Question about Ace Hardware Black & Decker& Battery Charger
I am trying to charge a dead battery on my car, and I am using this battery charger for the first time. Black and Decker model number VEC1086BBD. I got a light that says "Fault". What does that mean? I ought to be able to switch the amp usage for charging but I cant do anything. Maybe I should let it charge for a while and see what it does?
  • 594 Answers
O.k. the fault light means that the battery is either 1. not connected right or 2. the battery is not chargeable.
Please let me know if you need further assistance.
Happy Holidays
Posted on Dec 11, 2008
Black and Decker rechargeable Screwdriver
There usually is an indicator on the charger that lights while charging is underway. However, the charger can light up and charge away merrily without reviving a dead battery.
Dec 01, 2013 | Electrical Supplies
When I started to charge up one of my two batteries the charger light went red two seconds later it went dark and I know the battery was dead.,Then I tried my second battery which was somewhat still...
A simple volt meter would tell you if your charger was putting out or not. plus the volt meter would come in handy for many other home/auto ETC problems down the road.
Feb 03, 2012 | Black & Decker Black And Decker FS24C...
My Black and decker cordless trimmer is not quite out of juice but it is not cutting anymore. can i recharge it now or do i have to wait until the battery is completely dead?
You can recharge the battery at any time. I usuly use mine then when done using it I put it back on the charger so I know it will be charged the next time I need it.
Jun 19, 2011 | Black & Decker String Trimmer Cordless 12"...
I have an 18V cordless drill/driver. When I tried to recharged the battery, the battery stayed dead. The red light was on while recharging. The charger stand has red and green LED indicators but only the...
Chargers will out last batteries by a long time.You will need to get a new battery. Black & Decker is a cheap household brand and does not hold up for long periods of time. I have better brands and buy several new batteries every year.
May 30, 2011 | Black & Decker 18V Cordless Drill/Driver
I am searching for instruction manual for my Vector Model VEC1086B. Can you help me out?? Thanks Jane in Coral Springs, FL janeerub@bellsouth.net
Hi Janee,
You can access the instruction manual at this site. Here is the web address for the .pdf document:
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90515397,VEC1086BBD.pdf
handy andie
Mar 20, 2011 | Black & Decker VEC1086BBD 6 Amp / 4 Amp /...
The charger for my Black and Decker PS130 power pack batteries just quit on me. Apparently, other folks have had the same problem so I don't want to replace it. I subsequently bought a Dewalt DW9118 but...
For the price a Dewalt costs, you can buy a few reconditioned cheap cordless drills and keep them all charged up. You will always have a standby. You can also check the pawn shops. With times like they are many people are getting rid of good stuff. You can find a great deat but always use a trustworthy pawn shop and get a receipt with the serial number on it. Theives like pawn shops, too.
Happy Hunting!
Dec 09, 2010 | Black & Decker Black And Decker 12 Volt...
My porter cable 19.2v model 8605 battery charger
Porter Cable has not offered a replacement for their poorly designed 19.2V chargers. I had the same problem and happen to like my drill and circular saw. I found a universal charger called a model number CHUN-2420. Google it--I got mine for $27 plus shipping. All you need to do to make this work is splice 3 wires.
My charger is a PC model 8624, so the instructions might vary slightly between the chargers. Remove the six screws on the bottom of your PC charger. Remove the bottom section. Remove the screw(s) that attach the circuit card to the plastic housing. Disconnect the 3 pin white charging connector from the circuit card, and cutoff the connector. Discard the circuit card and power cord. Cut the 3 conductor (red/yellow/black) cable coming out of the Chun-2420 approximately 2' from the charger. Splice these three wires to the three wires in the charger housing that connect to your battery. In my situation, Red/Red, Yellow/Yellow, White/Black. To verify, red=positive, black/white=negative, yellow=temperature sensor. Wrap the red/yellow/black cable with electrical tape where it exits the PC charger through the power cord hole. Re-attach the bottom.
Jul 24, 2010 | Porter Cable 19.2V Drill Kit
Describe your Black & Decker Black
If it is not 2 years old, it is covered under warranty: http://www.blackanddecker.com/CustomerCenter/Warranty.aspx
Sep 12, 2009 | Black & Decker Black And Decker FS24C...
Ace Hardware Black & Decker& Battery Charger  Logo
237 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
