Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Green tint on Samsung Television
I do not know the model but it has a persistent green tinge and the colours are slightly off. I have replaced the bulb but it still does it. Set is 50 inches and is rear projection. DLP I think.
  • 59 Answers
Hi sbatsch,
Not to worry - this problem is very common with projection TVs and is easily fixed:
The reason for the green shadows (and the resulting wrong colors) is that the three color tubes (red, green, and blue - the three colors of light that combine to form all the other colors) are not lined up exactly - this lining up is known as "convergence." You can fix convergence automatically or, if it doesn't work to your satisfaction, manually. Here's how:
1) Press MENU.
2) Go down to CONVERGENCE (using the up and down arrows)
3) Select it (usually with the left or right arrow)
4) Go down to AUTO and select it - the process should take about a minute.
If this doesn't work, then try manually:
2) CONVERGENCE (as above)
3) Select MANUAL
4) Using the number keys, SELECT, and the arrow keys, adjust the alignment of the different color crosses - the goal is to make them appear white (meaning that the red, blue, and green are exactly aligned on top of one another).
Here's a link to the JVC user manual that will explain the manual convergence adjustment in more detail.
I hope this helps - please let me know if I can be of any further assistance.
Posted on Dec 11, 2008
Green tinge on imedia s1800
This is generally caused when your display cable isn't plugged in all the way or has a broken pin. Make sure the cable is seated at both ends, if it still is bad remove the cable and check for bent or missing pins, if yes replace the cable.
Nov 08, 2011 | Acer Computers & Internet
The screen has a permenant green tinge which dominates all other colours. If watching football the grass insted of being bright grass colour green is more of a dull drab green
It could be the tint settings on your TV. Check your TV's settings menu for color/tint options. If you can't find it, break out the manual and look in the index for tint or color, then locate the page and it'll tell you how to get there.
Make sure the tint slider is in the middle, 0 or 50%, depending on your TV.
Best of luck.
Remember to rate my solutions! If you have time, drop a testimonial too - they really make my day. :)
Mar 29, 2010 | Sony BRAVIA KDL52XBR2 Television
Samsung Tantus (SP-43J8PF) Has Green Tinge - Easy fix?
You may try to get into the service menu and adjust screens/drives level(procedure below). But first turn the color off completely and adjust you brightness to mid-range, what you`ll want to do is a grey raster or bring it as black and white as you can while adjusting the red/green /blue guns or tubes. Also get a piece of paper and pen because you`ll want to record the original values of the items you may change. You want to go into the adjustment menu. Hope this will help Good luck
In quick sequence on the remote press:
MUTE - 1 - 8 - 2 - POWER buttons.
The TV will turn On with the Service Menu displayed.
Select the function and use the VOL+ button to enter.
Save settings and exit by pushing MUTE twice then POWER .
Nov 19, 2009 | Samsung PLH403W 40" Rear Projection...
Green tint
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
thank u
rate me
May 29, 2009 | Sanyo DP42746 42 in. Plasma Television
Bluish green tint to television picture
Find out what board and circuit is responsible for the color and you have your answer.
Mar 12, 2017 | Panasonic PT-52LCX66 Projection Television
Colour spots
turn your color all the way down and observe the black and white, contrast and grays . should be crisp. if sorted looks still like blurry grays with little contrast...... your problem lies in the video processing circuit.
Oct 23, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
VIdeo Problems with television.
If these are diagonal green lines then one of two things is wrong. You either have a bad video driver transistor for the green on the CRT board or the IC the controls the CRT (jungle IC) is bad. The possibilty of a bad green gun in the CRT is there as well.
May 24, 2008 | Televison & Video
Green tint to everything on my Samsung HDTV Digital 1080i television
I have the same problem here on this Samsung 40" LCD. its a 2007 model. everything was fine until recently. I had to reset my digital cable box. now the picture has the green tint. its ruined what was a nice tv, and it won't go away.
Mar 11, 2008 | JVC HD-56G886 56" Rear Projection HDTV
most atimes if i adjust the screen adjuster on the voltage multiplier i always observe that the screengoes green(lg 21" television),and if i readjust the screen,the greengoes off.Rubberhead,try adjusting the sceenknob on your voltage multiplier(line transformer).
Feb 26, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
924 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
