Question about Asrock K7VM2 Motherboard
Wish to increase cpu spped and memory
I have a k7vm2 mother board i wish to know the best prosessor for it and also is it just a matter of changeing them or would i need to reinstall all windows #programme.
and also how do i make it faster for me to put vista on it .???
  • thefuncouple Dec 12, 2008
    thanks for all the info you have been a great help will use the site again . and have a nice xmas and a happy new year one and all.
    President:
  • 2,351 Answers
Hi thefuncouple, here is the ASRock link for supported CPU's:
http://www.asrock.com/mb/cpu.asp?Model=K7VM2&s=462
The Athlon XP 2600+ CPU is the highest CPU this board can support. (It will be hard to find one).
Main web site for the K7VM2: http://www.asrock.com/mb/download.asp?Model=K7VM2
Honestly, ASRock does not have drivers for Vista. Some of the drivers listed for XP may work with Vista. Your best chance is to download & run Windows Vista Upgrade Advisor 1.0
(Before installing Vista in to your system).
http://www.microsoft.com/downloads/details.aspx?FamilyID=42b5ac83-c24f-4863-a389-3ffc194924f8&DisplayLang=en
Vista, any version needs at least 1GB of memory. Two GB is recommended. After running Upgrade Advisor you will know if your ASRock motherboard can handle Vista. You should be able to upgrade to Vista (Over-writing XP) but only if your system passes the Upgrade Advisor.
Your best bet would be to buy a new system with Vista on it. Your ASRock board is just too old for Vista. You'll save money upgrading to a more supportive PC.
Good luck thefuncouple!
Vista is not for everyone, many users end up going back to XP.
Thank you for using fixya.
Mike
Posted on Dec 11, 2008
What is the best processor to get for upgrade?
GET THE PROSESSOR ID# OFF CPU--Go to cpuworld.com get to your CPU Family and Choose by #, observing WATTS
Jan 31, 2014 | Dell Precision 390 Workstation Tower,...
Best supported processor for gaming?
For CPU upgrade it is hard to say without more information. These machines can have several different mother boards. Take a look at the mother board and find a Model number. With what you gave it looks like it runs a Pentium 4 641.
However, when systems get slow they may need a clean out. I use CCleaner to clean excess files and the registry out. But make sure to have a backup.
Other then this speed for gaming depends on what type of CPU, memory (RAM), motherboard, etc. that you have. There are so many products on the market, so exact details are needed to see what is slowing you down. Also, if frame rate, FPS, is an issue then, Do you have a video card that is not integrated on the motherboard?
Dec 29, 2013 | eMachines T5088 Motherboard Replacement...
Mother board appears to be getting to hot new ram modules installed recently running windows 7 with an ATA hard drive WD800 Number on mother board PB2390J9VSJXZI appears to have 3 ram modules...
Hi Please check the Processes From Task Manager window - Check how much is the Memory Usage - There will be Lot of Programs running - Check the one which is taking the Max and Right click on that Program and End Process - Remove the Program which is causing the Problem
- Better Run the Registry Cleaner tool and clean the Registry - Also check Run the PC Virus Check and remove the Viruses - Increase the Total Paging File Size by increasing the Virtual Memory .
http://www.registry-cleaner.net/ http://www.malwarebytes.org/
Best regards Tejodhar
Sep 18, 2011 | HP Computers & Internet
CPU runs at 100% a lot of the time, mainly when opening internet files, freezing the system and causing the fan to kick in for long periods. I have removed as many programmes as possible and increased my...
It can be possible that the CPU and the mother board has some conflicts .If all unwanted programs were taken off , the OS was installed fresh, an antivirus was installed and the drivers installed then , the system must run well. If not cross check the CPU and the board as your memory is new. Does the CPU/board support the memory.
You have not mentioned make/model
Sep 30, 2010 | Compaq Computers & Internet
Is the asrock k7vm2 motherboard easily replace by the k7vm4 asrock. my k7vm2 is dead and replacements are not easy to come by. I'm just looking for a new mother board to hook up to my hard drive and not...
You may be able to just swap out the motherboard for a K7VM4 motherboard but some of the specs are different like the chipset and graphics etc.
K7VM4 specs as follows >>>>
  1. Socket A(462) for AMD processor
  2. VIA® KM400 Chipset
  • ASRock U-COP
  • Hybrid Booster - a safe overclocking feature
  • FSB 333/266/200, DDR 333/266/200
  • Integrated UniChrome 3D Graphic.
  • 1 slot for AGP 8X/4X 1.5V
  • ASROCK I/O - default 4 ready-to-use USB2.0 ports on rear panel, default Game/MIDI port.
  • ATA 133 supported
  • On board default 10/100 LAN and 5.1-Ch Audio.
K7VM2 specs as follows >>>>>>>
  2. VIA® KM266 Chipset
  • ASRock U-COP
  • DDR 266/200
  • Integrated ProSavarage8 3DGraphic.
  • 1 slot for AGP 4X/2X universal.
  • Supports both DDR and SDRAM memory modules to provide you best flexibility and save your cost.
  • ATA 133 supported
  • On board default 10/100LAN and Audio.
As you can see the graphics and chipsets are different although the processor sockets are the same.
This could cause problems if you are going to plug the hard drive to another board but saying that is is possibe and has been done before.
This is a chance you take when you swap out a board for a different motherboard although i suspect that the transition should go smoothly.
A fairly old motherboard like K7VM4 or K7VM2 will not cost that much these days. You will find both motherboards for sale on eBay.
Regards.
May 27, 2010 | Asrock K7VM2 Motherboard
What must I do into the bios To changes the cpu
NOTHING THE MOTHER BOARD AUTOMATICALLY DETECTS CPU SPEED
Apr 17, 2010 | ASUS A7N8X-X Motherboard
Need to increase the ram on the VGA Card
My friend you can add RAM on your VGA by purchasing another Higher Video card  RAM. you can buy 512mb (265 - 512 bit) VGA Card to increase your VGA RAM.
Jun 18, 2009 | ASUS P4P800-X Motherboard
Replaced CPU fan, now it won't boot up.
No beep codes means the motherboard is dead .
sorry David for your loss
Jul 30, 2008 | Asrock K7VM2 Motherboard
Prosessors
its an old model . the compan gives processor supprto to mobile celeron and mobile p3 to that laptop . the front siide bus speed of mother board is 100 mhz only which is designed for earlier cpus
it can support cpu speed upto 1 Ghz so a p4 must be unthinkble to that lappy
Dec 04, 2007 | Computers & Internet
Asrock K7VM2 Motherboard Logo
228 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
