Question about Dell Dimension 4600 PC Desktop
Ethernet Problem Like in a recent post, I am having problems with the Dell ethernet drivers. (from the Dell site) After reformating, all drivers worked accept the network drivers. After fresh install, installed the chipset drivers, then video, then network. It showed a limited connection, Then I tried making it a static IP since the "ipconfig /all" showed me no DNS. So I pluged my other PC and retrieved the IP info in full. Then pluged in the Dell and entered the ip info. Then it said it's conflicting with a another IP on this system??? Any ideas??
    Scholar:
  • 47 Answers
DJDXL, it sounds like when you copied the IP settings from the other computer on your network, you copied the Static IP address from that computer as well. This is most likely the reason you're seeing the conflicting IP address - they both want to be 123.123.123.123 (insert your own IP address here). You should change them so they are using different numbers on the final set of digits - for example, 123.123.123.121 and 123.123.123.122 - the last numbers must NOT match, but the first three sets should match.
Give that a try, hope this helps!
Posted on Jun 10, 2008
    President:
  • 2,961 Answers
If it is telling you there is a conflict the drivers are working it is the properties of the network card that are incorrect. Click Start>Run, then type ipconfig /flushdns then press enter.(note the gap between ipconfig and the /). Go to the properties of your network card and on the TCP/IP line click properties and tick 'Obtain ip address automatically'
Posted on Mar 06, 2007
I cannot get ethernet connection from BT hub 3.0 on my dell inspiron 5160
try connecting through an ethernet cable. see what happens. Install the appropriate modem driver and network driver from support site.
post your comments if solved/not solved
Hope this helps
Dec 22, 2012 | Dell Inspiron 5160 Notebook
Driver for ethernet
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
if these driver packages aren't right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
you might have to search/try a few times to get it right
IE: motherboard name ethernet drivers or lan drivers
hope this helps
Sep 18, 2012 | Dell J0592 / 0J0592 DIMENSION 4550...
I find it difficult to download ethernet contller
http://support.acer-euro.com/drivers/notebook/as_4520.html
Go to this Acer site above, and download your Ethernet adapter, always install as Administrator.
Apr 27, 2010 | Microsoft Windows XP Professional With...
Reformated my Dell Dimension 2400, now under device manager I got the big yellow question mark for Other Devices - Ethernet Controller -PCI Simple Communications Controller Dell's driver support page does...
If you have windows Vista simply Right Click on the entry in device manager and choose Update driver (Requires working internet connection)
Else use the following drivers (Works on XP and vista)
ftp://ftp.us.dell.com/network/R64645.EXE
Oct 16, 2009 | Dell Ethernet Card Network Adapter
No ethernet controller device found
If you went to support.dell.com and keyed in your service tag from the Dimension - dell should allow you to drill down and select the correct one.
Sometimes there are a few - usually from the month to month the machines were made the drivers can be different.
I have had to open the case and get the model number off the device before
Jun 17, 2009 | Dell Ethernet Card Network Adapter
Dell gx270 ethernet controller driver download
This is the driver page for the GX270 over at Dell, go to the Network tab (after selecting your OS) and should need the Intel Network Driver listed there.
If you have any problems please post under this thread so I can further assist you.
Apr 14, 2009 | Dell OptiPlex GX270 PC Desktop
Ethernet driver
Note the Service Tag of the the PC and access the Dell website from another PC. Go into the support section of Dell website, select Download Drivers, and enter the service tag of your PC.
You should be able to find the ethernet driver for it (if there are 2 or more download both and save to a CD or USB memory stick.
Now go to your Dell. You should be able to run the program from the USB stick and it will restore the Ethernet connection.
Do the same for other drivers you need, sound, graphics, etc.
Jan 06, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Ethernet controller
More than likely this is the one that you need. It is for a Broadcom NIC. If that one doesn't work, they have this one for a Gigabit NIC listed here. I would start withe the integrated NIC divers. Both files have download instructions on the page if you need it.
Hope this helps. Please remember to rate this information.
Thanks
Jan 05, 2009 | Dell Dimension 2350 PC Desktop
Ethernet adapter
POST the ethernet card details and OS on your system. I will help you with the drivers.
Jan 08, 2008 | Acer Aspire T690 (AST690UP820A) PC...
Dell Dimension 4600 PC Desktop Logo
271 people viewed this question
Alun Cox
