I have a Brother multi-function machine. It is model MFC-8860DN
The confirmation page print prints 3-inch wide vertical lines down the left side of the paper.
I would appreciate any help you can offer.
    Problem Solver:
  • 18 Answers
Do your incoming faxes have the same marks?
If not you might find that the scanning part of your machine has a dirty mark on the glass or that the unit has become faulty.
Try and take a copy from the machine and print from a report or any print from memory.
If you have the black lines on both then i'd suggest getting a new drum unit, if u have it only on the copy I would have a look at your scanner glass and see if there is a dirty mark on it. if not maybe call out an engineer as the scanner unit maybe faulty.
Need anymore help msg me.
Posted on Dec 11, 2008
2-sided scanning
HI Nada,.. Don't know what exact problem you're experiencing with 2-sided scanning. But from what I've gathered on your machine, it may not be capable.
Please find the attached software guide for a range of multi-purpose machines, including yours. Page 41 leads into that function being available on the MFC-9560. Double there and on page 130 to see if anything helps in clearing up your problem.
Good luck,
Jun 26, 2014 | Brother MFC 9460CDN - Multifunction fax /...
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
Brother MFC-6800 - Mysterious Vertical Lines
This unit has a brom tube unit and need to be replacement . By repair tec.
Oct 05, 2009 | Brother Multi-Function Center MFC-240C...
Fax confirmation page
If you have a reports button, press it and select the user settings report. Without a button, press menu button and scroll to reports and choose user settings. This report tells you what settings you can change and where they are. Most Brother machines only have an error report setting so that it just tells you when a fax doesn't go through.
Jun 23, 2009 | Brother MFC 490cw Color Inkjet...
My fax Machine has lines going each page that prints out
Get a can of air, open the unit and blow it out.
Also, clean the glass.
That should help solve the problem
Jan 08, 2009 | Brother MFC 4800 All-In-One Laser Printer
Brother MFC 9700
Remove your drum unit and you will see on top of where the drum unit sits inside your machine is a piece of glass(inside the machine). Wipe the glass with a soft dry cloth. If this do not work, remove your toner cartridge and see if the toner is spread evenly on the cartridge.
Mar 17, 2008 | Brother MFC 9700 All-In-One Laser Printer
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Jan 06, 2008 | Brother MFC-8860DN Printer
Instrution book for 8860 DN
I have a Brother MFC 8860DN Network Fax machine and I need to program some phone numbers on it for automatic fax. I don't have the book to follow the steps to program it.
Nov 21, 2007 | Brother Office Equipment & Supplies
324 people viewed this question
