Question about Akai PT4298HD Rear Projection Television
Clicking noise When I turn on the TV there is a clicking sound. Even while the tv is on the clicking continues. I have to turn the tv off and back on several times for it to go away. I have had a tech over to see what the problem and he could not find the problem. Sounds like the tv is arching . Any suggestions
  • Akai Master
  • 19,396 Answers
The clicking noise is a protection circuit that prevents the TV from switching on when a fault is detected.
That means that there is a short, a bad solder joint, or a bad component inside the TV, usually any good technician is able to find out at least the nature of the fault. Often this jobs must be done at a repair shop, as testing may take time, probably your technician was just in a hurry.
All you can try at home is leaving tv unplugged for a couple of hours, this drains power from the set , and fix some problem.
If it does not work send it to a repair shop.
Posted on Dec 11, 2008
Have a model WD 55734 and the screen is completely black when turned on, and the tv makes a loud chirping or clicking sound that continues even when you turn the tv off. Lamp replacement??
Tv LED"LAMP"light flashes,projection lamp been inside the tv like 1 1/2 or 2 years?Used like 4 or 5 hrs daily?Yes,the tv projection is dead,should be replaced.The clicking noises,that mean the board call the Ballast board also dead,must be replacing too.The Ballast board only job it to ignite the tv projection lamp.
Feb 13, 2011 | Mitsubishi WD-57734 57" HDTV
TV will not turn on
Hi, If the clicking noise is metallic, could be a relay switching on/off. What's curious is that once powered on by remote, apparently the clicking doesn't affect the TV, meaning it continuously work. The relay is suppose to turn on or off a function of the TV and apparently it is trying to but there is not such effect since the TV, as I understand from your post, works. The relay can be for the degaussing coil, power supply, over voltage protection. Since this involve a little diagnosis of the electronics, soldering and probably a minor component replacement, an on-site service/repair man would be your best bet. Even if it were a nuisance/minor repair, you can at least get the clicking noise out. Other than you get to get a checkup of the TV and diagnosis of what caused/started the clicking sound in the first place. Hope this be of help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Aug 27, 2007 | Zenith C30W46 30" TV
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
Tv just makes clicking noise and doesn't turn on
I had the same problem. The power board for the on-off had to be replaced. The set is only 11 months old.
Oct 19, 2009 | Philips 42PFP5332D 42 in. Plasma...
My tv turns off by itself and makes a clicking noise
Most likely it has some bad capacitors in the power supply. Flat--panel sets are VERY hard on capacitors, due to the fact that the "rising heat' from the set "cooks" the caps and they fail VERY early.
Oct 12, 2009 | Samsung HP-T4234 TV
My phillips 50'' plasma tv is making a clicking noise like it is turning on but does not come on and continues to make the clicking noise. Any comments on what the problem could be?
sounds like its the CCFL trying to come back on, either that or like on my sony Bravia when it selects input sources it makes a clicking sound as well.
1) is got a bad CCFL
2) it has a bad psu
3) if its under warranty take it back
Sep 04, 2009 | Philips Televison & Video
When you turn 'on' the tv...the tv continuously 'clicks'
The clicking noise is caused by the relays on the power supply board trying to power up the system. Your TV has detected a problem that's causing the power supply to shutdown. Someone knowledgeable in electronics can track down the problem. The SOURCE of the problem could be another board other the power supply.
Mar 15, 2009 | Samsung 46 in. Flat-Panel LCD HDTV
Tv troubleshooting
There is problem in the power Supply section.check the h-out Transistor if Damage then Change for the Same COde #
Nov 13, 2008 | Televison & Video
Toshiba Plasma clicking noise
Check the fan, it may be dust or a bad bearing.
Oct 10, 2007 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
TV won't turn on just a clicking noise
ok this is a bit complex but im going to describe to you what you have to do\ 1) TAKE THE BACK COVER OFF 2) LOOK FOR WHERE THE SWICJ IS LOCATED 3) LOOSEN THE SCREW WHICH HOLDS THE BUTTON 4) CARRY ON LOOSEINNING BUTTON UNTIL YOU CAN PRESS IT 5) THEN CHEC IF IT WORKS IF IT DOES TITEN THE SCREW AND PUT COVER BACK ON IF NOT THEN CONTACK ME
Aug 26, 2007 | Philips Magnavox 20MT133S 20" TV
Akai PT4298HD Rear Projection Television Logo
77 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
