Question about Amana AER5515QA Electric Kitchen Range
Attempted to set oven to 350
I have an Amana range model AER5515QAQ I cleaned it for 2 hours after which the bake light kept flashing upon reading the manual it said to hit the cancel button which I did but it continued then it said to turn the power off and back on and that fixed the problem. A few days later I attempted to set the over for 350 but the preset never happened. It just started at 350. Normally it starts at 100 then works it way to what I have set it for. Need to what might be causing the problem
  • 1 more comment
  • blmcph Dec 14, 2008
    I turned the power off for 10 minutes if that is what is meant by a hard reset and it did not work.
    Yesterday morning I turned it on to see if it would work and it started at 250 and when it got to 350 the buzzer when off and it stayed warm for a little while then it got cold again.
  • blmcph Dec 16, 2008
    I unplugged it for a whole day and it is still doing the same thing.
  • blmcph Dec 17, 2008
    I found out that the board is bad and it needs a sensor. So I have solved the problem.
    Master:
  • 416 Answers
Anothr reason might be that capillary tube (the tube attached to the oven wall that senses the temperature in the oven and activates the control that adjusts the temperature) may be out of adjustment.
If the oven doesn't hold the selected temperature, you need to check the capillary tube and test or recalibrate the temperature control
It can be done folowing this:
But you need to find someone who can operate with multimeter.
Test and replace the temperature control:
  1. Unplug the oven or turn off power at the electrical service panel .
  2. Open the oven control panel by removing fasteners or clips around the perimeter. If any of the terminals appear discolored or burned, replace the temperature control (steps 7 through 9 below).
  3. If the control has more than two terminals, identify which terminals to test, using the diagram located on the rear panel, inside the storage drawer or control panel, or in the owner's manual.
  4. Set a multimeter to RX1 (resistance times 1). Disconnect one wire from the terminals being tested, and clip on the tester probes. Set the oven temperature dial to 300°F.
  5. If the multimeter doesn't indicate continuity, replace the control following steps 7 through 9, below.
  6. Remove the capillary tube from its supports in the oven and push it through the rear wall. Then, from the back of the range, pull the tube out of the oven.
  7. Unscrew the two temperature control screws in the front and remove the control from the back of the range.
  8. Label and disconnect the wires, replace any burned wire connectors.
  9. Connect the new control and screw it in place. Push the capillary tube through the back and into the oven, then clip it to its supports.
Test and replace the oven selector switch:
  2. Open the control panel (see above) and set a multimeter to RX1 (resistance times 1). Disconnect one wire from each pair of terminals being tested, and check for continuity in each position.
  3. To replace the switch, remove any screws from the front of the control panel and pull the switch out the back. Label and disconnect the wires.
  4. Replace the switch with an exact replacement part
Calibrating oven temperature:
Some ovens have a calibration ring on the back of the temperature-control knob. On others, temperature adjustments are made with a screw inside the control-knob shaft. If the capillary tube touches the oven wall, reposition it on its support clips. If the capillary tube is damaged, replace it and the temperature control switch with exact replacement parts.
  1. Test oven temperature with an oven thermometer in the oven and by setting the temperature control to 350°F. Wait 20 minutes, then check the temperature every 10 minutes for the next 40 minutes and calculate the average.
  2. If the result is off by less than 25°F, the control is normal. If it is off by 25° to 50°, recalibrate the temperature control with the following two steps. If the temperature is off by 50° or more, replace the control.
  3. Remove the oven control knob.
  4. If the knob has a ring with marks indicating decrease and increase, loosen the screws and turn the knob to move the ring in the appropriate direction, then retighten the screws.
  5. If there is no ring, hold the control shaft still with adjustable pliers. Insert a thin screwdriver, and chip away the factory seal. Then turn the inside screw clockwise to raise the temperature or counterclockwise to lower it. A one-eighth turn should adjust the temperature about 25°.
Good Luck
Posted on Dec 16, 2008
  • 365 Answers
    President:
  • 2,110 Answers
This maybe due to a dirty filter or dirty evaporator coil
It might require replacement..
Posted on Dec 14, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls try again the unplug from the mains or switch off the breakers for an extended period of time. To determine if a hard reset was accomplished, the clock should reset likewise to 12, if not and near to correct timeid displayed, then the reset never took place.
Additionally, you may want gleam additional insight from a solution posted by another member of this community, aborcass, at this problem where he posted:
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Good luck and Thank you for using FixYa. Happy Holidays.
  • 470 Answers
Heres the code my dear, F5 indicates the control felt a loss of power. I generally check the oven sensor for resistance (1040-1090 Ohms @ 770F). If the sensor is within normal limits, the control is bad. this is the proper step my dear to use the oven properly......
1.First, you need to determine how far off in temperature the oven is set. Get a good quality digital oven thermometer, install it in your oven, and set the oven to 350 degrees F. When the oven indicates it is at the proper temperature, check the reading on the thermometer.
2.Once you know how inaccurate your oven is, you can attempt to adjust it. If your oven has a calibration gauge right on its knob, you can attempt to repair it. If it does not, call a qualified appliance repair person.
3.Remove the oven temperature knob by pulling it from its shaft.
4.Take note of the current setting, and move the directional arrow in either direction to adjust the temperature up or down. You may have to remove a few screws to do this. Moving the arrow one notch usually adjusts the temperature by 10 degrees.
regards JAN_yuanjia
    Genius:
  • 2,920 Answers
Try unplugging the stove for about an hour to see if that wont reset the timer.usually that woks for me as mine had the same problem and now it works fine
    Sergeant:
    Champion:
  • 435 Answers
Hi, try the hard reset. switch it off and disconnect the power for ~10 mins and then switch on and see.
I have Super capacity ultrabake system electric won't turn off.
I had this with my oven, it just kept getting hotter and hotter. Had to replace the whole control panel. Mine was a Kenmore but I suspect they are similar.
Apr 10, 2010 | KitchenAid KERC607 Electric Kitchen Range
I have a matag cre9600cce, the oven heats, but very slowly and not all the way. i set it to 350 and after an hour it is only at 210
the cre is elect so look for one of the elements not working / ( bake ) is probably is out . and the pre heat is only from the top element .. / test by open door ser to bake bottom element should go red / then set broil and it to should turn red . the one that does not repl .. mm
Dec 12, 2009 | Amana ARGS7650SS Gas Kitchen Range
Maytag oven overbakes or burns bottom of cookies, biscuits
Try this first, if the temperature is off contact me.
Put an oven thermometer at the center of the oven and set the oven to 350 degrees F.
Check the temperature indicated on the thermometer after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Apr 25, 2009 | Amana AER5515QA Electric Kitchen Range
Broiler will work, but oven wont
Could be the bake igniter is bad and broil igniter is still good. may need to replace the bake igniter you will need a complete model number off range to determine the part number of the igniteryou may need.
Jan 07, 2009 | KitchenAid KGST307 Gas Kitchen Range
Amana Range, Electric wont bake or broil
the fact that the time keeps flashing is odd, an you set the clock?? and if so does it return to blinking again???sme stoves wont allow proper operation of oven without the clock being set.
Mar 23, 2008 | Kitchen Ranges
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Cannot figure out how to make oven work
Hi, try this and see if will help you. Most of the Gemini models are the same.
To set Bake:
1. Press the Bake pad.
• BAKE will flash.
• 000 will flash in the display.
2. Select the oven temperature. Press the
Autoset 0 pad for 350° F or the appropriate
number pads.
• Each additional press of the Autoset 0 pad will increase
the temperature by 25 degrees.
• The oven temperature can be set from 170° to 550°.
3. Press Bake pad again or wait four seconds.
• BAKE will stop flashing and light in the display.
Nov 20, 2007 | Maytag MER5775Q Electric Kitchen Range
Oven will not heat past 220 degrees
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
May 06, 2007 | Amana AER5515QA Electric Kitchen Range
Amana AER5515QA Electric Kitchen Range Logo
88 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
