Question about Brother Office Equipment & Supplies
Knocking noise on mfc-8660 - Brother Office Equipment & Supplies
Brother MFC-9440CN Laser Printer knocking noise on startup and printing
Throw that piece of garbage out and get an HP or Samsung. One of these has plagued my office for years and I've spent countless hours plotting its demise. Worse than useless: unreliable.
Mar 25, 2014 | Brother MFC-9440CN Laser Printer
The engine has a nkockig sound..could this be caused by a bad knock sensor?
No it isnt a knock sensor the knock sensor job is to detect a knock noise and ****** timing. The knock that it is looking for is from octane or fuel or pinging that creates N0X s. A pollution gas. The knocking noise that you are hearing is different. If it is a multiple noise ar a rattling sound that will be the valves. There are other noises like a piston knock this knock is a sharp metallic noise, If the knock occurs only on acceleration that noise is a crankshaft noise. You need to check you oil level and make sure it is corrects. Look at the oil condition do you see silverish or whitish condition,is the oil deep black.
Apr 24, 2011 | 2004 Nissan Maxima
Wrinkled copies
Fuser unit is about the only thing in this model of printer that WILL cause wrinkling/creasing of the paper. So most likely, yes you are going to need to replace the fusing assembly.
Part# LU0214001K
About a $179.00
The vendor I use is precisionroller.com
Good Luck
Mar 04, 2010 | Brother Multi-Function Center MFC-8870DW...
I repeatedly get a paper jam inside the unit. I've used canned air to clean it out, the toner is pretty new, I can't figure out what the problem is!
Sometimes you have to actually turn the thing upside down to remove a piece of paper. It can be so tiny and cause a "paper jam". Look on the back of your printer and see if there is a "lock" door. If so, you may be able to get it out through there.
Sep 29, 2009 | Brother MFC-8660DN 5-in-1 Laser...
What does the drum look like.
Here is what the drum look like for the Brother MFC-8460n courtesy of Super Media Superstore:
http://www.supermediastore.com/toner-dr-520-drum-unit-brother-mfc-8470-8660-8670-8860-8870-comp.html?utm_source=googleBase&utm_medium=pcsite&utm_term=TO-001-2618-datafeed01&utm_content=datafeed01&utm_campaign=googleBase%20-%20TO
Aug 19, 2009 | Brother MFC-8460N All-In-One Printer
I lost my serial number for photoshop
You should be able to contact Adobe and let them know that you have an educational copy of photoshop elements. Just tell them that you got it through you school and they shouldn't give you any problems in getting a serial number. This would be a good starting point.
Jan 13, 2009 | Adobe Photoshop CS2
Grinding noise/paper jam
Fuser drive gear is a mission to install
Dec 30, 2007 | Brother MFC-8840D All-In-One Laser Printer
73 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
