i only have one 220 line coming out of my breaker box, which goes to my well pump. can i connect my new mr. slim 22000 btu heat pump to that same line?
thank you for your consideration.
Let me try to send you to a quick fast electrical course on wiring size vrs amp draw it can carry before it burns into. The breaker box can send out the rated amps the wire comming into the box its sized for. (example. #3 can carry 10 amps) then it is distributed thru breaker thru the wires to the loads amp draw. depends on the maxium rated amp draw of the load, the wire can carry a certain amount of heat or amps. Ceck the max. rated amps or heat draw it can carry to size your wires & breaker,! thank you very much!
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a...
(More)
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a forced air system. Recommendations from heating contractors include Trane, SlantFin and Weil-McLain. Are these the best choices?
Air conditioner is cooling a control room built on the centre of 2 brick manufacturing kilns with...
(More)
Air conditioner is cooling a control room built on the centre of 2 brick manufacturing kilns with excessive temps. Room size is 6m by 6m and electrical contactors are also mounted in this room. The sizeof LG aircon used is 26000 Btu. Is the size big enough, what is your advise?
