all four speaker to play simultaneously, it either speaker A or Speaker B, but not both at same time, what's up with that?
It could be the out-put mode, in the settings on your unit, you can change modes to surround sound, and other veriations.
Feb 09, 2014 | Onkyo TX-DS838 Receiver
Onkyo TX-DS838 Receiver. Mine just sparked smoked
Not worth repairing until the root cause of the failure is proven.
The reason being is that you can have it happen again if caused by any of the devices attached to it, such as inefficient speakers.
Jun 06, 2010 | Onkyo TX-DS838 Receiver
TX-DS838 shows protect and then shuts down
yes , Im afraid you have a chip gone , If you open the unit up you'll see a alloy heatsink with 4 to 8 large chips screwed to it , These are the amp drivers , In between these chips you see a smaller one (that is the protect chip),You see when things get a little hot this chip is designed to break sooner that the more expensive main amp chips , In the past ive unsoldered these and still found the amp driver bust too ,dont worry though , maplins or even farnell(cpc) on the web will supply these for less than a tenner..If you wanna test my fix then just unsolder the littlest chip on the main heatsink and it should start to work again but with NO protection(unplug it first before taking it to bits)
Jun 06, 2009 | Onkyo TX-DS838 Receiver
Onkyo services manual
Go to http://www.retrevo.com/, regsiter for free and search for Onkyo TX-DS838. It will prompt you to download the manual (3.3MB).
Feb 02, 2009 | Onkyo TX-DS838 Receiver
Onkyo TX-DS838 Issues
The problem here is that the output amplifier section has a problem. This is detected internally and the system shuts down in a "protect" mode. The output section really only kicks in when you attempt to bring up the volume. Another possibility is a problem in the "front end" where DC current is being passed to the amp section. Without takeing measurements, it is difficult to determine the exact cause. This should be a relatively stright-forward repair for a service shop and should cost about $20-$40 in parts plus the local labor charge.
Dan
Dec 23, 2007 | Onkyo TX-DS838 Receiver
Sound cutting in and out
Same problem here....took it to authorized onkyo repair and cost was $700+ for new board. Got the 707 from crutchfield instead.
Nov 09, 2007 | Onkyo TX-DS838 Receiver
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Jun 04, 2006 | Onkyo TX-SR601 Receiver
Onkyo TX-DS838 Receiver Logo
122 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Dennis McCollum
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
