Upgraded to firmware V5.02, Start button does not work and home button blacks out the screen, although the power stays on!,
When I try to enter (type ) Information "DATA", I Can't access the keyboard .Upgraded to firmware V5.02, Start button does not work and home button blacks out the screen, although the power stays on!,
You can't post conmments that contain an email address.
upgrading/downgrading or installing CFW in PSP is a risky business. the rule of thumb is to know if you have hackable or unhackable motherboard. if you had 5.03 chickhen before, then most likely you have a PSP-3000 or PSP-2000 v3 which has unhackable motherboard. you should have just installed 5.03 Gen-C or CFW Enabler 3.70, or upgraded the OFW to 6.20 and installed 6.20 TN-E or 6.20 PRO-B. 5.50 Gen-D3 is for hackable motherboards like PSP-1000 or early versions of PSP-2000. you have bricked your PSP!!!
for more details, check out sites like pspslimhacks.com, pspcustomfirmware.com or qj.net.
PSP Custom Firmware 6.35 PRO-B4 has been release by Virtousflame (a.k.a liquidzigong) and coldbird. The latest release includes a few bugs fixes for better stability and compatibility for all model PSP System (PSP 1000, 2000, 3000 and PSP GO - N-Series) .
This CFw has works on Sony firmware (OFw) 6.35 to lets users play backup UMD's - ISO games, so if you're already on OFw 6.35, you can either use this, If it doesn't, you will need to update your PSP firmware to 6.35.
Required :
PSP-300x or PSP-200x TA-088v3 or PSP GO has Sony Firmware '6.35' installed. other firmware is not supported. If you don't have PSP 6.35 installed, you need to update it.
Version check: On the PSP Menu (also known as XMB= Xross Media Bar), and goto 'Settings Menu' >> 'System Settings' >> 'System Information' and you should see firmware version of your PSP.
An Memory Stick at least 32mb for OFw update & CFw 6.35PRO-B4, ( Internal storage for PSP GO ).
Installation Instructions : Note: This software is free, and comes with no warranty, it has been tested and it has work, however I am not responsible for any bricked, so please try this at your own risk!. If you're afraid of risk of brick, don't try to downgrade. Read more...
it think that you should have a higher ofw or cfw ps ofw is original firmware from sony and cfw is costum firmware or a hacked firmware but you need a memory stick if you will have a cfw you can find cfw's in warez-ghost.com and write in the promoter blackpoison123 and thx...
Because you are using an Official Firmware(OFW) try downgrading to a 5.00M33-6 Custom firmware(CFW) you can easily do this with a pandora battery which will install 5.00 OFW on your psp and then you simply download the 5.00m33-6 CFW update OR download 1. Hellcat's Recovery Flasher 2. 5.00 OFW it is 25.83MB
install the Hellcat's Recovery Flasher on the psp and put the 5.00 OFW on the psp This files should be put in this directory PSP/GAME
open the Hellcat's Recovery Flasher in the memory- stick of the Game section when the psp is on
for you to upgrade your psp, you'll have to connect your psp to your computer and download the update from sony's website. http://www.us.playstation.com/support/systemupdates/psp, visit the lik and update your psp.
check battery, run without the battery, using ac adapter, see if problem persists
did you update psp firmware?
if so, undo the update, go back to previous firmware version
Is it possible to put a new software in it or unbricked it? And how can I fix it?
