Question about Basf 938 DA-40 ADAT 16Bit format / Album Box ADAT (S-VHS) Tape
"prot" error message on Alesis ADAT 16 bit recorder
I forgot to mention the model and brand of the machine,. to repeat, I'm getting the "prot" error message which I assume means the tape is write protected, even though the knockout tab which was removed is covered by tape. I even tried a brand new SVHS video tape that has never had the tab removed, same result.
I heated the mechanical sensor switch with a hair dryer. Probably caused a contact point to expand just enough to close the circuit.
Posted on Dec 12, 2008
How to hook up the wires of Mackie CR-1604 mixer, to Alesis ADAT xt20 recorder
If memory serves correct you have rca and outs, 8 each. Using rca to 1/4" cords work the best. Connect each of your cords from the "in" on the alesis to the channel access 1 through 8 I believe to the first click. Run the "outs" from your alesis to channels 9 through 16. Use 9 through 16 as playback and 1 through 8 for instruments. This is one good way of doing it with our limited gear. Good luck!
Jun 01, 2014 | Mackie Cr 1604 16 Channel Mixer
When I try to make a cd from the playlist it will not record(write)! Also I can not get the input mode to switch from analog to digital. When I press the input button the light blinks but stays in the...
There must be some error message when you try to write a CD. What happens when you press the 'create CD' button?
Regarding the other issue, you must have a valid digital input connected for the Alesis to lock on to. PCM digital at one of the sample rates specified on the front panel. If you try to feed it a non-PCM digital signal, such as Dolby Stereo, some other Home Theatre format, or other, it will not accept it. Must be 16-bit or 24-bit, 44.1 to 96kHz as per front panel.
Jul 29, 2011 | Alesis MasterLink ML-9600
Alesis ADAT HD24 Fireport I tried to read the hd24 drive in my pc and now it is corrupted. What can I do to recover the data? Thanks
Try a new or different OS
Use a program called studio
Use an USB cable to IDE and power, download hd24tools and recover your racks
Oct 20, 2010 | Alesis ADAT HD24 Fireport (ALADHDFIR)
Sr 16....Hissing sound on all selections. Is there a repare center and what is the charge
You didn't mention your location so here is two links for you: also: Your closest listed dealer should be able to give you the service you need.
Aug 26, 2010 | Alesis Sr 16 Stereo Drum Machine
Can i hook the alesis drum machine up to my computer and use it to make beats?
Are you talking about recording the beats from the Alesis or are you talking about designing beats on your computer to load into the Alesis? If it's the latter, try this link: This link might also be useful: Please let me know how you make out.
Nov 25, 2009 | Alesis Sr 16 Stereo Drum Machine
I cannot get my Alesis ADAT HD24 to work on Windows 7. The Vista drivers do not work and I cannot find anything that will work.
There are some fundamental driver support differences between windows 7 and vista. It doesn't appear that Alesis has release a windows 7 driver for their fireport and im not sure if they will.
Nov 22, 2009 | Alesis EC2 ADAT HD24 AnaloAlesis ADAT HD24...
Backup user patterns for Alesis SR16 drum machine to pc
Some harddisk recording/PC based recording programs recognize "Midi Bulk Dump"
I use Alesis Data Disc for all midi backup from synths and drum machine. This is a one unit rack module you can get for som few dollars.. ;)
Alternative check out with "midi" as search word.
Feb 18, 2009 | Alesis 16 Bit Stereo Drum Machine System
Alesis lx20 type 2
send it to be serviced.
My adat lx20 keeps showing a error 2 and spits the tape back out, i chek the tape in my other adats and its fine. any suggestions?
Dec 24, 2007 | Quantegy ADAT: ADAT: 60 Minutes ADAT...
Basf 938 DA-40 ADAT 16Bit format / Album Box ADAT (S-VHS) Tape Logo
206 people viewed this question
Top Basf Electronics - Others Experts
Are you a Basf Electronics - Other Expert? Answer questions, earn points and help others
