Question about Marley PJ1257 Heater
I have a marley elect wall heater the little motor is shot
Can you get me a motor for a marley heater up2422-I 240 ac amps 9.2/63/4.6/332 watts 2200/1500/1100/750 42504-269-06 is a number on the heater itself.. motor has a uppco chicago on it 338703 may be another number on the motor.. model 51B2 240 v 60hz 190 amp lp class b this on on the motor itself.... i really dont know the model of this heater other than what i put up above.
    New Friend:
These motors are now made by Century electric motor Co. -who bought A.O. Smith, who bought UPPCO motor company.
The parts can also be requested Marley EP still manufactures a similar heater
In order to obtain any needed repair or replacement
parts, warranty service or technical information, please
contact Marley Engineered Products Service Center tollfree
by calling 1-800-642-HEAT.
When ordering repair parts, always give the information
listed as follows:
1. The Model Number
2. The Part Description
3. Date of Manufacture
Posted on Feb 25, 2013
2 Suggested Answers
SOURCE: Motor for bathroom exhaust fan
same problem but l thing l solved it by ordering a new replacement from if you need more help email me at
Posted on Mar 10, 2010
Marley md26
A standard 'Geyser' (water heater) timer is quite capable of controlling the two heaters.
Nov 22, 2013 | Heating & Cooling
Marley heater control knobs
can't find a contrl knob for my marley wall heater model # fzl3004b
Jan 17, 2013 | Marley Electric Hydronic Baseboard Heater,...
How do i wire a 240volt hydronic base board heater and thermastat
I need a control knob for my Marley electric wall heater model#fzl3004b
Dec 17, 2012 | Marley Electric Hydronic Baseboard Heater,...
Hello Fixya Guru ! I am in the process of installing several Marley PLF series 2000 watt/ 240 volt electric "Hydronic" baseboard heaters. I am using 10/3 bx with a 30amp breaker. To my...
You are correct that these heaters use a two-wire 240 volt supply, and the neutral is not needed.
2000 watts = 240 volt x Amps ==> Amps = 8.3 amps
30 amps x .8 safety factor = 24 amps
24 amps / 8.3 amps = 2.9 heaters per 30 amp breaker (3 heaters should be okay)
More info, pls let me know.
P.S. Where does the 2880-watt number come from ?
P.P.S. There has to be a ground bus-bar in the panel -- if it's a main panel (not a sub-panel) the ground buss and the neutral buss are connected in the panel. Could you clarify what you have in the panel.
Jan 11, 2011 | Fahrenheat Electric Convector Baseboard...
My 500 Watt Electic Baseboard heater ticks all the time, what can I do to stop this. Thank You
More than likely, the ticking is caused by the heating element ... expanding and shrinking as it gets hot and then cools off. You might get rid of some of it if you will gently lift the element and insert a small piece of fiberglass between the element and the element rest. If this noise annoys you ... maybe you can turn the radio up? :-) Don't use any other kind of material for this job.
I hope you find this suggestion helpful ...
Thanks for your interest in
Nov 27, 2010 | Marley HBB1004 Electric Baseboard Heater
MWA 2420 Wall Heater Motor Replacement
From what I can see you are asking me to tell you how I fixed the problem for free ye you want me to pay you for the solution, I don't go for that kind of business!
Jan 05, 2010 | Dryers
Marley Hydronic baseboard heater not turning on
on the one that don't work use a clamp around ammeter and see if you are drawing current. no current, the heater element is shot!
Oct 23, 2009 | Marley Electric Hydronic Baseboard Heater,...
Marley B2451 wall heater
These are only 1500 watt heaters.
They 'could' heat a 20 x 20 foot room (with good, tight construction), with a slow temperture rise.
Check the company web site at
Jan 22, 2009 | Marley Electric Hydronic Baseboard Heater,...
Installing hot water baseboard heater
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
How far off the floor do i install hot water baseboard heaters
When you install the baseboard heater make sure the bottom part which is the all thing must sit over the floor and touch the tiles or carpet and use 2 or 3 wood screw against the wall. That is it and do not put any kind of paper or cotton or material things above the cover. Beside that you are ok and it is not like an electric wall heater.
Marley PJ1257 Heater Logo
629 people viewed this question
Top Marley Heating & Cooling Experts
Paul Carew
Ron Durham
Are you a Marley Heating and Cooling Expert? Answer questions, earn points and help others
