Question about Dell Inspiron B130 Notebook
Won't turn on. Power adapter light on - noting on the b130
How can I check to see if power cord is not getting juice to my laptop?
  • Anonymous Dec 27, 2008
    Can the laptop turn on without the battery installed? ( with a working power supply of course)
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 74 Answers
If the power light is on then the laptop is getting power.  Take the battery out and if the power light is still on when you push the power button then there is something else wrong with the laptop.
Posted on Dec 11, 2008
My screen does not turn on
  • Remove all power (adapter power Cord and Battery (for laptops))
  • Hold down the ON button for 30secs (dispersing internal voltage)
  • Plug the power cord in only (ie leave battery out, for the moment)
  • Turn on
Check your power adapter. Plug it in to a known good power receptacle. See if the power adapter has any lights that light up to make sure it is getting power.
Take the battery out of the laptop and just only plug in the power adapter.
Do any lights on the laptop light up when you power it on? Does it beep?Does it make a sound? Is where you plug your power adapter to your laptop loose or broken?
if no sound or light the its either power adapter , dc jack or cable, or system board .
Please note, it is also a good measure to re seat the memory.
You may need to locate your disassembly guide
Aug 14, 2014 | Compaq Presario R3000 Notebook
Laptop has power but won't boot up
There are three possible reasons why it's acting like that.
1. Defective AC Adapter or Power cord
2. Defective Motherboard
3. Defective Battery
First off, you need to isolate the part which causing the issue. Please follow the following steps:
1. Remove the battery and use the power cord alone in powering up your computer. If it goes well, then you need to replace the battery. If no go, then try using a different known good outlet.
2. Check the acer power adapter (the box) if there's a light lit. If it's green, then it's should be working fine. If it's amber or nothing at all, then there's a problem with it. You might need to replace that.
3. If the AC adapter looks good, then try to wiggle the cord so that you can check if the cord is properly connected to the computer. Usually, cords get loose and it causes problems. If it has this kind of problem, then you need to get a technician to check that for you because you might need to buy a new motherboard for that.
Please do the above simple steps, and let me know if anything happens. I hope this can solve the issue.
Feb 13, 2013 | Acer Aspire One PC Notebook
Latop will not boot up
1.Ensure your battery is holding power. Some laptops will auto shut-off if the battery won't hold a charge. In that case, replace your battery and retry. Check your charging lights or indicators to see if your laptop is getting power and charging.
2.Check your AC to DC converter (the little black adapter you plug in your AC outlet.) This converts AC power into DC power. Is it abnormally hot? If so, it is probably burned out. Replace it. Note- high heat is not a true indicator of malfunctioning. It can be dead and cold as well. No power
indicators on your laptop could be a sign of a dead or bad converter also. Converters WILL get hot (this is normal.) If it is REAL hot (to touch), then this is not good.
3.Check your power cord. Are there nicks or cuts? If so, unplugg it from the AC power and repair with electrical tape- better yet, replace it. Many computer salvage stores carry power adapter cords. They're cheap.
4. Check your laptop lid switch. If it is broken, you may have power but your screen may not come on.
This is usually a little button or mechanism located close to the lid hinge that turns on or off your
screen when your lid is open or closed respectively. Normally the operator does not push this button.
These are fragile and broken easily on some laptop models. Sometimes these can be fixed, more often
they will require replacements. If you aren't an expert repair person, get a technician to
repair/replace it for you. Opening up laptops is a very delicate operation and much more difficult to
repair than desktops. It may be worth it to spend the money for repair.
5. If you have tried these easy solutions and it still won't power on, then your problem lies
elswhere. You may have an internal power switch or voltage regulator problem.. Internal problems will
require professional help.
Nov 02, 2012 | Dell Inspiron 1526 Notebook
Suddenly won't turn on no charge light indicator
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's power socket.If the power/battery LED light flashes and in a certain position this LED lightstays firm, then the power socket is either faulty or it has a dry solder jointwhere it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 25, 2012 | ASUS G71G-A2 PC Notebook
My Dell Inspiron B130 won't turn on. The battery light blinks yellow twice then green, but that is the only thing happening.
Take the battery off completely and drain the flea power from the laptop by holding down the power button while the battery is off. Hold down the power button for about 15-20 seconds to ensure no power remains on the laptop. Check if your battery has a drain button too. Drain the battery and place it back on the laptop.
Charge it for about 30 minutes before you turn it on. See if it works.
Post here if you need further help.
Jul 30, 2011 | Dell Inspiron™ B130 PC Notebook
Laptop is plugged in. Notice on screen that battery was low, even with it plugged in, and now no power lights on. Adapter light is still on indicating outside power supply on. Removed and reinserted...
The batteries do go bad overtime and will no longer hold a charge but the laptop should still work as long as the power cord is connected. If it still does not work with the power cord connected then it is most likely the power cord, these can go bad, but make sure that the power is securely connected and that if it is plugged into a power strip that it has not been turned off, try another outlet just to rule it out as well.
Jan 22, 2010 | Dell Inspiron B130 Notebook
Has power but wont boot up at all inspiron b130 notebook, was working fine 4 days ago ,
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 15, 2009 | Dell Inspiron B130 Notebook
My inspiron laptop wont turn on after I replaced
Verify that you obtained an exact replacement power adapter for the Dell. If it is an exact replacement then try this. Disconnect power adapter. Remove battery. Reconnect power adapter without the battery. If it turns on, then power off and place battery back in. Then try again. If problem returns, there could be a problem with the battery itself.
Sep 28, 2009 | Dell Inspiron B130 Notebook
My Inspiron B130 will not charge,even with a new battery. I plug in the power cord, will not charge still. No power light, nothing
just had the same problem- the socket where you plug in the adapter had shorted out-needed to be resodered-no big~100$
BUT my ac adapter was bad as well- may have caused the short (they are cheap on ebay)
May 08, 2009 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Notebook Logo
173 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
