Question about Xerox 5855C Copier
Xerox 5855C Copier
Dear Sir,
I am Technition, From India. I want need your help .Complante is Xerox 5855C Copier Fault Code -09-350 this error comming. Pleace send my email ID solution error resetting.I hope to your help
Thanks.
  • 239 Answers
This error can be missleading.
It may have to do with the NVM in the main board.
Check if the waist bottle is full in diagnostics. Clear this back to Zero.
Also check and see if the other settings have gone over threshold.
Presure roll, developer, Heat roll, Full sump bottle. Especially full sump bottle this can come up and stop the machine.
If anything else try to reinitialize the settings. Remember you need to have written down the values before you do this proceedure.
This is not an easy task to repair even for a Xerox service rep.
Let me know what you find.
Good luck.
Posted on Oct 18, 2009
    President:
  • Xerox Master
  • 990 Answers
It need to replace the connector in the toner cartridge
Posted on Dec 11, 2008
Xerox 7345 error code009-936 has been received. Please send the solving process.
Return to Search Results
Solutions for : Fault Code 009-936: More Than One Consumable is End of Life Fault Related Fault Code: 009-936 Solutions ranked by relevance:
  1. Make Sure All Highlighted Supplies Are Replaced
Have you found what you are looking for? Yes
Not Yet
Please Help
Dec 17, 2015 | Xerox Workcentre 7345 Printer, Copier,...
HOW TO RESET ERROR CODE 04-562
Not a copier guy here BUT came up with this
1) From here
http://www.copytechnet.com/forums/xerox/43094-error-04-562-workcenter-pro-c3545-print.html
It sounds like 'Image Belt Transfer' whatever that is.
'you can enter in serice mode on this model only with laptop and xerox wcp diagnostic navigator'
2) from Zerox here. http://www.support.xerox.com/support/workcentre-pro-c2128-c2636-c3545/support/enus.html click on fault code search , put in code.and......
'Needs further customer support.'
Sounds like a 'belt' inside the machine broken or faulty.
Hope this assists you.
Sep 16, 2014 | Xerox Copier Toner, C2128, 2636, 3545...
004 error code350
I am afraid that that foult code means that the machine's software has to be reloaded. The only way this can be done is by a qulified xerox tech. It need a laptop with special software to connect to the machine to do the download.
Nov 28, 2013 | Xerox CopyCentre C20 Black and White...
Error code 11-346 on xerox 5855c
This machine must have a stapler and a sorter.
Most common problem to fix it is to replace the main board inside the sorter.
Other problems are the sorter needs to be latched correctly so the actuator (steel pin) can actuate the closed interlock switch.
This sorter is usually pretty realiable, when a problem occurs, then it is really big problems. This would require the schematic to locate the other power circit boards to see where the sorter lost power.
Other possible problems can be an old NVM battery on the main board. (Date on the chip over 10 years old) When the battery is not good, this causes memory corruption to the values, machine setup configuration. The memory gets corrupted causing the machine to malfuntion.
Not seeing the machine, it is difficult to further trobleshoot the problem.
Sep 15, 2010 | Xerox 5855C Copier
Xerox 5855copier showing 03-326
Try cleaning the optics even if they seem to be clean
Apr 08, 2010 | Xerox 5855C Copier
I Have Xerox 5821 Star Copier and it got U6 error. Help me out
U6 code means that you have a problem with the exposure lamp or exposure lamp circuit working properly.Hold down the 0(zero) key while turning the unit on and punch in the codes 20 start 3 this will enable you to clear the code unless you have a permanent problem where a part has to be replaced
Apr 21, 2009 | Xerox 5100 Copier
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
Xerox error code u1-1 main motor fault
You will need to replace the main drive motor assembly.
That stepper motor is a common fail item.
You have to remove the rear cover, the MFSYS and MCU board assembly to access that motor.
Jul 09, 2008 | Office Equipment & Supplies
Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Jan 02, 2008 | Panasonic DP-150A Copier
128 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
