Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic PT-47wx49 47in
Replaced two Convergence IC in my Panasonic TV. it looks alot better then before, doesn't have that 3d effect anymore but can't get the color blue to aligned tho. I Did the setup menu "convergence 2", the top right cross hair blue aligned but the rest wouldn't. Could it be somthing else i need to look at?. Is the CIC is the only thing in my tv that converg colors?. Please Help.
    New Friend:
  • 13 Answers
One of the resistors in the circuit connected to one of the ic's has burned out or changed value due to heat caused by short in previous ic before it was changed.
Posted on May 10, 2007
I have a Panasonic pt-53x42 projection tv. I believe i have a convergence problem. I have double lines running along bottom of screen..Any help please...
Yes,this problems is 100% convergence problems,it dead.The tv have colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Blue convergence + wont move right or lift, the Blue will move up and down.
try the hard reset method , that is, unplug all the cables and wait for half an hour , and replug all cables and try ......hope this will help you
Jun 20, 2008 | Panasonic PT-51HX41 51" Rear Projection...
I have a convergence problem in the bottom of the lower left quadrant pf the screen. It is like a parabolic semi circle that is at the very bottom edge of the screen. The front screen isn't damaged at...
Tv 100% have a convergence problems,if any parts of the tv picture colors lines R,G,B are mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board the 2 STK ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Yellow band on bottom of PT. Double image on news scroller at bottom of PT. Have tried convergence - no luck. Green will not align and will not come down.
Ur tv have any colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures.Ur tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.The parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 13, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic pt-51hx41e
This is a convergence output IC problem. convergence board (main Board) would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 26, 2009 | JVC AV-48WP74 48" Rear Projection...
Picture double colored
Picture double colored or 3D looks is due to failure of convergence out ICs in TV and need to be replaced.
If you are not comfortable with TV repair then call local TV tech.
Jul 25, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Screen looks like 3d
While Ginko's solution is correct, it is possible that the problem is simply poor solder connections at the ICs. If you can solder, try resoldering the pins on the ICs first. That may resolve the problem. Please note that there are potentially dangerous high voltages present even when the set is unplugged.
Also, If you post the model number, we can provide you with the part numbers etc.
Dan
Feb 24, 2009 | Hitachi Televison & Video
PT-53WX52
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Dec 02, 2007 | Panasonic PT-53WX52 53" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
3d effect
Hello, please replace convergence output IC`s and R7048 (2,2R). If you need more info please contact me at LIVE Expert Assistance. Best regards, Arpi
Jul 01, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
141 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
