Question about Canon PIXMA iP1600 Printer
In ip1000 printer black ink is not working.already replaced a black tank but it doesn't make any result.why???
    Guru:
  • Canon Expert
  • 183 Answers
Hi vdkmail,
Perform nozzle check pattern from maintenance menu in printer driver properties first. Is all black nozzle printed?. Is it perfect or partially printed?. Or no black nozzle printed at all. Then perform printhead cleaning procedure to fix this. If problem still persist means the printhead should be replaced with new one. But be careful, print blank (no nozzle printed at all) might be caused by faulty purge unit too so that ink not flows down from ink tank.
Regards,
Source:
Canon Inkjet Forum
Posted on Dec 13, 2008
Canon pixma ip1000 print black colour with gaps.
Sounds like printing nozzle problems, or the waste ink absorber is saturated. There is step by step guide to cleaning it at
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
Jan 23, 2014 | Computers & Internet
Canon pixma ip1000 black ink stop printing suddenly
Based on your explanation I will try to help.
Your ink tank had run out. You can refill it through the bottom of the tank or just simply replace your ink tank.
Aug 11, 2017 | Canon PIXMA iP1000
My canon ip1000 printer show error "print head not available". but head already fix in place
The print head may not be proper electrical connection. Remove the print head and clean the electrical contacts on the ink cartridge and in the printer with methylated spirits, replace the print head and hopefully this will fix the problem.
Feb 02, 2013 | Canon PIXMA iP1000
Canon pixma ip 1000 black ink not print
Change black ink. If no result, then the printhead is dried. You need to run clean printhead from the printer driver, but in most cases without success
Jan 15, 2011 | Canon PIXMA iP1000
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
Waste ink tank full
Here's the steps for reseting "Waste Ink Full" problem at iP1000
Step 1: Manual for Service mode (1st method)
1. Unplug POWER and USB cables.
2. Open door, PRESS and HOLD the POWER button.
3. Connect the POWER cable.
4. Close door, then release POWER button.
5. Power ON your printer a usual (It should not blinking anymore)
Step 1: Manual for Service mode (2nd method)
2. PRESS and HOLD the POWER button,
3. Release the the POWER button
4. Power ON your printer a usual (It should not blinking anymore)
Step 2 : Software for Permanant (1st method)
1. Reconnect the USB cable and turn ON your Printer
2. Open "General Tools for iP1000",
http://www.printersiam.com/data/download/iP1000%20Service%20Tool.zip
3. Select (USB PORT)
4. Choose (SET DESTINATION 1)
It should be reseted already, but somehow it start blinking again if you ever unpluging AC POWER cable. So try the 2nd method by using ServiceTool for IP1500
Step 2 : Software for Permanant (2nd method)
2. Open "General Tools for iP1500",
http://www.printersiam.com/data/download/iP1500%20Service%20Tool.zip
4. Choose CLEAR WASTE INK COUNTER - MAIN
5. Choose CLEAR WASTE INK COUNTER - PLATEN
It should be working, coz my printer now now work normally
I tell you what. Before you decide to reseting the waste ink counter, you should really clean up the ink absorber, or else you will find the ink watse absorber overflow...
Aug 25, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Canon pixma ip1000 ink
dear claire
if your use that, it;s no problem ( you refill this with ink)
it's compatible for your catridge
oke well
thanks
cropp
Mar 16, 2008 | Office Equipment & Supplies
Canaon pixma ip1000
i need driver for pixma ip1000
Sep 22, 2007 | Office Equipment & Supplies
Canon PIXMA iP1600 Printer Logo
176 people viewed this question
old marine
old marine
