Question about Mitsubishi WS-55807 TV
Concaved distorted picture in 1080 Mitsubishi 65" TV.
Recently we hooked up a DVR and High Definition cable box. Now there is a distortion where the picture is distorted and bows inward from the top and bottom. The image is also stretched at times. Sometimes, it also has lines going thru the image. It happens with regular tv, a DVD, etc.
  • 3 more comments
  • Anonymous Dec 19, 2008
    Same problem on my 60" Mitsubishi Diamond HD1080 , just turned the tv on one day and picture is bowed and colors not aligning. Trying to get a repair man in time for xmas - - - any hints as to what the cost to repair convergence problem???
  • lendalew25 Mar 04, 2009
    Abrsvcs i am having the same problem. Please provide the details and instructions you mentioned above.
    Thank You
  • Anonymous Mar 05, 2009
  • Anonymous Mar 07, 2009
    Abrsvcs Can you email me the fix procedure for convergence IC's?
    I have found that this only occurs during the warm up .. and then goes away..,. so I ssume its a resolder issue
    Kerrym60@yahoo.com
  • ellchevere Mar 30, 2009
    I have the same issue; a concaved distortion of my picture. Even when the screen is filled, it is distorted in all the corners. There are 'spectral' colors, I think red, yellow, and ... maybe blue. It used to come on and then disappear after a few minutes. But, now it's on almost all the time. We are weighing the option of repair versus buying a new unit.
  • 4,234 Answers
This is a convergence rpoblem that is either bad connections on the pins of the convergence ICs or defective ICs. If you can solder and are comfortable working inside TVs where there are potentially dangerous high voltages, let me know and I'll provide additional details and instructions for fixing this yourself.
Dan
Posted on Dec 11, 2008
  • Jason Kaduk Mar 23, 2013
    I have this same issue on my 65" WS-65907, first it would snap into a "bow" with all 3 colors exposed on the edges, then it would flip back to normal. now it's stuck like this, I would love to know what the fix is, and comfortable around the inside of the tv.
I have a mitsubishi ws55807 hd 1080 it has a convergence problem on the sides can it be ajusted with the remote dont now how which board is four the convergence middle right or left can you buy this board any where for good price
Posted on Apr 10, 2009
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
50' philips plasma tv has sound but picture is distorted
I sugest you to change the video resolution settings on the PS-3 to see if TV sets to any one resolution...if you have any other video out (analog from PS3)...connect the out to TV and check video at different resolutions. If PS3 has Deep Color settings turn it OFF.
Apr 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
My 57" Toshiba projection TV recently started having picture problems. The picture is distorted and wavy. The picture on the PIP screen is fine. is this a common problem and is it fixable?
First bypass the cable box and hook the tv directly to the cable to see if the problem goes away. if the problem persists you possibly have a bad input board.
Mar 13, 2010 | Toshiba 57HDX82 57" Rear Projection HDTV
High Definition--WS-55807
IF the MITS has 3 component inputs blue red yellow RCA jacks on the back then yes at 480 or 720p, you'll need to attach 2 audio cables for sound. If it has a HDMI input then absolutely.
please rate!
Mar 11, 2009 | Mitsubishi WS-55807 TV
HDTV CABLE NOT HOOKED UP/WORKING
COMP 1 and 2 are for 480i/p sources. Hook it to the 1080i capable on the back. Also make sure the HD DVR is outputting 1080i not 720p. The Mits can not disply 720p and will show a scrambled screen if you try to.
Jan 31, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Great Picture But No sound
Good Day;
Look in owners manual pages 28-35, pay special attention to page 31 and make sure the antenna is connected to ANT-DTV input. Good Luck, big IRISH.
Sep 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
My Mithsubishi HD-1080 rear projection tv 65 picture warps and distorted when first turned on.
sounds like your convergence ICs are getting weak, or the solder may need to be touched up.
Apr 06, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
voila....
now check your tv settings to accommodate
Nov 17, 2007 | Sony BRAVIA KDL-40V3000 Television
Mitsubishi WS-55807 TV Logo
597 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
