Question about Acer Aspire 5600 Series 5630-6951 Laptop
I have an Acer 5610-2328 notebook. I need to clear CMOS. How?
I can't find the CMOS battery. I have taken the top plastic off the machine and some of the bottom plastic. I have a CMOS bios password trying to clear it. I can't find any information on which jumpers to bridge if any. Help, please! :)
  • 623 Answers
A CMOS battery usually looks like a coin. It is a silver lithium battery, similar to wrist-watch battery and is usually placed near the BIOS chip.
Some motherboards - especially laptops - have a different kind of battery.
They are simply a capacitor on its own board attached to the motherboard.
So in order to clear the CMOS you need to remove the capacitor and re-solder it to the motherboard, which you don't want to do without some electrician skills.
Posted on Dec 17, 2008
Cmos battery
Replace an Acer Extensa CMOS Battery
CMOS batteries allow you to store basic settings on your laptop.
If you notice certain features on your computer do not operate correctly, such as the computer clock, you may have to replace your CMOS battery.
This battery sits on the interior portion of your machine and measures about the size of a dime.
If you have a screw driver and know how to work with your hands, you can replace the CMOS battery on your Acer Extensa computer.
Open the screen of your laptop until you can view your keyboard clearly.
Find the bar that consists of plastic on the upper portion of your keyboard.
Place your screwdriver on one end of this bar and slowly ease it up until you can grab its edge with your finger.
Pull the opposite side of the bar in the upward direction with your screwdriver.
Then, ease out the whole bar.
Take out the screws on the side portion of your keyboard.
Pull your laptop keyboard upward and put it on a soft surface such as a bed or pillow.
Take out the four screws from the steel plate, which covers the motherboard of your computer, and take off this plate.
This allows you to view the CMOS battery, which sits on the lower right portion of your motherboard.
Pull the CMOS battery up from the motherboard and take it off.
Insert a new CMOS battery, which you can buy at a local computer store.
Put the parts of your computer back in the same manner as you took them off.
May 26, 2013 | Acer Extensa 5620-4020 Notebook
Step 1:
This might not be your laptop it might give you a guide into the cmos battery
The CMOS (Complementary Metal Oxide Semiconductor) battery saves basic settings on your computer. If the date and time function on your Acer notebook isn't working, chances are your CMOS battery needs to be replaced. Separate from your laptop's main battery, the CMOS battery is about the and shape of a coin and is located inside of your computer. Changing the battery yourself isn't the simplest task that relates to your Acer, but it isn't terribly difficult either. Here's how.
Open the notebook screen until you can easily access the keyboard. Locate the plastic bar that borders the top of the keyboard. Insert the flat head screwdriver at one end of the bar and gently pry it up until you can grip the edge with your fingers. Pry the other side of the bar up with the screwdriver and pull out the entire bar, being careful to mind the ribbon cord that connects the keyboard to the computer. Remove the two screws on either side of the keyboard that secure it to the computer. Slide the keyboard up and place it to the side. Remove the four screws on the exposed metal plate that covers the motherboard and remove it. You should now see the CMOS battery in the bottom-right-hand corner of the motherboard. Remove the battery by gently pulling it up and off the motherboard. Replace it with the same model battery (available at any computer store or online). Reassemble the computer the same way you took it apart. Acer TravelMate 6592G Keyboard Replacement Guide
Apr 01, 2013 | Acer Aspire One Netbook 8.9" Notebook
How to remove the bios password and the windows password
Step 1:
The Acer Aspire stores the password in a component called the complementary metal-oxide semiconductor. This component is integrated into a random access memory chip embedded on the motherboard. The CMOS holds data that the basic input/output system - a critical software utility that controls how the computer operates at startup - accesses when the computer boots. If the BIOS detects that a password is registered in the CMOS, it will prevent the computer from booting until the user enters the password correctly. Depending on which model of Acer Aspire you own, you may be able to clear the CMOS manually. Contact Acer before attempting to clear the CMOS, as opening the computer without permission could void your warranty. Desktop Models Some Acer Aspire desktop models come with a jumper that is used to clear the password and other settings stored on the CMOS. This jumper is located on the motherboard and is often found next to a label such as "JBIOS1" or "CLR_CMOS." To clear the CMOS using the jumpers, turn off the computer, disconnect the power cable and remove the case cover. Remove the jumper shunt from pin 1 and pin 2; then place the shunt on pin 2 and pin 3. Return the shunt to its initial position after 10 to 15 seconds. If the Aspire doesn't come with a jumper to reset the CMOS, the CMOS can be reset by removing the lithium coin-cell battery instead. Removal is accomplished by pushing down on the tab securing the battery to the motherboard and lifting the battery out of its slot. Leave the battery out for 24 hours, and then return it to its original position with the positive sign facing up. Laptop Models b> Resetting the CMOS password on an Acer Aspire laptop is much more difficult than resetting the password on a desktop. Disassembly steps vary from model to model, but on most models, you'll have to take apart the computer to access the CMOS battery. Don't take apart the notebook if you don't have experience disassembling PCs. After turning off the computer and disconnecting the AC adapter, take out the battery (different from the CMOS battery). All visible screws must then be removed from the bottom of the notebook. Remove all components stored to their separate compartments on the base of the notebook. Turn over and open the PC. Lift up the switch cover and remove the screws securing the keyboard to the PC, if any are visible. Remove the keyboard. Remove the screws securing the monitor to the hinges, and then set the monitor aside. Disconnect all visible cables connected to the motherboard; and then remove the screws from the top cover. Remove the top cover to reveal the motherboard. Locate and then remove the CMOS battery. Leave it out of the notebook for 24 hours; then reinstall it and reassemble the Acer Aspire. Other Options b> If removing the CMOS battery fails to clear the password, or if you don't feel comfortable with the idea of opening your computer, you might be able to gain access to the computer using a backdoor password. These special passwords were implemented to allow technicians to access locked computers. Not all models recognize backdoor passwords. Most Acer Aspires use the Phoenix BIOS, and backdoor passwords for this BIOS include "BIOS," "CMOS," "phoenix" and "PHOENIX." All of these passwords are case-sensitive.
Mar 26, 2013 | Acer Aspire One AOD257-1497 Atom N570...
How do I replace the cmos battery
Drop down to the 'paragraph' that starts with - Travelmate 200.
(200 in Blue)
Go down to the 7th line (5730 in Blue), scroll across, and click on -
6493 in Blue.
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (6493) it may take up to 30 seconds, before the first page comes up.
The file is downloading in the background.
The CMOS Battery, or also known as the RTC Battery, (Real Time Clock), is on the BOTTOM of the motherboard.
Scroll down a little to the two Large views of the motherboard;
1) The first view shown is the Bottom side of the motherboard.
Has the blue -
For Acer Travelmate 6942 6942G notebook motherboard MBTLN0B001 and tested+ree, above it.
Yes. TravelMate 6492, not TravelMate 6493. The RTC Battery is still in the same place.
Above the pink processor socket......see the Yellow round object?
It actually has wires coming from it, that end in a small white connector.
Not the same color, not the same series, but gives you a better look at this type of RTC Battery setup,
There is a little round watch type battery in that Yellow, and that Black plastic 'bag'.
Losing date, and time? Replace CMOS/RTC Battery.
Need to reset, or wipe out a BIOS password, or HDD password?
Not THAT way.
Go to Page 53. (Adobe Reader page number box at top)
Page 168 - Bottom View of motherboard - Number 13 in the chart -
CLRP2 - CMOS clear
(Clear CMOS jumper)
Instructions on Page 169
The Service Manual doesn't show the location of the CMOS battery.
DOES state it in Troubleshooting / Random Loss of BIOS Settings Page 148 at the Bottom.
Just an average laptop disassembly video I found. Skip to 3:40 or so to start.
You SHOULD wear an ESD wrist strap, and have it's aligator clip attached to a good ground source.
He is AT least working on a wood table top.
Perhaps some of these Acer pictorial guides will also help,
Could I be wrong about the CMOS Battery location?
Look down in the Battery Compartment for the CMOS Battery, or in a small hidden panel down in the Battery Compartment.
Also look on the top of the motherboard, once the Palm Rest Cover (Top Cover) is removed.
For additional questions please post in a Comment.
Oct 31, 2012 | Acer TravelMate 6493-6495 Notebook
I have an acer 4520 lap top. I can't get it to power up at all. When I push and hold the power button the green light comes on around the power button and the three lights in the upper right side flash...
first remove your battery and try to switch on your laptop with good power adapter if still have the same issue ?? just remove your memory and reinstall after clean your memory if still have the same issue ?? remove your memory and cmos battery and switch on it with a good power adapter.after 2 minute you can re install back your memory and cmos battery and try to switch on it.
Sep 14, 2011 | Acer Aspire 4520-5582 Notebook
Reset bios
You need to open your notebook remove first the battery and all screw at the back of your notebook. You can see there a CMOS battery together with the CMOS jamper. Just read it you can read CLRSCR which means clear cmos, just pull it with in 10 seconds and insert it back. Now you are done to reset bios.
Mar 30, 2010 | Acer Aspire 9810 Notebook
I need to replace the cmos battery where is it? how do i get to the cmos battery?
The RTC battery is inside the laptop connected by a two wire connector. it generally resembles a large button type battery. The laptop will have to be taken apart and the top panel removed to be able to get to it.
Dec 11, 2009 | Acer Aspire 4730-4947 Notebook
Clear bios passwort
Unplug the power, remove the battery, check the battery compartmnt, there should be a small screw or slot and a yellow or white or black plastic encased thin watch battery with red and black wires, you need to detatch it and attach back after 10 seconds. It will clear the CMOS settings including password.
May 20, 2009 | IBM ThinkPad T20 2647 Notebook
Acer Travel mate 517TE C MOS low battery warning msf at Power up
If you clear the cmos you are just loading the defalt bios settings but not solving the problem.
In this case you dont have to clear the cmos but instead replace the cmos battery.
Dec 12, 2008 | Acer TravelMate 517TE Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
441 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
