Question about Maytag MGR5770 Gas Kitchen Range
Clicking sound on my gas stove
We just moved into a new house, well, it is new to us. We have a Maytag gas range stove, and this morning. It just started clicking like we were trying to turn on one of the knobs to light a burner. My husband had just boiled some water on the stove, and he turned it off. A few minutes later we heard this clicking noise, on all of the burners. We didn't know why. We unplugged the stove from the outlet, and the clicking stopped. I need to know if I should get a repair person out to look at it? Is this normal? Please help!
    Habit-Forming:
  • 171 Answers
There switches behind each knob, 1 of them is broken,or wet, when you remove the knobs then remove the knob panel you can test them and find the bad one,they are no more then $15.00 each. to test you can plug the stove and disconect the switches one at a time until you find the bad one replace and you are back in bussines.
Posted on Dec 12, 2008
Maytag mgr5770adw incorrect oven temperature on digital display
Posted on Dec 20, 2008
4 Suggested Answers
SOURCE: I have a maytag stove
I have a Maytag stove Model #MER5875QCW The problem is it
Takes for ever for the stove to reach 350c Can anything be done?
Posted on May 24, 2008
oldskool55
  • 51 Answers
SOURCE: Clicking sound on my gas stove
You just need to turn the knob a bit more, thats the igniter you are hearing.
Posted on Mar 17, 2009
  • 105 Answers
SOURCE: replacing electrical outlet for stove top burner cartridge
You need to remove the cartridge then all of the screws that are around the inside perimiter of the well. You may also need to remove the control panel via the screws securing the top trim and the bottom flange. The part numbers for the wires with contacts are as foloow: 71002326 blue wire, 71002604 brown wire, 74005845 violet wire and w10116778 yellow wire. They should retail at @ 7.-8$ each.
Posted on Apr 07, 2009
HELLO I HAVE MAYTAG GEMINI GAS RANGE IT IS MAKING CLICKING SOUND WANT CAN I DO
The concern is tha the clicking sound is from the igniter for the gas.
It is correct at least in my stove that at the time you are turning on the flame that for a few seconds the stove generates a clicking sound which is actually arcing from a high voltage supply. Once the flame is lit the advancement of the flame control is to a higher flame position -OFF that of the start, is when the clicking should stop. There is no reason to leave the igniter on for a long time. If it does stay on all the time then that is a service issue that should be addressed. igniter devices can be expensive to replace- they are NOT continuous operational parts.
Aug 23, 2012 | Maytag Kitchen Ranges
Ignitor keeps clicking and i unplugged the stove and it still is clicking to ignite
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Jan 16, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
I GOT THE BURNER IGNITOR WET WHILE CLEANING STOVE...IT KEEPS CLICKING...WHAT DO I DO
It will stop once it drys out. The best bet is to unplug the electrical power cord and let it dry overnight. Plug it back in the morning and it should be fine. The moisture is most likely in one of the switches just behind the knobs.
Apr 21, 2010 | Maytag MGR6772 Gemini Gas Kitchen Range
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Gas stove makes clicking noise when turning on
When a gas stove is clicking, it means it is trying to ignite the burner. If the knob is held in the ignite position for more then 3 seconds and the burner does not ignite, it means that (1) the gas is shut off to the stove, (2) she does not have gas service set-up yet at the apartment, or (3) the gas nozzles feeding the burner are dirty and clogged.
Most of the time, when you move to a new apartment, you need to call the gas company and have the gas turned on, unless it is included in your rent. Either way, when a house or apartment is unoccupied, the gas is turned off for safety reasons. I would contact the landlord to be sure.
Mar 22, 2009 | Stoves 600SiDOm Gas Kitchen Range
Mar 17, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
The dial on my maytag gas stove shorted out
sounds as if one of your spark switches ( mounted on the gas valve itself) has shorted out, repalce the switch assembly, comeswith all foure sp[ark switches, easy enoough for you to do
Nov 30, 2008 | Maytag MGR5765QDS Stainless Steel Gas...
No ignition spark
sounds like you knocked a wire off something, theres1 module problably behind unit that controls all the clicking for entire stove, i would check there first
Nov 18, 2006 | Kenmore 78570 / 78571 / 78572 / 78574 /...
Maytag MGR5770 Gas Kitchen Range Logo
670 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal De GO PATS
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
