Question about HP iPAQ RX3715 Pocket PC
Lost screen sensitivity
My Ipaq 3715 will not respond when the screen is tapped. I have tried resetting and restoring and this does not help. Is the screen it self bad? Any suggestions ?
It sounds like you've got some dust in the corners of the screen, here's what I did: 1. clean around the edges of the screen using a business card. 2. If you dare, try using some compressed air to clean between the screen and the body (very, very carefully! do not apply too much pressure). I had excactly the same problem and solved it this way.
Posted on May 24, 2007
    Novelist:
  • 198 Answers
Make shure the PDA didn't received any shock or something similar. Then try a master reset and then if it still doesn't work try a ROM upgrade. Download the ROM file from here: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=420450&prodTypeId=215348&prodSeriesId=457080&swLang=8&taskId=135&swEnvOID=2050 And follow the program's instructions. If it still doesn't work, it is almost shure that your touchscreen (digitalizer) has failed. This is a separate part from the actual display, you don't have to change the whole display. However it could be an expensive repair. I'm sorry for not being able to assist further.
Posted on Mar 06, 2007
On IPAQ hx2700, how do I do a hard reset? I want
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
How do you reset it to factory settings
To perform a soft-reset (if the device has locked), briefly insert the stylus or a paperclip into the reset hole on the bottom left of the 3715
To perform a hard reset (losing all data!), insert the stylus or a paperclip into the reset hole on the bottom left of the 3715 while holding down the far left and far right of the four main buttons. Information in the iPAQ File Store will not be lost, but data on the Internal memory will be wiped.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 30, 2009 | HP iPAQ RX3715 Pocket PC
Ipaq 3715 tapping problem
have you downloaded any viruses? if not try another hard reset is the screen cracked?
Jan 07, 2009 | HP iPAQ RX3715 Pocket PC
Hp ipaq 3715
Hopefully you can do a warranty repair, I'm pretty sure the main board is damaged since a hard reset should have taken you back to the factory defaults.
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
A soft reset stops all running applications, but does not erase any
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
To perform a soft reset:
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
loaded are stored.
functionality.
Oct 16, 2008 | Computers & Internet
Screen is locked
Mine hp ipaq also froze up, but I tapped the screen until they moved around all in alignment, and I got the basic things back (my programs, Media Player etc. but I can't sync it with my computer. It doesn't recognize the name of my handheld.
Aug 04, 2008 | HP iPAQ HX2755 Pocket PC
How do i play mp4 on my ipaq 3715
try converting the mp4 into either an mpeg or mp3
Nov 20, 2007 | Compaq iPAQ H3630 Pocket PC
IPAQ 3715 harware buttons don't work correct
perhaps your hardware problem should been taking to the lab/ you ca also select the uses of youe button from >setting>buttons> up and down control to be more sensitive.
Sep 11, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ 3715 - screen problems
Return it as faulty. WiFi should not impact your screens ability to stay on.
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
Hebrew Support for IPAQ 3715
Try Laridian.com They specialize in Bible and some language software for PDA's. Good Luck.
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
