Question about Marantz SR-7200 Receiver
On screen display menu
The owners manual says you can display on screen menus either through the remote or the main unit. Do you know how to display through the main unit? I cannot get the menus to display through the remote and want to change my speaker settings. Thank You
  • ercble Jul 24, 2008
    I have the same problem not able to access OSD remotely or from the unit. Help!
I scratched my head over this for an hour. The manual says you can access the OSD from the unit, but I see no way to do this. From the remote, you have to select the "AMP" setting at the top of the input list. Then hit the OSD button. Assuming your monitor is set up correctly, this will bring up the On Screen Display. Then hit the "Menu" button also on the remote, and you can make your adjustments. Good luck!
Posted on Jan 02, 2009
    Problem Solver:
Thank you ROZZY-VA for your help. The problem solved! I did not have it hooked up properly to my Television set. I was expecting to see the display on the unit itself. I kept reading the online Manual provided through Marantz websight and carefuuly followed the instructions to abtain on screen diplay. Thank you again for your help. ercble
Posted on Jan 06, 2009
    Problem Solver:
  • 6 Answers
I think you have already found the "MENU" button on the front panel ?!
Posted on May 18, 2008
Unlocking the remote and panel for Sharp Aquos LC-46LE832U 46 in. HDTV LCD TELEVISION
When all else fails read the owner manual page 35:
"• To unlock the buttons on the remote control by using the
touch sensor panel of the main unit (see page 25):
1 Press MENU to display the MENU screen, and then
press VOLl/k to select "System Options".
2 Press CHs/r to select "Operation Lock Out", and
then press INPUT.
3 Press CHs/r to select "Off", and then press INPUT.
4 Press MENU to exit.
• To unlock the buttons on the TV, press MENU on the
remote control, and then select "Off" in "Operation Lock
Out".
Took 5 minutes to find the manual for this unit. GOOGLE
Apr 05, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Kenwood ddx712
do you have the manual for your device.
Oct 23, 2008 | Car Audio & Video
Toshiba 36a42 picture problem
try to reset as below,
turn off the TV, remove the power supply from the main socket.
leave it for about 20 minutes
Turn it on again...
Jun 05, 2008 | Toshiba 27AF42 27" TV
How to get unit to play without remote
You can probably use the front panel buttons (STOP PLAY OPEN/CLOSE etc) manually, the only thing you cannot do without the remote is access certain DVD menus, including subtitles/language/special features etc. You can always obtain and use a universal remote for basic menu functions later on if necessary.
To play a DVD movie without the remote, simply load your preferred disc, wait for the player to finish reading its contents, then to skip copyright warnings and/or the 'play movie' menu screen, press STOP, then PLAY, or simply press PLAY button where 'play movie' (or whatever function) is highlighted in the menu. These buttons should be on the front of the main unit. Doing this should encourage the player to detect the appropriate title (the movie) and play it (basic playback operation may not be possible with some DVD releases due to the numerous interactive menus and title pages, such as film trailers).
If basic manual operation is not completely possible with some DVD titles, consider a universal remote for your player if you have either lost your original, or the player was purchased/received without one. Such remotes are relatively inexpensive to purchase, and are available just about everywhere.
Apr 22, 2011 | Panasonic Televison & Video
I have SC-PT750 Wireless system with SH-FX65T and SE-FX65, the wireless does not work and the screen flashes W1 to W2 and the SE-FX65 red light stays on
1 Turn on SE-FX65 2 While pressing [>>/>>'] ] press the numbered button [3] on the remote control until "P" lights in the home theater unit's display The indicator on SE-FX65 turns green. 3 While "P" is displayed, press [I/D SET] 4While pressing [>>/>>'} press the numbered button [3] on the remote control.
This worked for me. I moved and lost the FX65A, and Had to buy a replacement off ebay,
Used this manual http://www.specsserver.com/CACHE/FRQUJVMNXTYS.PDF but I have to give mosyzlak props, cause he gave me the idea to look for it.
Nov 28, 2010 | Panasonic Home Theater System System
How do i change the language from spanish to english on the insignia remote
Press the Setup button on your remote control to enter the on screen menus. Using the remote's navigation buttons, scroll to Language Settings, then Display Menu to set your preferred display language. The owner's manual can be found here for more details.
Dec 17, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
My clock will not display the outside temp. after battery replace
Try replacing the AA batteries in the main clock/display unit - that worked for me, then you'll probably need to press the reset button next to the AA batteries, and maybe the reset button next to the AAA batteries in the remote unit - press reset on the main unit first. My remote is now registering and the red light is flashing, but I don't know how to reset to the correct time and date - it's been scanning for a while and found nothing...
Nov 21, 2008 | Audio Players & Recorders
Remote malfunction - panasonic dvd stereo system
The remote control and main unit are factory-set to “REMOTE 1”
mode.
If your remote control affects other equipment during operation, you
can switch to operate in “REMOTE 2” mode.
To switch to “REMOTE 2” mode
1 While pressing and holding [AUX] on the main unit
Press and hold [2] until “REMOTE 2” appears on the
main unit display.
2 Press and hold [ENTER] and [2] for at least 2
seconds.
The main unit and remote control are now set to operate in
“REMOTE 2” mode.
To return to “REMOTE 1” mode
Do steps 1 and 2 above but use [1] instead of [2] for both steps.
(“REMOTE 1” appears on the main unit during step 1.)
The remote control cannot work with the main unit if their
modes are different.
“REMOTE 1” or “REMOTE 2” appears on the main unit display when
you operate the remote control.
If “REMOTE 1” appears (The main unit is in “REMOTE 1” mode.)
Press and hold [ENTER] and [1] on the remote control for at least
2 seconds.
If “REMOTE 2” appears (The main unit is in “REMOTE 2” mode.)
Press and hold [ENTER] and [2] on the remote control for at least
2 seconds.
Feb 21, 2008 | Audio Players & Recorders
No sound
1) Your subject line reads NO SOUND. Page 26 of the owner’s manual contains a trouble shooting guide and says for PROBLEM: No sound or poor sound, Adjust volume control on remote control or main unit, or Press the MUTE button to restore sound. I thought it might be the MUTE BUTTON. You can get a copy of the owner’s manual for free here http://tv.manualsonline.com/manuals/mfg/symphonic/sc313d_sc319d_1.html you do have to join to get the free owners manual in PDF form. After I joined I had to re-click the “get this manual” button. When I did, it brought up the PDF of the owners manual and I saved it to my computer in a folder I named purchases.
You can also view a copy of the owner’s manual for free with out joining anything here http://www.fixya.com/support/p16664-symphonic_sc313d_13_in_tv_vcr_combo/manual-17933 but you do have to page thru it one page at a time and it stays online.
2) Yes, you can purchase a new remote control for you tv. For 33.99 you can get one here http://remotes.com/store/symphonic/sc313d.html
Or for 29.95 you can get one here http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=N0105UD
Page 6 of the owner’s manual called the remote control unit PART NO. (N0150UD)
You may be able to find another source to purchase a remote control for you tv by searching for one in a search engine.
I hope my answers helped.
Feb 15, 2008 | Symphonic SC313D 13 in. TV/VCR Combo
On-screen menu Zenith Tv Model Z20A21D
it might be due to your cable operator giving important message. please reset tunning once or auto tune. give service code for opening menu. if you do notremember give me system control ic no. so i can send you thanks
Sep 11, 2007 | Televison & Video
Marantz SR-7200 Receiver Logo
1,022 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
