Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Canon powershot SD 500 lens does not return, E18 in photo mode
The play back mode works fine, the camera mode says e18 and a bleck screen. the lens does not return to flat position.
Nick Spirov
  • 35 Answers
SOURCE: E 18 problem
The dreaded E18 error happens to many Canon cameras.
This error occurs when the lens is mechanically stuck. Sometimes you need it to be serviced and most times you can fix it, but even then it's a good idea to have it serviced soon. The cause to this may be dust, dropping and other mechanical problems.
1. Check if the battery is full
2. Check for visible mechanical problems (obstacles, debris). You may notice the lens is not exactly straight - in this case this is the cause of the problem.
3. Turn the camera off.
4. This needs to be done with gentle force: Take the camera in one hand and with the other gently take each part of the lens and gently move it round in a circular movement. Do this with both sections of the lens. You will hear a little "click" as it pops back in place.
5. Power the camera on.
Hope this helps!
Posted on Jan 09, 2008
t00nz
  • 4738 Answers
SOURCE: canon powershot s2
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 02, 2008
t00nz
  • 4738 Answers
SOURCE: E18 Error message on my Cannon PowerShot A410
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Posted on Jan 15, 2009
  • 13433 Answers
SOURCE: canon powershot s2 is lens won't retract error e18
Try tapping not so gently. other than that it will most likely need to be taken apart and put back together the right way. And any broken parts replaced.
Posted on Mar 17, 2009
pixeldawg
  • 71 Answers
SOURCE: what does E18 mean?
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off. This is caused by dirt in between the telescoping portions of the lens. You can clean this with compressed air, generally. Blow air all around the turret sections of the lens. you can also GENTLY push the lens inward ( have the lens extended and take the battery out... then push inward...)
Posted on Jul 11, 2009
E 18 problem
I dont know what error E18 means, check cannon support for that, but welcome to the world of DISPOSABLE CAMERAS, I have replaced 3 cameras in 3 years, 2 because of lens and shutter issuses.
Jan 26, 2009 | Canon PowerShot S2 IS Digital Camera
Camera won't function - "E18" (Canon PowerShot S230)
Try lightly tapping lens on a hard surface. This sometimes reseats the lens. If this does not work take to bits and reassemble.
Dec 13, 2008 | Canon PowerShot A75 Digital Camera
E 18 problem
The E18 error happens on Canon cameras usually when the lens is jammed when extending.
The error is so (in)famous that it has it own website where you can find help and advice on how to fix it. You can view the site by clicking the link underlined in blue below:
http://www.e18error.com/
There is also a Wikipedia entry which you may find helpful:
http://en.wikipedia.org/wiki/E18_error
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Aug 02, 2008 | Canon PowerShot S500 IXUS 500 Digital...
E 18 problem
I have the same issue "E18" on my powershot A95 and i don't know how i can solve it. Sorry. Loic
Jul 15, 2008 | Canon PowerShot A95 Digital Camera
Have a powershot sd550
E18 is a lens error. My guess would be sand got into your lens (into the gears, etc.). These guys should be able to take care of you. http://www.darntoothysam.com/servlet/the-1730/Canon-Powershot-SD550-Camera/Detail
Feb 28, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
E 18 problem
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
E 18 problem
This error is caused by a faulty lens motor, contaminated transmission, or mechanical damage from dropping. Unfortunately, there is no easy fix for this and it requires service from Canon or other repair facility.
Dec 30, 2007 | Canon PowerShot S2 IS Digital Camera
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
E18?
Click here for help on repairing e18 error
good luck my friend!
Hope you will save 150$ for the repair..
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
19 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
