Question about Maytag 24 in. PDB1420 Built-in Dishwasher
Maytage dishwasher soap dispenser not operating properly
My Maytag is nearly 19 years old, Model WU482. It has a round soap dispenser divided into 2 sections. The dispenser doesn't open during the second wash cycle. I've made sure it is not clogged with old, hardened detergent. I don't know how to take it apart to see if a spring or something is broken. What do you suggest? Is this a do-it-yourself repair? Thanks for any information you can provide.
I have an older (1990) Maytag dishwasher that had the same problem. In my case liquid dish soap had penetrated the seal and dried out causing the rotating cover shaft to freeze up.
Remove the door panel and then disconnect and remove the soap dispenser from the door. Make a diagram of the soap dispenser as you carefully disassemble it; there is a coil spring around the soap door axis. If you find a buildup on the door shaft or in the hole it rotates in or in the groove the door rides in, try removing the residue with a plastic scuffy pad after letting it soak in a lime scale remover (Lime Away) or some other cleaner. I think Jet Dry makes a dishwasher cleaner. Before you reassemble the dispenser, wipe a thin film of plumbers grease (available at Home Depot or Lowes) on the shaft.
If the door is free turning and doesn't appear to be bound up, then the problem may be with a heating element that expands when energized, allowing the door to open to the second soap compartment. An ohmmeter will be needed to test the thermal lock.
These jobs are fairly simple and should need only a Phillips screwdriver and a volt ohmmeter.
Happy Motoring!
Posted on Nov 24, 2008
You are in luck. I had to figure out a solution to this same problem tonight (same model). There are four screws running up each side of the inside face of the door. Remove those screws and you will be able to seperate the bottom door panel from the control panel. Reinsert the top two screws on each side loosely to keep the control panel from falling away. Once you have the bottom door panel off you will be able to see the cam assembly that controls your detergent door. If you carefully study its operation you will see that a spring on the left side (yours may be missing, hence the reason its not opening) holds the cover in its natural position by attaching in a hole in the black plastic peice near the top of the assembly, and grabbing a small "arm" on the side of the cam. When you close the cover, a metal U shaped clip catches the cam and puts tension on the spring. At some point in the wash cycle an electric charge causes that clip to jump away and the spring rotates the door to the other side.
My spring had come off and needed to be put back on. Fortunately, there is nowhere for it to go so it dropped out as soon as I took the door apart. I also had to remove the metal clip (actually I believe it is called a "bi-metal switch") and bend it back toward the cam just a hair to make sure that it would catch positively. Once you have the door apart you will see that this is an extremely easy fix.
Posted on Jan 20, 2009
  • 72 Answers
Assuming the dispenser is in the door... maybe take off the front door panel to access the inner workings of the dispeser to see if the spring is worn out or missing. otherwise, try a little WD-40 sprayed onto the hinges or moving parts.
Posted on Mar 06, 2007
Where is the rinse aid dispenser on a maytag performa?
Hello Chris.
The rinse aid dispenser is usually in the door right next to the soap cup, usually it has a round cap that you unscrew to refill. For me to be more specific reply with your model number as found on a label on the rim around the door and i will look up your exact model.
Gene
Aug 05, 2011 | Maytag Dishwasher
Wet dishwashing soap
make sure that the you let the hot water run for 2-3 min to make sure it is hot going into machine or it will not break down the soap.if the dispenser is opening then it is a tempproblem. let me know if my assistance was any help with a 4 thumbs up post
Feb 27, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Dishwasher does not rinse clean
run the dishwasher empty: use 1/2 the amount of soap you usually use in the soap dispenser close it then put white vinegar in the open dispenser and, run the dishwasher
Apr 22, 2009 | Dishwashers
Soap dish does not open during normal cycle on my maytag dishwash
the soap u use may be causing this try cleaning it out real good and use liquid soap
Apr 20, 2009 | Maytag DWU9962 Dishwasher
GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dishwasher - Soap Stuck in Cup If you have dishwasher detergent stuck in the soap cup after a full cycle, please check for the following conditions:
  • The water temperature should be at 120 degrees (140 degrees if your dishwasher has water heating capability). Check your water temperature Check your water temperature.
  • Make sure the soap cup is not blocked by anything.
  • Allow the dishwasher to fill and make sure it is getting a proper amount of water. The dishwasher should fill for about 90 seconds. On permatuf models, the water should measure 3/8" above the island near the center of the tub. On all other models, the water should measure about 1/2" below the heating element.
  • Check the lower spray arm for any blockage in spray holes or items that would restrict its turning.
  • Make sure the soap cup has opened at the end of the cycle.
  • Check the sump area inside the dishwasher for any restrictions.
Apr 09, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Soap dispenser doesn't open
My recommendation is to switch over to a tablet and merely put the tablet on the floor of the dishwasher bypassing the soap holder all together. It should work just fine that way. good luck.
Dec 29, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
410 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
