Question about Acer TravelMate 201T (91.44G01.4J4) PC Notebook
Acer Travelmate 201T most times no display
There is some light on the display, but no screen. Only sometimes (maybe every 7th time) it works. So the backlight works, but no signal to the display. The external monitor works all time.
Is it the inverter? Where can I get one. How do I test if it is the inverter (without another travelmate)?
  • gerrri Dec 14, 2008
    I have already checked the cable for the screen. It is tight. I only wonder why it sometimes works very well.
    Is it worth to replace the screen for such an old laptop? Where can I get one and how much will it be approximately?
    Thanks a lot
  • 116 Answers
If the backlight is coming on its not the inverter, check the ribbon cable for the screen itself, If its been opened and closed alot maybe be time to replace the screen. Check connections first, go from there.
Posted on Dec 11, 2008
  • Justin Washburn Dec 14, 2008
    Alot of times from opening and closing the lid the wires that run to the screen get brittle. Eventually the have a stresst break and the screen goes out. Usually these wires will make a decent connection every now and again bring the screen up, If the screen is moved the screen may or may not go out again. Same issue with flip phones, the lcd will eventually stop working for the same reason. Ebay is your best bet for find a barebones system dirt cheap, in terms of fixing it vs junk, that depends on the price of the parts, valeu of the system to the owner, and so forth. If its an older laptop that the screen even when its working is hard to vieew unless you are looking at it dead center, especially if theprocessor is under 800 mhz, it very well may not be worth the time and effort, now a days you can get a pretty good laptop for 600 to 1000 dollars. I cant really say whether or not it is worth fixing, that would be up to you. At the very least you could fix it, and if you decide to buy something better you can always auction it off as a working system, or sell it for parts. I know im going kinda back and forth, just suggesting options. If you decide you want to fix I can help you find parts, as for testing the inverter, if you see aslight glow around the edges all the times, regardless if there is picture or not, its not the inverter, occasionally i have shined a very bright flash light at a screen and been able to make out a picture, you cantry that, not a sure fire test method though, if you see a picture with a flashlight then its either the backlight or the inverter, the backlight in older systems is asmall thin flourescent/neon tube, they do get old, the inverter inverts the battery power from what ever dc volatge there is(12 to24 volts) to 1000 volts to power this lil tube, if you go to look at the inverter with the power on be very careful as the high voltage from the little inverter board will burn flesh and leaves a pretty good sting, if miss handled. Look for the glow around the edges first, then go from there.
Hi this is prince here from Bangladesh. i have a laptop that is acer travel mate 420. a few days ago its display is not working properly. some times it turn into various color. so what can i do?
Hi Prince, has your laptop experienced a squeeze or fall recently? I have a few suggestions. Plug another monitor into the VGA or DVI connection on your laptop. See if you are getting the same problem. If everything is working fine on the external monitor you would have eliminated the drivers being the problem. I suggest getting the LCD display changed. If your laptop is under warranty, you can get this done for free. However, if it is not under warranty you may have to replace it either yourself or take it to a local Acer specialist. If you chose to install the new display yourself, there are handy tutorials on removing and installing the screen on the Acer website. I have noticed that many times the Acer TravelMate Notebooks have experienced display issues. I hope you get your problem resolved soon.
Thanks for using FixYa.com!!
Apr 18, 2010 | Acer TravelMate 4200 Notebook
White screen on Acer Travelmate 7720
most likely you have a faulty LCD screen, the only option u have is to replaced it or u can use a external LCD screen to act as screen for your laptop. you'll be needing a VGA cable to connect your laptop to any LCD screen available.
Dec 16, 2009 | Acer Aspire 7720 Notebook
Acer Travelmate 4p20 Display problem
Try to reset LCD video connector, if you have already changed and tried inverter, then check lamp.
Best of luck.
Regards;
Hassan
Sep 03, 2009 | Acer TravelMate 4220AWLMi Notebook
How do i change the CMOS battery on an Acer travelmate 212T?
It may well be similar to the procedure for the Travelmate 201T, for which I happen to have produced a YouTube video showing the procedure... hope this helps!
May 30, 2009 | Acer TravelMate 212T Notebook
I need to reset the bios password
if u know how to open ur laptop, then after opening it. look for a jumper.
replace it & insert it after atleast 10sec.s. the password will be removed.
do let me know if that doesn't work.
thnkx
Jawad
Mar 15, 2009 | Acer TravelMate 201T PC Notebook
Acer laptop and data projector: no communication
i have faced the same problem before 2 days ago......now i solved that one....i load my pc in safe mode....i adjust the screen resolution.....and i removed lastly i installed new software (it was typing master --- leave it this one).......after that i tried to connect acer laptop to sony projector (FN+F5) it's working properly.....try this.......please
Mar 14, 2009 | Acer TravelMate 2300 Notebook
Acer 2410 display having 3inches wide black vertical line at the right end
Hi...there,
The problems.. your panel are damaged. Don't bother to replaced...will cost you a lots of $$$.... It's time for retired...
Oct 14, 2008 | Acer Refurbished 11 3 STN LCD DISPLAY **...
Acer travelmate 2350 take time to start (5 t0 30 minutes some times)
This is not any problem. B.coz if u have installed Vista Home Premium its take time after loging to display sacreen as pe your loaded software and drivers.
Mar 03, 2008 | Acer TravelMate 2300 Notebook
Help to repair ACER Travelmate 290LCi
this is normally motherboard or powe side problem check your motherboard
Oct 19, 2007 | Acer TravelMate 290LCi Notebook
Acer travelmate 4000 laptop Big problem
I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
Aug 23, 2007 | Acer TravelMate 2300 Notebook
Acer TravelMate 201T (91.44G01.4J4) PC Notebook Logo
110 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
