Question about Garmin Nuvi 350 Car GPS Receiver
The tip of the car charger is missing and so is the fuse. how do I go about fixing it or do I just order a new car charger. My cousin has the same garmin and his charger did the same thing.
  • Garmin Master
  • 2,130 Answers
It's kind of tough to find those parts by themselves. Your best bet is to just order a new charger and make sure the end is on tight this time. The part that scres on is usually meta and knurled, so you could use a pair of plyers to tighten it.
- Jim
SHARCNET-USA
Posted on Dec 11, 2008
I Cant turn it on.
The car charger input is +12VDC and +5VDC at the plug that plugs into the Nuvi. Make sure your car +12V outlet is working. Try another device in the outlet. Check that the fuse in the charger tip isn't blown. The tip unscrews. Be careful, the charger tip, fuse and spring can shoot out. Cup your hand over the end while you use the other hand to slowly unscrew the charger tip. You can have a bad charger plug or cradle. Also, try pressing the reset button, underneath of the flip up antenna assembly. SHARCNET USA Out of Warranty GPS Consumer Electronics Repair Center
Sep 19, 2015 | Garmin Nuvi 660 GPS Receiver
The fuse is fine, but when i put the car charger in it still doesnt work my car is a 2002 pontiac bonneville
Most car chargers have a fuse in the part that plugs in. you can unscrew the tip and check the fuse. But first plug in another charger and see if it works.
Feb 28, 2011 | Pontiac Bonneville Cars & Trucks
My garmin goes at usb mode when i put the car charger on it.how can i fix it
the car charger plug has a fuse in it check the fuse
To do that ...Unscrew the silver tip of plug.... be careful its spring loaded
check the 3A fuse
Oct 25, 2010 | Garmin nuvi 260W GPS Receiver
Unit will not power on. Light on the charger does
if the light is not on, on the charger, check the fuse in the end of the car charger...the tip unscrews and there is a tiny fuse just under the tip.
if thats ok, check the fuse to the outlet you are using in your car.
if the light comes on the charger and it still wont charge, let me know and i can help you fix it.
the 3140 are known for there bad power ports.
bill
Dec 28, 2009 | Magellan Maestro 3140 GPS Devices
Is there a tip for the car adaptor that goes over the fuse?
yes, there should be a tip over the fuse and also a spring. if your is missing and your charger was working, look inside where ever you had it plugged in last.
bill
Dec 21, 2009 | Magellan Maestro 4250 GPS
My tomtom wont charge through car charger or pc
It is possible that the cvar charger fuse has blown. Undo the tip and remove and replace !amp fuse and all should be fixed.
Please rate my help++++Thanks for using FIXYA
Dec 08, 2009 | Tomtom ONE 3rd Edition GPS
Megallan 3250 car chrager tip is missing
I went out and purchased an iGo charger. I was able to purchase the charger at a Radio Shack store, but in order to get the proper tip, I had to go to the manufacturer web site and order from there. I'm sure that you could order a new charger from Magellan, but it might be more expensive to do so. The iGo is capable of taking multiple tips for multiple devices. I hope that this helps.
Nov 06, 2009 | Magellan RoadMate 360 GPS Receiver
GPS charger of my car is not working.
first check and make sure the socket in the car is getting power, like trying your phone charger or something similar. if its not, locate the fuse in the car and see if its ok. if its ok check the fuse for the charger, most are in the tip that gets plugged in to the car. most can be removed by screwing the tip off. if the fuse is ok, then there is probably a problem with the gps.
Sep 02, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Lost cigarette lighter adaptor
I purchased a replacement. Thank you.
Feb 07, 2009 | Amcor 3900 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
91 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
