Question about HHP Alternator/Battery Tester - 125 Amp Load Hand Held
Wiring to fuses
Car is a seat ibiza. would like to see pictures of the wiring diagram of the fuse box and alternator.
I have a seat Ibiza 2014 and only one indicator is not work n/s/r . I swapped the rear lights and it's not the light because it works on the other side . Snap on machine says there is no faults
There's this website www.reliable-store.com
They have books on ALL vehicles.
it covers wiring diagrams, electrical diagrams, fuse diagram, torque specs, PCV, error codes, fault codes, service info, repair info, parts info, owner's/service/repair/parts/maintenance manuals etc everything totally..
I have 1987 toyota 4runner model and I keep servicing and when needed repair it on my own. worth it !!!
Mar 18, 2018 | Seat Cars & Trucks
94 mercury villager van, passenger auto seat belt motor running continuously & seat belt won't work. Drained battery. Where is the fuse located?
Engine compartment main fuse panel 30 AMP fuse Fuse #4 scroll down and look at this diagram picture on this link. http://www.autogenius.info/mercury-villager-1st-generation-1993-1998-fuse-box-diagram/ caution, this fuse runs power seats, windows and sun roof as well.
Mercury Villager 1st Generation 1993 1998 fuse box diagram Auto Genius
Oct 15, 2016 | 1994 Mercury Villager
How do you find location of fuse for break lights? Seat Ibiza 2004
Check the fuse number 13.Under the glovebox.
For step by Step Guide On Where Is Fuse panel With Diagrams And Helpful pictures.Click the link below:
http://carrepairworld.blogspot.com/2016/06/seat-ibiza-brake-light-fuse.html
This will help.
Thanks.
Jun 02, 2016 | Seat Cars & Trucks
Seat Ibiza 1.2 12v 2004 My Reverse Light doesnt work :( Any help much appreciated!
Take it to someone who knows how to fix these thing's !!!!! Before you mess it up !
May 16, 2015 | Seat Ibiza Cars & Trucks
Blower not working in my 2010 seat ibiza sport.
Have you checked your fuse and relay boxes, that is where I would start.
Nov 11, 2014 | 2010 Seat Ibiza 1.6
Seat Ibiza chill were is the fuse box show me please
there are 2 compartiment box fuse see the picture.
God bless youff93edbb-f00f-4493-a49b-8ee5af3148d6.jpg69f15c9e-4e16-4a9e-8c88-de70ee3d90ef.jpeg
Sep 24, 2013 | Cars & Trucks
1998 isuzu trooper need wiring diagram for charging system with a3.5 li5ter motor
1998 trooper new alternator and still not charging and alternator bench tested good,
Check main 80 amp fuse in engine compartment and also check fuses in inside fuse box, there two in that one. first is engine fuse 15amp and the 10amp gauge fuse,
Here is the wiring diagram for the charging system as you asked for , also check connections, follow battery wire off the back of alternator make sure connections are good , that wire runs to engine fuse box and that is one fuse that i said to check it is 80amp, hope this is helpful good day9_30_2012_10_15_05_pm.gif
Sep 30, 2012 | Cars & Trucks
Seat ibia fan not working
the fan motor is bad or u can check for a bad fuse in ur fuse box,, hopefully thats it .
Aug 30, 2012 | Renault Cars & Trucks
2004 Chevy trailblazer. Power windows & locks dont work on driver side front controls. Have all ready removed and replaced control cluster on arm rest. All other wondows work at the respective door,...
Sounds like a fuse. Are you getting power to the driver door module (control cluster as you say). Below are 3 pictures for you. The first one is the location where the fuse box is located for that fuse (under drivers seat in the rear). The second picture is a diagram or the latout of the fuses. The fuse you want to check is the fuse marked "LT DOORS" or the one marked 02. It should be a 25 amp fuse. The 3rd picture is a wiring diagram for the circuit. If the fuse isn't blown check the power wire from the fuse box to the driver door control module. Sounds like a power issue. Anymore questions or diagrams that you need, feel free to email me at csautomotivecars@att.net and I should have and will send if you need anything else. I hope this helps and good luck.
Jun 27, 2011 | 2004 Chevrolet TrailBlazer
HHP Alternator/Battery Tester - 125 Amp Load Hand Held Logo
185 people viewed this question
Top HHP Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a HHP Measuring Tool and Sensor Expert? Answer questions, earn points and help others
