Question about Sony Handycam HDR-HC3 HDV Digital Camcorder
Shutter will not open/close (Disengaged from motor - "flopping" loose)
Hello FixYa's! Bertman here; Nicetameetcha! My HC3 is sickly - I bumped it on wood (not even hard) and the front shutters came loose and just "flop around". When I turn on the camera, I can hear the motors trying to open the shutters, then it tells me I can't record because "Lens cover not fully open. Turn power off then on." This of course does nothing to fix it - the shutters are mechanically disengaged from the motor that opens them. The unit is otherwise working perfectly. I want to open it myself if I knew how to unscrew the front and get the shutters reconnected. (It seems the "jumped the track" and just need to be re-set.) What say ye? Thanks! - Bert :o)
    Sergeant:
    Champion:
  • 326 Answers
Well, replacement of the shutter unit (lens barrier)instead of the repair seems more realistic... Please contact your nearest Sony Service for the price estimate. If you need more info please advice. Arpi
Posted on Mar 20, 2007
How can I open the shutter feature under ignition of my scooter Honda Metropolitan 2015
there is a shape on the side of the key that fits in the bottom part. If you line up the bump with the slot the right way, and turn it, the shutter will open
May 06, 2016 | Honda Cars & Trucks
Rear clunking noise when hit bumps
Could be
Exhaust pipe holder broken and pipe flopping when you hit a bump
Muffler too close to frame
Gas tank strap broken
Broken or shot shock absorber
Broken spring
With out being able see and hear it these are only suggestions.
Mar 02, 2015 | 2009 Pontiac G6
2006 harley street bobber. My transmission jumps when I hit a bump
Sounds like the main drive chain is worn and possibly slipping; it will flop a bit when hitting a bump.
If your drive chain is loose or the sprockets are worn this can happen also. If it is a belt drive check to see if the belt cogs (teeth) have good sharp corners, this could be slipping too.
WORST case scenario...worn bearings on the clutch end of the main shaft flopping about and slightly disengaging the main drive inside the clutch/ tranny box.
May 07, 2014 | Motorcycles
I'm getting error code E000584-0001
E584
Main Cause The shutter open sensor (PI5) is faulty. The safety area detecting switch
(MS3) is faulty. The shutter closed detecting switch (MS4) is faulty. The
No. 2 feed motor (M8) is faulty. The finisher controller PCB is faulty.
Mode of
Detection
0001 The shutter closed detecting switch does not turn on when the No.
2 feed motor has been rotated CCW for 1 sec or more.
0002 The shutter open sensor does not turn on when the No. 2 feed motor
has been rotated CCW for 1 sec.
0003 While the tray lift motor is in operation, the shutter closed detecting
switch is found to be off when the tray 1/2 is at OFF position
of the safety area detecting switch.
-David.
Nov 03, 2010 | Canon imageRUNNER 5000 Copier
External Microphone for Sony's HDR-HC3 camcoder
ECM-HZ1 Microphone is compatible as HDR-HC3 has Active Interface Shoe for this mic.
Apr 24, 2009 | Sony Handycam HDR-HC3 HDV Digital...
Help with "B" setting
You press the shutter once and that opens the shutter (you do your light painting) then you press the shutter a second time to close the shutter.
When you press the shutter the first time and look in the view finder it will be dark . this is because the mirror has locked its self up while doing the exposure (this is normal) Once you click the shutter a second time the mirror will flop down and you will be able to see threw the viewfinder again.
Jan 24, 2009 | Canon EOS-AE-1 35mm SLR Camera
Lens shutter one side is loose and flops
the only place i've ever seen that fixes small digital cameras like that is portatronics, but it's a mail-in business.
Jan 15, 2009 | Kodak EasyShare Z700 Digital Camera
Carousel error 8550dn
Hey there.
That indicates that the color toner carousel is not working
correctly. This could be caused by an obstruction in
the carousel path, such as a loose shutter or
disengaged toner cartridge.
Open the carousel door and waste toner tray.
Look for an obstruction, such as a toner
cartridge shutter catching on the waste toner
tray. Verify the toner lock lever is fully locked. If
the message does not clear after closing the
doors, turn the printer off and on to reset the
printer.
Mar 18, 2008 | Office Equipment & Supplies
Shutter won't open/close, and blank screen on "capture."
It prolly took a bump at some point or has crud inside...try cleaning it GENTLY with alcohol NOT WATER.
Aug 27, 2007 | HP Photosmart R727 Digital Camera
Shutter Won't Open
Well, replacement of the shutter unit (lens barrier)instead of the repair seems more realistic... The part number is: 178739811 Please contact your nearest Sony Service for the price estimate. If you need more info please advice. Arpi
Mar 09, 2007 | Sony Handycam HDR-HC3 HDV Digital...
Sony Handycam HDR-HC3 HDV Digital Camcorder Logo
318 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
