Question about Lexmark Office Equipment & Supplies
The display screen tells me to check inside the printer for obstructions, then press check
    Genius:
  • 1,550 Answers
This indicates that there is chance of paper jam on your printer . Remove the cover and remove any bit of paper and clean the roller with isopropyl alcohol and then put back cover and restart printer .
Hope this helps .
Posted on Dec 11, 2008
Keep getting paper jam fault 3618
Hi!
If the error comes up during the initial setup of the printer:
  • Select All-in-One Printers.
  • Double-click the Setup Guide for your printer.
  1. Open the printer access door.
  2. Remove all:
    • orange shipping tape
    • foam pieces
  3. Follow the steps in the Setup Guide to insure that you have properly installed the printhead and ink cartridges.
  4. Close the printer access door.
  5. Press OK to clear the error.
  6. Make a print.
OR
Check the printhead carriage area:
Debris and Obstructions:
  1. Remove any paper, tape or other obstructions from the printhead carriage area.
  2. Gently move the printhead carriage from side to side to see that it moves freely and there are no obstructions.
Ink Cartridges:
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
    NOTE: If the printhead does not move to the center position, press Home, then Maintenance on your printer. Check if the Install Ink Cartridge option is available. If so, select Install Ink Cartridges, press OK, and follow the instructions. Otherwise do the following:
    1. If an error is displayed on your printer control panel or the status monitor on your computer, press Cancel to clear the error.
    2. Go to KODAK All-in-One Printer Downloads and Drivers, select your printer from the All-in-One Printers pull-down list, and download and install the latest firmware version for your printer. Follow the on-screen instructions.
    3. After you upgrade the firmware, press Home on the printer control panel.
    4. Select Maintenance, then press OK.
    5. Select Install Ink Cartridges, then press OK.
    6. Follow the instructions on the control panel LCD.
    7. Go to the next step.
  2. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the black ink cartridge into the printhead, then press down firmly until you hear it click into position.
  5. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
  6. Close the printer access door.
  7. Press OK to clear the error.
  8. Make a print.
Hope this helps.
Apr 19, 2011 | Kodak ESP5250 All-In-One InkJet Printer
Service error 5100
1. 5100 is a carriage error, check the timing strip for contamination(plastic strip
about 1/4" in width)
The unit is not homing, check for
obstructions.
2. hold RESUME then press & hold POWER release RESUME, then press it twice, the light should go amber then green again.you're now in service
mode (you can release POWER now)
3. This error means that there is something obstructing the printing process. Check inside your printer through the gears that you can see under the lid. There
should be something obstructing the gears such as dirt or in my case popcorn.
There was even some paper caught underneath the rollers that I had to jiggle
around to even see. Check VERY thoroughly
Mar 23, 2011 | Office Equipment & Supplies
A PRINTER ERROR HAS OCCURED. SEE YOUR DOCUMENTATION. I RECEIVE THIS MESSAGE ON THE DISPLAY SCREEN. I HAVE NO PAPER JAMS. WHAT COULD BE THE POSSIBLE PROBLEMS?
Turn off your printer and unplug the power cable. Open the scanner lid. Double check for any obstructions. Move the print head to the left side and check again if there's obstructions on the right side. Close the lid and try to turn on the printer. If error message still displays on the screen, possibly it is a printer issue. It may require service.
Dec 16, 2010 | Epson Stylus RX580 InkJet Photo Printer
A printer error has occurred. See your documentation.
Dec 13, 2010 | Epson Stylus RX580 InkJet Photo Printer
OKI B6300 DRUM/TONER
try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Jul 28, 2009 | OKI B6300 Laser Printer
My hp desktop will not operate. It reports a message that I have a paper Jam. I have checked the printer as advised and there is no paper inside. I have also conducted all recommended shut down and...
You need to clean NVRAM on Lexmark X5470 printer. Please follow the steps given below to clear NVRAM on Lexmark X5470 printer:
1. Turn the printer off.
2. Hold down "#5" button and turn the printer back on.
3. Keep holding "#5" button for about 5-10 seconds.
4. Press "Menu" button once.
5. Press the right arrow until display shows "Tools."
6. Press "Check" button once.
7. Press the "Right" arrow button again until display shows "Maintenance."
8. Press "Check" button again.
9. Press the "Right" arrow button again until display shows "Manufacturing."
10. Press "Check" button again.
11. Press "Right" arrow until display shows "Clean NVRAM."
12. Press "Check" button to clear nvram.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
May 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Epson CX6400. No display. no power. does the printer have an inline fuse?
1.) Unplug all cable connections ( power cable and usb cable ).
2.) Check if there's any obstructions inside the printer.
3.) While the printer is off and unplugged., press and hold the on button for 10 sec.., release after 10 sec. and connect power cable.
4.) Turn on the power.
Apr 06, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Printer carrier stall
I am getting a "Printer Carrier Stall" message and "Check printer for obstruction" message. what can I do to fix it?
Oct 03, 2008 | Dell 966 All-In-One InkJet Printer
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
