How to mount a conia CL3201HDR on the wall, no screws in box and not sure what thread size to purchase.
You need to purchase the wall mount separately. They range from a simple "on the wall" mount to swivels and extending mounts, and can be very expensive for the fancy features.
First, make sure your set is wall mountable. In the center of the rear of the set there will be a square arrangement of bolt holes. I do not know of any newer sets without them, but it does not cost anything to take a look and make sure.
Next, you need to decide on a mount. Personally, I did not want to spend allot, so I found a very inexpensive, yet good quality, "straight" mount at Sears for around $25.00. It does not extend or swivel, but all I wanted was to get it on the wall. Different screws and bolts were supplied with it and I was able to match up what worked for the back of my set.
Now, THE MOST IMPORTANT PART!!!!!
You ABSOLUTELY MUST find where your wall studs are! This is CRITICAL! DO NOT use any kind of expanding bolt to mount your set or it will eventually come loose and FALL!
I had an inexpensive "stud finder" (around $10-15) to show me where the wall studs are... Sears sells them too....You want to bolt your TV wall mount to the studs using 1/4" stud or lag bolts (they look like oversized wood screws) for maximum strength, if your mount will accept bolts that thick. Also use flat washers on the bolts. If your TV mount has its mounting bolt holes too wide apart for bolting to a standard 2" wide stud, mount a 6X6" piece of 1/2 plywood through your wall to the stud, using at least 4 #10 deck screws...it may be overkill, but it will be secure... my personal saying is, "If I can't hang from it, neither can my TV!" This is critical if you want to use a fancy swiveling mount that extends out since it will add stress to where you bolt it to the wall.
My mount was in two pieces.... a section that bolted to my wall, after I mounted a piece of plywood as I described above. This piece has a large pin that sticks up, and the part that mounts to my set (with the screws provided by the manufacturer of the mount) has a receiving hole that slides over the pin. When I need to take my set down, I simply lift it straight up.
I hope my long-winded solution did not bore you, and I wish you the best in hanging your set. Please take a minute and rate my solution.
VA
http://www.bestbuy.com/site/olspage.jsp?...
I have a wall mounting bracket on the wall. Problem is I have no way to attach it to the TV.
The bracket has a space to match up with the back of the TV but there is no reinforcement or holes for them to be attached.
What am I missing?
Thanks,
Tom
