Question about Hobart A200 Stand Mixer
H600 I have two spare H600 motors that I no longer need, both new. Any chance I can sell them or trade them somewhere? I have tried ebay and craigslist but I think the motor is too specific. Can it be used for other things? Thanks and have a good one. Gary
  • cumedia Dec 29, 2008
    New they are $2,000 per and I am selling for $500 per. I am traveling through next week but will be back at the factory then. Gary
  • 49 Answers
I might be interested if its a bargain
Posted on Dec 29, 2008
What is the difference between a H800 and L800 mixer
I have used the H600. Nice piece of kitchen kit for hard use.
Model H600 is a heavy-duty 60-quart mixer which features a two-horsepower motor, a timer and a #12
Attachment Hub as standard equipment. With the use of bowl adapters and special agitators, 30- or 40-
quart bowls may be used on the H600.
Model L800 is a medium-duty 80-quart mixer designed primarily for use in general kitchen applications.
This mixer features a timer and #12 Attachment Hub as standard equipment and is powered by a
two-horsepower motor. With the use of bowl adapters and special agitators, 30-, 40- or 60- quart bowls
may be used on the L800.
A Bowl Guard is standard equipment on all H600 and L800 models.
A programmable timer controller is optional on H600 and L800 models.
These mixers can be ordered with a stainless steel finish.
A variety of attachments and accessories are available for all mixers. These are described in a separate Use and Applications Handbook, which is furnished with each mixer.
Here is your manual.
http://www.cvrsupply.com/manuals/hobart/Hobart_L800_Manual.pdf
May 07, 2016 | Food Mixers
What is hobart h600, single phase or 3 phase?
Not sure if you are asking if an H600 is automatically a single phase or a 3 phase and the answer is NO. Depending on the motor it will be 1 phase or 3 phase application. It will have 4 wires versus 3 wires -- hope that makes sense 3 of the wires are "HOT" on a 3 phase and only 2 are "HOT" on a single phase Motor.
Jul 09, 2014 | Hobart H600 Stand Mixer
Hobart h600 shuts off after running for a minute and then thermal resets
Check and see if your Vents are Open, you are overheating it and shutting down to protect your machine,. If it is not overheating then your Sensor is going bad. Clean it up and there is a better than average chance it will work much better...
Apr 09, 2013 | Hobart H600 Stand Mixer
I needed to know the PH for a h600 11344142 Hobart mixer... And is it a single Or 3 face??
Hello Jbabajanov,
I understand that you want to know about the HP (Horse Power) of a H600, 60 quart mixer and weither it is a single or three phase.
All H600 Hobart mixers are equiped with a 2 horse power motor.
As to wether it is single or three phase you will need to look at the service tag of the machine. If is listed on it weather it is single or three phase.
Thank you for choosing FixYa.com
Justin
May 13, 2011 | Hobart H600 Stand Mixer
I need a wiring diagram for the Hobart H600 which has a multi tap motor on and i would like to change the voltage on the motor to 200volt single phase 120/208 or even 120208 3phase. The wiring diagram is...
You cannot wire a three phase motor for single phase and you cannot wire a single phase motor for three phase. If you have a three phase dual voltage motor your options are 220 or 440 volts. If you have a single phase dual voltage motor your options are 120 or 240 volts. A 208 volt Hobart motor will only function correctly on 208 volts and is not dual voltage.
Aug 05, 2010 | Hobart H600 Stand Mixer
Hobart HZ (h600?) Raising handle is acting up
You will need to confirm the model number. An H600 or L800 have a wheel to manually turn to raise and lower the bowl. The M802 and V1401 hav a belt driven bowl lift clutch, operated by a lever. When you push the lever up or down, you are engaging a small transmission between the motor and main housing. You would need to remove the top cover and see what's happenning. It may be there is something other than the proper spiral pin joining the lift lever to the clutch input shaft, giving alot of backlash and insufficient selector movement.
Aug 18, 2009 | Hobart H600 Stand Mixer
Hobart H600 Double Pole Breaker
You need to get a new electrician; a real electrician would read the power requirements on the motor name plate and install the correct voltage and amperage circuit.
A single pole breaker does not supply the same voltage as a double pole breaker. It hums because the voltage is wrong
May 31, 2009 | Hobart H600 Stand Mixer
I need to change gear oil in Hobart H600 mixer.
Take the top cover off,where the front screw on the cover goes in that long shft has to be unscrewed,get a funnel and add oil.
Feb 19, 2009 | Hobart H600 Stand Mixer
Question about model numbers
Hi, the "T" means it has a timer, not sure the "D", digital maybe? There are a few Hobart guys on here, maaybe they will post, or you can call your local restaurant equipment dealer, thay should be able to help you.
Dec 31, 2008 | Hobart Food Mixers
Motor is burned out
Are you sure the motor is bad?
Dec 03, 2008 | Hobart H600 Stand Mixer
Hobart A200 Stand Mixer Logo
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
