Vertical strip paler than rest of the screen
37 inch Toshiba lcd, 4inch strip right hand side of the screen appears to be slightly paler than the rest of the screen.
  • james_caddy5 Dec 11, 2008
    Seems to do it on all channels
  • 116 Answers
Check connectore for that area, may be loose, release the cable before pulling, and reinstall it. See if that works.
Posted on Dec 11, 2008
  • Justin Washburn Dec 11, 2008
    Youll need to open the monitor up and actually look at the connectors near the stripe, itll be near where the bar leightens up, the connector to the panel itself may be loose or have a weak connection. Post a pic if you can
5 inch wide blue vertical stripe on lcd
It can be but rarely the main board, most of these sets have either one or two boards that drive the image on the screen, different names like T-con or Y out etc. the right side board could be the problem or a bad connector or ribbon cable for that side of the screen unit.
Several possible cures and none are a snap to find in most cases.
Dec 06, 2012 | Toshiba 46LX177 46 in. LCD HDTV
The right side of my screen at about 3 inches from the side has a vertical bar that is lighter in shade than the rest of the picture. It started as horizontal flickering lines contained in the vertical...
Hello
There must be some loose contact with the t'Con board of your tV. Just look for it. Just unplug and replugh all the strip wires goes to T'Con board. This must solve the problem to your Tv. OK.
Oct 13, 2011 | LG 42LC2D 42 in. LCD HDTV
Model is Satellite P105 S6024, serial # 86019106W About one inch from right-hand side of screen, a 'white line' (in appearance) has appeared. It is about one inch in width, and goes from top to bottom of...
When you get vertical lines from the top of the screen to the bottom of the screen, it means you have bad LCD panel, you need the new one. It will get worst with more lines as time goes by.
Mar 04, 2010 | Toshiba Satellite P105-S6024 Notebook
Strip about 4" on right hand side of screen toshiba tv
Sounds like a bad connection. Lines through screen (horizontal and/or vertical). The wires that connect the panel to the main board are fragile and simply touching can break them.
Repalce screen. Usually cost prohibitive
-=/ Daft Tech /=-
Oct 25, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Nov 16, 2008 | Televison & Video
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Screen Problem
Unfortunately the fix is a new lcd. The tab welds at the top of the lcd are not allowing that portion to work correctly. As these tabs are fused to the lcd you will need to replace the lcd. My Toshiba M105 is almost the same.(I Have 4" Gone) on the right side. so to use it I clicked and dragged my system tray from the bottom to the side. And shrunk my web pages to utilize tthe good portion.
I suppose I should replace it but being only 18months old the LCD's run about 160.00 USD.(sometimes I just hook up an external monitor.
Apr 16, 2008 | Toshiba Satellite P105-S6207 Laptop
Lg 37 inch lcd has a dark shadow vertical line down left side of screen about 1cm wide and does not seem to go right to the top or bottom and is slightly wavey
reseat the LVDS cable inside the set. this is the multi wired connector that connects the main board to the panel. if that doesn;t solve your problem replace the main board. if you turn off the set and you can still see it in the screen it is the panel.
Feb 14, 2008 | Televison & Video
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
