Question about GE DSXH43EAWW Electric Dryer
GE Dryer model DSXH43EAOWW won't stay on.
Has been working fine for 7 yrs. Today coworkers noticed sparks coming out of the back! It will not stay on unless the switch is held in the the start position manually. What should we do?
buffalonyman
  • 1865 Answers
SOURCE: GE #DVL226EB6WW
Here is a link to parts and drawing for your dryer: http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
If the drum won't move, likely culprit is the belt
Posted on May 07, 2009
localwonder
  • 6784 Answers
SOURCE: GE Dryer doesn't give out heat.
OK, i would check the thermal fuse. is usually located on or around the blower housing. Check the vent duct if its not on the blower motor housing. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
If the fuse is OK, there is only one more problem spot and that will be the timer itself. replace the timer/control if the fuse is OK.
Posted on Jun 01, 2009
  • 26 Answers
SOURCE: Dryer won't stay running
I had the same problem with my kemore. Thank goodness I still had it under warranty.
The tech said the door latch was just slightly ajar. This is common he said that when we take clothes out we let the door close to hard or gets ajar for leaning in to take clothes out.
He readjusted it and I have never had a problem with it again.
Hope this helps
Posted on Sep 26, 2009
hunter19_46m
  • 7482 Answers
SOURCE: ge dryer model DVL223EA0WW service manual to replace heating coil
Try this website, they will have everything you need.
http://www.repairclinic.com/SSPartDetail.aspx?PartID=2512&Acc=1&PPStack=1
Good luck,I hope this helps
Posted on Nov 13, 2009
rylee_smith
  • 8619 Answers
SOURCE: My GE Gas Dryer won't
Hi
Thanks for using FixYa. If the vent is clean then it seems to be the issue with the Thermal Fuse/Thermostat going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. You can check it for continuity with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 06, 2010
Need a color coded wiring diagram of the timer M460-G for the GE electric dryer DSXH43EAOWW
All GE dryers have a wiring diagram inside the control panel on the left side as you stand in front of the dryer. It should show the wiring in black but with color coding listed for each wire. If yours is missing I will try to locate a copy. SearsPartsDirect use to have some wiring diagrams on their parts site.
Jun 03, 2015 | GE Dryers
I have a Frigidaire Dryer model number GLER341AS2. The dryer runs fine, but won't get hot. I pulled the dryer from the wall to see anything obvious. I noticed what I thought at first to be anim
Are you mechanically inclined? You may have several problems. 1st, heating element is most likely burnt out. Then I would check ball and socket assembly that back of drum fits into. Also check felt in front of machine that drum rides on. May need competent service person on this.
Sep 13, 2017 | Frigidaire Electric Dryer
Is the GE WSXH208A1WW a stackable washer with the GE DSXH43EAOWW Dryer?
Could you please describe the problem you are having a little better?
Nov 27, 2012 | GE WSXH208A Front Load Washer
Ge dsxh43eaoww won't start or anything, light on when open door, i have 240v coming in what's else can i check ?
I would start with your door switch it will not operate with this bad. Remember to rate my solution and give testimonial it is how i earn my achievements Thanks in advance.
Apr 23, 2012 | GE DSXH43EAWW Electric Dryer
No heat from dryer
i believe a while back, this model had a timer issue, but would need exact model to be sure,
anyway its a pretty asy repair and the part is easily available at
appliancepartspros.com
the average timer is around 80
and about ten minutes repair
Oct 15, 2009 | Kenmore 73952 Gas Dryer
Ge select electric dryer
it may be clogged on the inside of the machine not just the exhust tube.
Jan 10, 2008 | GE DCSR483EA Electric Dryer
GE DSXH43EAWW Electric Dryer Logo
271 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
