Question about Toshiba MV20FM3 20 in. TV/VCR Combo
TV VCR combo Toshiba MV20FM3
The vertical deflection is overdriving at the top of the screen causing horizontal lines superimposed on the top 4 or 5 inches that are a reflection of what should normally be at the top of the screen.
SOURCE:
skippy101
  • 143 Answers
SOURCE: Toshiba TV?VCR combo problem
you have bad caps in the vertical curcuit if you open it up you will see a smallmetal square ground sheild in there you will find two red caps look at them very carefully one will be wet it is leaking replac it
Posted on Nov 02, 2007
SOURCE: LOSS OF T.V. PICTURE
My television has sound but no picture. I can not program the television because I can not see the screen menu. I also have tried to change the antennae but this does nothing to the picture's reception.
Do you have any ideas to correct this problem. There is no warranty.
Posted on Feb 03, 2008
SOURCE: 20 INCH TOSHIBA DVD VCR COMBO, DVD KEEPS READING BUT NEVER DOES
I was having the same issue and I've been to several video stores to rent DVDs and 2 out of 3 rentals have the same affect where it is just 'reading' but even worse, it would play fine and then freeze up during the movie- very frustrating. Now, after 3 years of owning it, it died today. They just don't make them the way they used to :(
Posted on Apr 04, 2008
  • 4 Answers
SOURCE: Screen white line problem.
There are two capacitors in the vertival output circuit that need replaced
Posted on Jun 19, 2008
SOURCE: White lines accross top of screen on our 27 inch Toshiba,
My Toshiba required replacement of two of the vertical filters/capacitors. Doesn't take long and the parts are inexpensive, but requires a repairman.
Posted on Sep 12, 2008
I have a tv that has line going side to side
The line is horizontal but means no vertical deflection (set deflects picture from middle to top and bottom.
Either bad solder connections at vertical output chip or a bad part somewhere in that circuit.
Jun 16, 2012 | Toshiba 26 inch HD monitor TV, DVD and VCR...
My screen has one line going across the middle.
The problem is a vertical deflection issue, caused by bad connections on the vertical deflection ic, or needs to be replaced and one or two bad capacitors.
Mar 17, 2011 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
One line horizontal onscreen
This is well known problem with the Toshiba line, the problem is in the vertical deflection circuits, it causes the picture to collapse to a flat white line, the vertical output ic and two to three capacitors need to be replaced to correct the issue.
Jan 19, 2011 | Toshiba MD20F51 20 in. TV/DVD Combo
There is a line down the center of the screen
whether the line-shaped vertical or horizontal? if it appears a horizontal line on your side, it signifies the vertical rays do not exit the screen or your TV vertical part is not working. damage can be caused by IC Vertical, or in the vertical deflection coil yoke.dan if a line that appears is from top to bottom that indicates the horizontal section is not working, usually there is a problem of the deflection yoke is not connected or defective.
Jul 11, 2010 | Televison & Video
The picture is just small line in the middle of the screen , still as sound
Hi, if the line is from top to bottom, that is the horizontal circuit transistor problem;/if the is left to side that is vertical deflection ic driver and some capacitor to replace and verify soldering arround
needs to be fixed by a real tech..
have a nice day
hope that will help you.
Apr 07, 2010 | Sylvania 6727DE 27 in. TV/VCR/DVD Combo
Where are the vertical deflection caps located
Check C421, C427 and C429. These capacitors are located nearby IC401. IC401 is mounted on a heatsink and has the following markings on the body LA78041
Feb 11, 2010 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
I have a three year old model pvc2542 tv/vcr combo the picture is just a line in the center of the screen
Bad vertical deflection circuit, unless you have a bad connection (bang on set to set it it fills out for a second) . you will need components replaced such as the IC, capacitors possibly a fuse from the power source to the vertical IC.
If its a bad connection soldering the IC pins is not to hard if you are OK with taking it apart yourself.
gd lk
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 21, 2009 | Televison & Video
My screen become blank, one thin Horizontal bright line in middle of the screen appears
You have what we call 'frame collapse'. This has many causes and without fault finding, I cannot pin point the exact location of the faulty component.
Feb 13, 2018 | Toshiba MV20FM3 20 in. TV/VCR Combo
Toshiba 32A14 horizontal line
This symptom is characterized by a thin horizontal line in the middle of the screen. This symptom is caused by the absence of the deflection sawtooth current in the horizontal deflection coil.
The trouble is easily isolated by a continuity test and by checking the most likely defective components such as A)open vertical linearity compensation transformer, B) open capacitor and C) open horizontal deflection coil.
Be sure to decrease the brightness first before trouble-shooting if the line is very bright,as it burn the phosphor screen..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 19, 2008 | Toshiba 32A33 32" TV
Toshiba MV20FM3 20 in. TV/VCR Combo Logo
44 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
