Question about Brother MFC 240C All-In-One InkJet Printer
I am trying to print but nothing is showing up on the page
The printer keeps saying add paper and the paper is already in the tray. I think a piece is missing that helps with the printing. Don't know if I am saying this correctly.
    Champion:
  • 320 Answers
YOU MIGHT TRY CLEANING THE PAPER FEED ROLLER WITH ISOPROPHYL ALCAHOL, THE ROLLER IS ABOVE WHEN THE PAPER TRAY IS REMOVED
Posted on Jan 12, 2009
I have a hpj6480 printer. It says paper jam. I've done everything, turned off removed every piece to clean out, pushed every imaginable button...still paper jam it reads....
Below are the causes of paper jam
  • Paper loaded incorrectly in the paper tray.
  • Damaged or dirty paper rollers.
  • Torn, wrinkled, or damp paper loaded in the paper tray.
  • The rear access door or two-sided printing accessory (duplexer) might not be closed or is not locked into place.
  • Paper was added to a stack already in the tray while the HP product was printing.
  • The tray contains more than one type of paper.
  • The paper is jammed inside the HP product where you cannot see it.
  • An obstruction is blocking the paper path.
  • Torn pieces of paper from a previous jam are stuck in the product.
  • The tray is too full.
  • If printing on an envelope, the edges of the envelope are bent.
Try steps provided in below link and check if paper jam is resolved.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c01312792
GuruAid.com
Oct 30, 2014 | Office Equipment & Supplies
MY BROTHER MFC 9440CN KEEPS SAYING NO PAPER RELOAD PAPER IN MP TRAY
not sure if your on copy mode or print mode ..close the MP tray door....turn off then on go to general setup select tray 1. not sure if your on copu mode or print the machine wants you to add paper to the tray that needs it. if you add paper dowes it still say"add paper" .if this is the case then the tray sensor is 1)broke2) pushed out of the way folded3) tray feed roller are not installed correctly no allowing sensor ..make sure your printer settings(properties) are set the that tray.
Oct 16, 2014 | Brother MFC-9440CN Laser Printer
13.02.00 paper jam on tray 2. i have removed the tray and even the catridges but can't find any paper. I don't know where the sensor is as this may be the cause as well. Please need urgent...
Number 1 you failed to mention what kind of printer you have.
Number 2 when you print, does paper even feed into the printer?
When was the last time that you replaced the feed rollers?
Yes it is possible that a sensor is jammed. Before the 13.02 error,
did the printer actually have a paper jam? If yes, was there a piece of paper
missing from the jammed sheet or was it whole?
Jul 15, 2011 | Office Equipment & Supplies
Tray which printer prints from.
Just had this problem and stumbled upon how to fix it. Check the guides in your tray 2. Our back guide was slightly off of the proper spot for letter size paper. This was causing the printer to think the tray had a custom size of paper in it. Your document is probably trying to print on letter size paper and when it doesn't think the paper is in there it switches to tray 1.
Apr 08, 2010 | HP LaserJet 4700 Printer
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
When asking to print keeps saying load MP feeder cardstock A4 although computer set up to print from tray 1?
depends on the printer, normal home use printer have only 1 tray.
office printer usually have multiple trys. and usually the default for that is tray 2. tray 1 is manual feed.
May 14, 2009 | Office Equipment & Supplies
Keeps saying "paper out" when paper tray is full
Reduce the quantity of paper fed to the printer.
Mar 31, 2009 | Dell 922 All-In-One InkJet Printer
At power on I get a 13.20.00 jam inside rear door. Nothing is found in the rear door area. I can't find any flag tied up or a sensor to clean.
This error can be misleading at times. Although it says to check the rear, if you haven't already, remove the toner cartridge and check inside. Also, when you look inside you should see a green lever on the right side. Lift that and check to see if there is paper stuck down there. Another place you can look is in the paper tray area. Remove the paper tray and check to see if there is a piece caught on the way up. Keep in mind when removing a jam make sure you get a whole piece of paper, any missing pieces will cause problems later.
If both areas appear to be clear, think back to if you have a paper jam and got the paper out. Did the paper tear? A small piece could be stuck on a sensor within the printer. If you find paper and everything is good to go, check the pick up rollers to ensure jamming won't happen again. They are located on the paper tray (grey/blue roller) they should like mini tires with grooves, NOT smooth. The other roller is located inside the printer.
Mar 26, 2009 | HP LaserJet 4200 Printer
BROTHER MFC 8440 ERROR "NO PAPER"
Check the paper tray adjustable guides inside the tray; the guides need to fit around the paper snug, when re-inserting the tray if the rear guide is back too far the paper may be shifted towards the front of the tray out of range of the paper sensor so it thinks it's out of paper. I service HP LaserJet printers and most of the time this is the problem. Hope this helps.
Mar 12, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC 240C All-In-One InkJet Printer Logo
110 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
