Question about Panasonic Lumix DMC-LZ2 Digital Camera
Black screen I also get a black screen when I turn on the camera. It just started doing it one day and never fixed itself. I can go to all the menus and can even view pix from a memory card. I just can't take pix (they come out just a black pic) or see anything, but black on the screen, the focus square and what mode I'm in! UGH!
  • Elizabeth Maranville Mar 09, 2007
    After gently tapping the camera, like advanced suggested, with the screen on I noticed a slight bit of light coming through to the sensor. I figured out that if I push up firmly on the extended scope/lens (whatever you call it) I can see everything I'm pointing at. Pain in the butt, yes, but worth it til I can afford a new digi!!
    Thank You!!!
  • Elizabeth Maranville Jan 31, 2008
    Just a little tip. If you fix it then aren't careful (say by accidentally tapping against something, or dropping it) you will have to go through the whole process again.
DarrenC was absolutely right. The ribbon at the top of the case is the culprit. The little black connectors on the sides of the ribbon where it connects to the board did the trick. I've had this same problem for about 6 months. I had to push on the upper right hand corner of the camera with one hand while snapping a picture with the other hand. But it really is so simple, 1. seven screws, 2. top ribbon, 3. black connectors! I'm so excited, thanks TerryB and DarrenC.
Posted on Feb 10, 2008
I followed the advice of TerryB and removed all (7) screws from the sides and bottom. It took a bit of effort to get the back off, and the door for the smartcard fell off with a metal brace. This revealed the PCB board. There are three yellow ribbons, but the one connected at the top connects to the lens/shutter and it is what came loose on mine. It was not obvious until I took a very close look. I pushed the black connectors back in, and low and behold it now works. Thanks TerryB! It took a bit of effort to put the PCB board back together, but it all fits from the inside.
Posted on Nov 20, 2007
  • dobicraz Aug 03, 2011
    I totally agree with Darren's fix!! But i really had to look closely!! at the top ribbon to see that it was loose, it really wasn't until I moved it further off and then pushed it back on that I could tell how far it was really out. Thanks so much to everyone for their input, so happy I dont have to replace my favorite camera!! WendyL
I took the advice of taking the screws off and just fixing the orange cable, it is the orange cable that is alone by itself, not the one that is next to the black and red one that controls whether the image is black or where you can see it. I was afraid to tamper with anything, but I went to the 99c store and got a little "precision tool kit"with about ten little screwdrivers,and unscrewed all of the screws on the outside case, then took the back off, the orange wire next to the black and red cable came out. I then focused on the orange cable by itself and just took it,and with the flat little screwdriver, put the black thing behind it back in, BUT did not push it all the way in, then i slid the orange cable on top of it and slid it into place, and then pushed down one side of the black thing to secure the orange cable in place, Then I put the other orange cable back and the red and black cable back, and tada! Camera is as good as new!!!!!!!!! I could not believe it,with 99cent supplies, 10 minutes, and some patience, I fixed it and saved so much money. I do love this little camera, I record videos with it as well. Thanks for the tip it was awesome, I love taking videos of my son!
Posted on Jan 30, 2008
I had the same problem and I just fixed it myself!
I: (1) removed the six screws from the camera; (2) opened it up; (3) simply jiggled the orange ribbon cable; (4) made sure the internal plug-in was in tight; and (5) closed the camera and put the screws back in.  As soon as I turned it on, IT WORKED!!!
Good luck!!
P.S.  I found this solution somewhere on this Fixya.com site, but I can't relocate it.  THANK YOU to whomever posted it!!
BTW, I originally took the camera to the camera store and they told me they would have to send it away for repair, and that I was looking at anywhere between $100-150 to fix.
~CameraGirl!
Posted on Oct 13, 2007
Number 7 solution worked beautifully. I was visiting grandchildren and was so frustrated when my black screen appeared. Tapping the camera gently was the solution! Hooray! grateful grandmother
Posted on Apr 05, 2008
  • 53 Answers
If any of you need parts for your LZ2 there is a guy in South Carolina who has good used parts. I got an LCD for $49.00 and it works like new. I think his email is gerald.ray@aa-ark.com
Posted on Mar 12, 2008
Thank you for solution its work whell on mine ..this the orange ribon on top .just push it than it work again . isave 100 box thank and happy new year
Posted on Jan 02, 2008
Wow!!! Thank you. Terry B and DarrenC. My camera worked fine for two years, then I couldn't capture an image. However, I could review old photos, so I knew that some part of the camera was working. I followed the suggestion above. .I removed the 7 screws, and then carefully inserted the orange ribbon on the top. This produced a fuzzy image. I then taped the ribbon on the bottom a bit, and the camera was able to capture an image. This is great. My camera now works fine.
Posted on Dec 11, 2007
Thanks for the idea of tapping on shutter. Both my kids received the DMC-LZ2 as gifts over a year ago and both experienced the black screen issue within 6 weeks of one another. By tapping on one of the cameras, I can get a picture on the LCD. The other camera just can't get a full picture. At least one is operable!
Posted on Sep 25, 2007
    Novelist:
  • 107 Answers
Your camera's shutter has stuck closed. Normally the shutter is open while you compose the image, and when you hit the button it will close allowing the image sensor to record the image at that moment. When it is stuck closed no light can reach the sensor, and there is only black on the screen. Sometimes you can free the jammed shutter by GENTLY tapping the camera on a hard surface. Be very careful, this can damage the camera further if you are not cautious. If the tapping does not free the shutter the camera will have to be serviced by a professional. Check with your manufacturer to see if there are recalls or technical bulletins pertaining to your camera. Failing that there are repair services online who can work on your camera. David Millier Advance Camera Repair
Posted on Mar 06, 2007
MY CANON G10 DOES NOT SHOW AN IMAGE ON THE SCREEN ON THE BACK OF THE CAMERA?
Known issue!
G10 => Dead Black Sceen ! (only on screen infos): Canon PowerShot ...
https://www.dpreview.com/forums/thread/2639340
  1. Cached
Aug 13, 2009 - 11 posts - ‎4 authors My G10 is dead a few days ago, in a middle of a trip... (can't explain my ... Does the camera take pictures and can you download them to your computer? Then your sensor is OK and ... No cover on lens, and tried every display mode, you can trust me. ... (and even on, I will not have a permanent black screen). PowerShots can't do purple!?: Canon PowerShot Talk Forum ... 29 Dec 2013 G11 Date & Time Issue: Canon PowerShot Talk Forum: Digital ... 31 Jan 2010 G10's LCD dims when held in vertical position: Canon PowerShot ... 16 Nov 2008 G10 Can we adjust in camera parameters like sharpness for JPG ... 16 Nov 2008 More results from www.dpreview.com
A Simple Fix for a Stuck Shutter 'Do It Yourself Digital Camera Repair
camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
  1. Cached
  2. Similar
May 30, 2009 - Would not recommend trying to open your cameras to repair this ... Also turn off the LCD screen (press the DISP or DISPLAY button). ... For many Canon cameras this will be shutter priority (Tv) mode (for .... I got the image back in about 5 tries. .... My Cannon S2 IS had a black picture and I fixed it from your ...
Canon G10 screen is black
www.lionebra.com/canon...g10_digital_camera/q1947687-canon_g10_screen_black
  1. Cached
Canon PowerShot G10 Digital Camera - Canon G10 screen is black- ... with the menu,changed something and now the screen does not show image of anything. ... has problem in CCD Imager and this part will be replaced to get back picture. ... E18 my canon powershot A150, got the whole E18 problem, it turns on with the ...
Canon Powershot G10 image quality problems... I have had my Canon ...
www.lionebra.com/canon...g10...camera/q4217842-canon_powershot_g10_image_q...
  1. Cached
Canon PowerShot G10 Digital Camera - Canon Powershot G10 image quality ... They are not coming back with a completely blank screen as I can see the ...
Digital camera repair - Digicamhelp
www.digicamhelp.com > Digital camera care > Digital camera repair
  1. Cached
  2. Similar
Digital camera repairs can be expensive if not covered under warranty or a service advisory. ... When a sensor goes bad, images may exhibit some or all of the following: ... Hard reset for Canon compact cameras: this has worked for some Canon ... a blank LCD screen, a stuck lens or sensor or other problem that can't be ...
S2 IS "black screen *****" problem: a SOLUTION! ' Canon PowerShot ...
https://www.flickr.com/groups/26928900@N00/discuss/72157606903408401/
  1. Cached
  2. Similar
Aug 23, 2008 - My 1st Canon (film) camera was a TL and I'd probably still have it but ... The "change the batteries" problem: Does any S2IS *not* have the ... A couple of weeks ago i turned on my dear S2 IS and.. no image!! i could only see the menus .... Actually, I had to do it 3 times before the screen got back the image.
Nov 24, 2016 | Canon PowerShot G10 Digital Camera
How to fix screen?
It sounds like you may need a new LCD screen or lens. I'm having similar problem with a white LCD screen on a Canon camcorder, but it still records video, I just can't see what's in the frame or access menus. Does yours still record video? If so, it is the LCD screen.
May 29, 2013 | Sony Handycam CCD-TRV608 Camcorder
READ MENUS FINE, LENS OPERATES FINE, OTHER STORED PHOTOS READ GOOD, BUT CAMERA SHOOTS ONLY BLACK FRAMES, NO SCREEN IMAGES WHEN SETTING UP A SHOT. WHEN HELD UP TO THE LIGHT THROUGH THE LENS, A FAINT GRAY...
woowww man i think youv got a lot probs with you camera,mainly if there is a a black frame in you screen i think your screen monitor is damaged so ull have to replace it...... and da black frames is a fault in da camera itself.according to wot i understand i think the shutter speed is not corresponding with da software in da camera um sorry but dese repairs are gonna cost ya.... best tin is to give it to a repair shop or service personnel for further clarification
May 30, 2011 | Cameras
N i turn the camera on, the screen is black...
If you can view photos from the camera's memory then the camera shutter is likely stuck in the closed position. Some owners have reported a "fix" by firmly tapping the camera on a solid surface, but that can also cause more damage.
If the screen is always black, the display itself is the likely culprit, and it will need to be replaced.
Either problem can be repaired, and I suggest that you take the camera to a local Kodak dealer (INOT the camera department at a chain store) or contact Kodak customer service via the Kodak.com web site to arrange repairs. Be sure to get a firm price, not just an estimate, before you commit. The cost of the fix can easily approach the cost of a new camera, and repairs typically only carry a 30-day warranty.
BillB
Feb 08, 2010 | Kodak EasyShare C713 Digital Camera
I have a Cybershot DSC-S780
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jul 07, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Black screen
Try cycling through the Display button until you're able to view photo to be taken.
May 06, 2009 | Sanyo VPC-S500 Digital Camera
Black Screen
Do more internet searches of your model. Sounds like the sensor chip died. Pretty expensive part. Could have not liked the salty environment or you are just unlucky. Do the search until you give up as there is a lot of info on internet. Cameras are getting pretty cheap now so if it is a little old or cheaper model, you may do better with a forced "upgrade".
May 20, 2017 | Nikon COOLPIX L18 Digital Camera
Sony T3 cybershot screen black
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=7&NAVDISP=di
Mar 11, 2009 | Sony Cyber-Shot DSC-T3 Digital Camera
BLACK SCREEN, OLYMPUS FE210
You must go to a camera technician. There are some parts inside that already been loosen. That's what happened to my camera before.
Feb 16, 2008 | Olympus FE-210 Digital Camera
Black Screen
Lenses may have dust trapped I found when I wiped it with a dry paint brush it cleared this problem however rembember that a brush will also push dust down futher so when it did this a 2nd time I actually gave it a tap on the bottom of the camera and so far touch wood it works fine. hope this helps
Dec 04, 2006 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
902 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
